3 Replies Latest reply on Oct 21, 2014 9:25 AM by HaroonTyagi
    java.io.IOException: Stream closed when using webservice
    DvorakMK
      Hello,
      I created sample webservice (just because my other one didn't work):
      # cat test.cfc
      <cfcomponent>
          <cffunction name="echoString" access="remote" returnType="string" output="false">
              <cfargument name="input" type="string">
              <cfreturn arguments.input>
          </cffunction>
      </cfcomponent>
      and now i'm trying to use that webservice by soapUI by sending:
      <soapenv:Envelope xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" >
         <soapenv:Header/>
         <soapenv:Body>
            <def:echoString soapenv:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
               <input xsi:type="xsd:string">333</input>
            </def:echoString>
         </soapenv:Body>
      </soapenv:Envelope>
      And no matter what i will use i always getting response:
      <soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
         <soapenv:Body>
            <soapenv:Fault>
               <faultcode>soapenv:Server.userException</faultcode>
               <faultstring>java.io.IOException: Stream closed</faultstring>
               <detail>
                  <ns1:hostname xmlns:ns1="http://xml.apache.org/axis/">amz-fe-w02</ns1:hostname>
               </detail>
            </soapenv:Fault>
         </soapenv:Body>
      </soapenv:Envelope>
      The file works on other hosts, THe host is
      Red Hat Enterprise Linux Server release 6.4 (Santiago)
      with coldfusion 10
