0 Replies Latest reply on Jul 10, 2013 4:58 AM by rayyan01
    Geolocation issue on andriod
    rayyan01
      I am facing problem using geolocation for andriod. It's working prefectly fine on some andriod devices but its giving problem on others.
      ISSUE:
      In location Setting
      Use wireless networks - true
      Use GPS satellites - true
      When i first time run the application, its listening the "GeolocationEvent.UPDATE" event and i am getting latitude and longitude.
      Now, when i am turning off "Use wireless networks " and "Use GPS satellites " , the event "GeolocationEvent.UPDATE" is not listen.Which
      is expected.
      Now, i am turning both on again "Use wireless networks" and "Use GPS satellites", my application is not able to listen "GeolocationEvent.UPDATE" and my handler is not called.
      Please note, same code is working on android(2.3.7). Its working as expected but on other devices.
      What can be the reason for that?
      Below is my code for your reference :
      private var geoLocation:Geolocation;
      public function getDeviceLatAndLng():void
           if(Geolocation.isSupported)
              geoLocation  = new Geolocation();
                                                        if(geoLocation.muted)
        trace('Muted')
                                                        geoLocation.addEventListener(GeolocationEvent.UPDATE,handleLocationRequest);
              else
                                trace('NOT Supported')
      private  function handleLocationRequest(event:GeolocationEvent):void
                                                   trace(event.longitude);
                                                   trace(event.latitude);
      Further, i have uncommented this from xml file for android:
      <uses-permission android:name="android.permission.ACCESS_FINE_LOCATION"/>
      regards,
      rayyan
