1 Reply Latest reply on Jul 9, 2013 4:13 PM by markerline
    TypeError: Error #1034: Type Coercion failed...
    markerline Level 4
      I have the following ActionScript Error:
      TypeError: Error #1034: Type Coercion failed: cannot convert videos::Feed@c98e041 to mx.collections.IList.
          at Function/<anonymous>()[C:\flex45tfs\FlexGrocerC\YouTubeInspector\src\YouTubeInspector.mxm l:41]
          at Function/http://adobe.com/AS3/2006/builtin::apply()
          at mx.binding::Binding/wrapFunctionCall()[E:\dev\4.y\frameworks\projects\framework\src\mx\bi nding\Binding.as:395]
          at mx.binding::Binding/innerExecute()[E:\dev\4.y\frameworks\projects\framework\src\mx\bindin g\Binding.as:469]
          at mx.binding::Binding/execute()[E:\dev\4.y\frameworks\projects\framework\src\mx\binding\Bin ding.as:333]
          at mx.binding::Binding/watcherFired()[E:\dev\4.y\frameworks\projects\framework\src\mx\bindin g\Binding.as:511]
          at mx.binding::Watcher/notifyListeners()[E:\dev\4.y\frameworks\projects\framework\src\mx\bin ding\Watcher.as:311]
          at mx.binding::PropertyWatcher/eventHandler()[E:\dev\4.y\frameworks\projects\framework\src\m x\binding\PropertyWatcher.as:377]
          at flash.events::EventDispatcher/dispatchEventFunction()
          at flash.events::EventDispatcher/dispatchEvent()
          at mx.rpc::CallResponder/set lastResult()
          at mx.rpc::CallResponder/result()[E:\dev\4.y\frameworks\projects\rpc\src\mx\rpc\CallResponde r.as:120]
          at mx.rpc::AsyncToken/http://www.adobe.com/2006/flex/mx/internal::applyResult()[E:\dev\4.y\frameworks\projects\rpc\src\mx\rpc\AsyncToken.as:239]
          at mx.rpc.events::ResultEvent/http://www.adobe.com/2006/flex/mx/internal::callTokenResponders()[E:\dev\4.y\frameworks\projects\rpc\src\mx\rpc\events\ResultEvent.as:207]
          at mx.rpc::AbstractOperation/http://www.adobe.com/2006/flex/mx/internal::dispatchRpcEvent()[E:\dev\4.y\frameworks\projects\rpc\src\mx\rpc\AbstractOperation.as:244]
          at mx.rpc::AbstractInvoker/http://www.adobe.com/2006/flex/mx/internal::resultHandler()[E:\dev\4.y\frameworks\projects\rpc\src\mx\rpc\AbstractInvoker.as:318]
          at mx.rpc::Responder/result()[E:\dev\4.y\frameworks\projects\rpc\src\mx\rpc\Responder.as:56]
          at mx.rpc::AsyncRequest/acknowledge()[E:\dev\4.y\frameworks\projects\rpc\src\mx\rpc\AsyncReq uest.as:84]
          at DirectHTTPMessageResponder/completeHandler()[E:\dev\4.y\frameworks\projects\rpc\src\mx\me ssaging\channels\DirectHTTPChannel.as:451]
          at flash.net::URLLoader/onComplete()
      using Flash Builder 4.7 / Flex SDK 4.6.0 .... The code will follow...
        • 1. Re: TypeError: Error #1034: Type Coercion failed...
          markerline Level 4
          <s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
                                 xmlns:mx="library://ns.adobe.com/flex/mx"
                                 xmlns:elements="org.osmf.elements.*"
                                 xmlns:most_popular="services.most_popular.*"
                                 width="960" height="850" currentState="Normal">
              <fx:Declarations>
                  <s:CallResponder id="getDataResult"/>
                  <most_popular:Most_popular id="most_popular"
                                             fault="Alert.show(event.fault.faultString + '\n' + event.fault.faultDetail)"
                                             result="currentState = 'Normal'"
                                             showBusyCursor="true"/>
                  <!-- Place non-visual elements (e.g., services, value objects) here -->
              </fx:Declarations>
              <fx:Script>
                  <![CDATA[
                      import mx.controls.Alert;
                      import mx.events.FlexEvent;
                      private function getLabelField(item:Object):String{
                          return item.media_group.media_title.title;
                      protected function getData():void
                          getDataResult.token = most_popular.getData();
              </fx:Script>
              <s:states>
                  <s:State name="Normal"/>
                  <s:State name="Loading"/>
                  <s:State name="Error"/>
              </s:states>
              <s:List id="videoList" labelFunction="getLabelField"
                      width="300" height="580"
                      x="10" y="10" creationComplete="getData()" labelField="id">
                  <s:dataProvider>
                      <s:AsyncListView list="{getDataResult.lastResult}" />
                  </s:dataProvider>
              </s:List>
              <mx:SWFLoader id="videoDisplay" x="320" y="10"/>
              <mx:ColumnChart x="980" y="10">
                  <mx:series>
                      <mx:ColumnSeries />
                      <mx:ColumnSeries />
                      <mx:ColumnSeries />
                  </mx:series>
              </mx:ColumnChart>
              <s:Label x="10" y="618" text="Loading . . . "
                       includeIn="Error,Loading"
                       text.Error="Error in loading video list"
                       color.Error="#FF0000"/>
          </s:WindowedApplication>
          I'm trying to follow a tutorial for displaying YouTube videos in a Flex application but since it's MX+Spark I'm thinking the error has to do with the fact that MX is throwing an error.
