0 Replies Latest reply on Jul 10, 2013 2:48 AM by chandrakantbaloogi
    how to add text to the carousel images ?
    chandrakantbaloogi
        Copyright 1997-2010 Day Management AG
        Barfuesserplatz 6, 4001 Basel, Switzerland
        All Rights Reserved.
        This software is the confidential and proprietary information of
        Day Management AG, ("Confidential Information"). You shall not
        disclose such Confidential Information and shall use it only in
        accordance with the terms of the license agreement you entered into
        with Day.
        Carousel component
      --%><%@include file="/libs/foundation/global.jsp"%><%
      %><%@ page import="java.util.Iterator,
                         java.util.LinkedHashMap,
                         java.util.Map,
                         com.day.cq.commons.Doctype,
                         com.day.cq.wcm.api.WCMMode,
                         com.day.cq.wcm.api.components.DropTarget,
                         com.day.cq.wcm.foundation.Image,
                         com.day.cq.wcm.foundation.List,
                         com.day.text.Text"
          %><cq:includeClientLib js="cq.jquery"/><%
          String xs = Doctype.isXHTML(request) ? "/" : "";
          if (WCMMode.fromRequest(request) == WCMMode.EDIT) {
              //drop target css class = dd prefix + name of the drop target in the edit config
              String ddClassName = DropTarget.CSS_CLASS_PREFIX + "pages";
              %><div class="<%= ddClassName %>"><%
          // initialize the list
          %><cq:include script="init.jsp"/><%
          List list = (List)request.getAttribute("list");
          if (!list.isEmpty()) {
              // config options
              int playDelay = properties.get("playSpeed", 6000);
              int transTime = properties.get("transTime", 1000);
              // todo: make default designeable
              String controlsType = properties.get("controlsType", "bc");
              boolean showControls = "pn".equals(controlsType);
              if (showControls) {
                  controlsType = "";
              } else {
                  controlsType = "-" + controlsType;
              // first shove all slides into a map in order to calculate distinct ids
              Map<String, Slide> slides = new LinkedHashMap<String, Slide>();
              Iterator<Page> items = list.getPages();
              String pfx = "cqc-" + Text.getName(resource.getPath()) + "-";
              while (items.hasNext()) {
                  Slide slide = new Slide(items.next());
                  String name = pfx + slide.name;
                  int idx = 0;
                  while (slides.containsKey(name)) {
                      name = pfx + slide.name + (idx++);
                  slide.name = name;
                  // prepend context path to img
                  slide.img = request.getContextPath() + slide.img;
                  slides.put(name, slide);
              %><div class="cq-carousel">
                  <var title="play-delay"><%= playDelay %></var>
                  <var title="transition-time"><%= transTime %></var>
                  <%-- write the actual slides --%>
                  <div class="cq-carousel-banners" >
                      <c:forEach var="slide" varStatus="loop" items="<%= slides.values() %>">
                      <div style="${loop.first ? "left: 0px; opacity: 1;" : "left: -1000px; opacity: 0;"}" id="${slide.name}" class="cq-carousel-banner-item">
                          <c:if test="${!empty slide.img}">
                              <a href="${slide.path}.html" title="${slide.title}">
                                  <img src="/etc/designs/default/0.gif" style="background-image:url(${slide.img})" alt="${slide.title}"<%= xs %>>
                              </a>
                          </c:if>
                          <h3>${slide.title}</h3>
                          <p>${slide.desc}<br<%= xs %>>
                              <a href="${slide.path}.html">Read More</a>
                          </p>
                      </div>
                      </c:forEach>
                  </div>
                  <%-- defines the controls --%>
                  <c:if test="<%= showControls %>">
                      <div class="cq-carousel-controls">
                          <a class="cq-carousel-control-prev" href="#" style="display:none"></a>
                          <a class="cq-carousel-control-next" href="#" style="display:none"></a>
                      </div>
                  </c:if>
                  <%-- write the switches, also needed when disabled --%>
                  <div class="cq-carousel-banner-switches<%= controlsType %>">
                      <ul class="cq-carousel-banner-switch">
                              <li><a class="${loop.first ? "cq-carousel-active" : ""}" title="${slide.title}" href="#${slide.name}"><img src="/etc/designs/default/0.gif" alt="0"<%= xs %>></a></li>
                          </c:forEach>
                      </ul>
                  </div>
              </div><%
          } else {
              if (WCMMode.fromRequest(request) == WCMMode.EDIT){
                  %><img src="/libs/cq/ui/resources/0.gif" class="cq-carousel-placeholder" alt=""><%
              %></div><%
           * Container class for slides
          public static final class Slide {
              private final Page page;
              private String img = "";
              private String title = "";
              private String name = "";
              private String desc = "";
              private String path = "";
              private Slide(Page page) {
                  this.page = page;
                  title = page.getTitle();
                  desc = page.getDescription();
                  if (desc == null) {
                      desc = "";
                  path = page.getPath();
                  // currently we just check if "image" resource is present
                  Resource r = page.getContentResource("image");
                  if (r != null) {
                      Image image = new Image(r);
                      img = page.getPath() + ".img.png" + image.getSuffix();
                  name = page.getName();
              public Page getPage() {
                  return page;
              public String getImg() {
                  return img;
              public String getTitle() {
                  return title;
              public String getName() {
                  return name;
              public String getDesc() {
                  return desc;
              public String getPath() {
                  return path;
