0 Replies Latest reply on Jul 9, 2013 9:27 PM by puuchyng
    Creating custom Adobe CQ commerce providers [ERROR]
    puuchyng
      I am trying to create a custom Adobe CQ commerce provider using maven, following this tutorial : Creating custom Adobe CQ commerce providers
      I am able to create the Adobe CQ archetype project successfully. However, when i try to run the command mvn eclipse:eclipse, i encounter the following error:
      C:\AdobeCQ\commerce-training>mvn eclipse:eclipse
      [INFO] Scanning for projects...
      [WARNING] The POM for com.day.jcr.vault:content-package-maven-plugin:jar:0.0.13
      is missing, no dependency information available
      [ERROR] The build could not read 1 project -> [Help 1]
      [ERROR]
      [ERROR]   The project com.adobe.training:commerce-training-content:1.0-SNAPSHOT
      (C:\AdobeCQ\commerce-training\content\pom.xml) has 2 errors
      [ERROR]     Unresolveable build extension: Plugin com.day.jcr.vault:content-pack
      age-maven-plugin:0.0.13 or one of its dependencies could not be resolved: Failur
      e to find com.day.jcr.vault:content-package-maven-plugin:jar:0.0.13 in http://re
      po.maven.apache.org/maven2 was cached in the local repository, resolution will n
      ot be reattempted until the update interval of central has elapsed or updates ar
      e forced -> [Help 2]
      [ERROR]     Unknown packaging: content-package @ line 20, column 16
      [ERROR]
      [ERROR] To see the full stack trace of the errors, re-run Maven with the -e swit
      ch.
      [ERROR] Re-run Maven using the -X switch to enable full debug logging.
      [ERROR]
      [ERROR] For more information about the errors and possible solutions, please rea
      d the following articles:
      [ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/ProjectBuildin
      gException
      [ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/PluginResoluti
      onException
      The pom.xml file is the default one generated from the command executed from the tutorial:
      <?xml version="1.0" encoding="UTF-8"?>
      <project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
          xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/maven-v4_0_0.xsd">
          <modelVersion>4.0.0</modelVersion>
          <!-- P A R E N T P R O J E C T D E S C R I P T I O N -->
          <parent>
              <groupId>com.adobe.training</groupId>
              <artifactId>commerce-training</artifactId>
              <version>1.0-SNAPSHOT</version>
          </parent>
          <!-- P R O J E C T D E S C R I P T I O N -->
          <artifactId>commerce-training-content</artifactId>
          <name>Commerce Training Package Package</name>
          <packaging>content-package</packaging>
          <build>
              <resources>
                  <resource>
                      <directory>src/main/content/jcr_root</directory>
                      <filtering>false</filtering>
                      <excludes>
                          <exclude>**/.vlt</exclude>
                          <exclude>**/.vltignore</exclude>
                      </excludes>
                  </resource>
              </resources>
              <plugins>
                  <plugin>
                      <groupId>org.apache.maven.plugins</groupId>
                      <artifactId>maven-resources-plugin</artifactId>
                      <configuration>
                          <includeEmptyDirs>true</includeEmptyDirs>
                      </configuration>
                  </plugin>
                  <plugin>
                      <groupId>com.day.jcr.vault</groupId>
                      <artifactId>content-package-maven-plugin</artifactId>
                      <extensions>true</extensions>
                      <configuration>
                          <group>adobe training</group>
                          <filters>
                              <filter>
                                  <root>/apps/commerce-training</root>
                              </filter>
                          </filters>
                          <embeddeds>
                              <embedded>
                                  <groupId>${project.groupId}</groupId>
                                  <artifactId>commerce-training-bundle</artifactId>
                                  <target>/apps/commerce-training/install</target>
                              </embedded>
                          </embeddeds>
                          <targetURL>http://${crx.host}:${crx.port}/crx/packmgr/service.jsp</targetURL>
                      </configuration>
                  </plugin>
              </plugins>
          </build>
          <dependencies>
              <dependency>
                  <version>${project.version}</version>
              </dependency>
          </dependencies>
          <profiles>
              <profile>
                  <id>autoInstallPackage</id>
                  <build>
                      <plugins>
                          <plugin>
                              <executions>
                                  <execution>
                                      <id>install-content-package</id>
                                      <phase>install</phase>
                                      <goals>
                                          <goal>install</goal>
                                      </goals>
                                  </execution>
                              </executions>
                          </plugin>
                      </plugins>
                  </build>
              </profile>
          </profiles>
      </project>
      Any ideas how to get this to work? Thanks in advance!
