Are you using the stand alone wizard or are you instead
referring to the one built into RoboHelp? I suppose it really
doesn't matter either way, as I actually believe both to be two
faces to the same product.
If you simply configure multiple destinations via the New...
button, I believe this gizmo will indeed publish from the source
location to all defined and selected destinations. You just need to
ensure all destinations are selected.
Yes, I know I can set up a server for each location I want to
publish to....but I can't run all three at the same time.....(can't
select more than one server at a time)...any ideas?
Is it the same if you set up the servers in the last page of
the wizard accessed from Single Source Layouts, rather than the
Smart Publishing Wizard? I have always been able to select multiple
servers there.
