5 Replies Latest reply on Oct 11, 2007 9:28 AM by Newsgroup_User
    Creating a printable pdf newsletter..
    Level 7
      Hi All
      i want to create a pdf news letter that can be viewed and also printed.
      i will include images (low res) logos (vectors) and text.
      as i am used to working online, i need a little help with getting started...
      can i create this in FW and then print it as a PDF?
      is there a better Adobe product to use, i have the web premium suite - if so
      which.
      anything to watch out for, any tips, suggestions on fonts to avoid / uses
      ect.
      i have googled this but i havent yet found a good resource so if you know
      of one please post the URL.
      Thanks for any help
      as ever
      keen to learn..
        • 1. Re: Creating a printable pdf newsletter..
          Level 7
          Keen to Learn wrote:
          > Hi All
          PDF files are not the best solution for viewing information online. That
          said, if you have the Adobe CS3 Web Premium Suite, you have Acrobat 8
          Professional as well. You can create your document directly in Acrobat 8
          and import your Fireworks graphics, or you can create it in MS Word, MS
          Publisher, In Design, PageMaker, etc., in short in any layout or word
          processing program you like. To convert your document to PDF, just
          select it as your printer. I don't recommend using Fireworks because
          it's simply isn't meant for creating long text documents. It's an image
          editor, not a text editor.
          Linda Rathgeber [PVII] *Adobe Community Expert-Fireworks*
          http://www.projectseven.com
          Fireworks Newsgroup: news://forums.projectseven.com/fireworks/
          CSS Newsgroup: news://forums.projectseven.com/css/
          http://www.adobe.com/communities/experts/
          • 2. Re: Creating a printable pdf newsletter..
            Level 7
            > so which.
            InDesign, likely.
            Barring that, probably Illustrator.
            -Darrel
            • 3. Re: Creating a printable pdf newsletter..
              Level 7
              Hi Linda / Darrel
              thanks for you help.
              do you know of any online resouces / tutorials / good sites showing the best
              pratices of creating PDF documents?
              thanks again
              keen to learn..
              "darrel" <notreal@nowhere.com> wrote in message
              news:fej75t$55h$1@forums.macromedia.com...
              >> so which.
              > InDesign, likely.
              > -Darrel
              • 4. Re: Creating a printable pdf newsletter..
                Level 7
                > Hi Linda / Darrel
                Just create it as you would any regular text document.
                • 5. Re: Creating a printable pdf newsletter..
                  Level 7
                  Ok thanks - will do...
                  as ever
                  keen to learn..
                  "Linda Rathgeber" <lightly@sc.rr.com> wrote in message
                  news:feku8l$5th$1@forums.macromedia.com...
                  >> Hi Linda / Darrel
                  >> best pratices of creating PDF documents?
