13 Replies Latest reply on Jul 18, 2013 1:13 AM by Trevorׅ
    Script to activate the Color Separations Panel?
    tlumbis
      I've Frankensteined together a script (javascript) using bits and pieces that I've found here that deletes unused swatches, deletes unused character/paragraph styles, and deletes unused text boxes.
      As the final function, I want the script to activate the separatations panel preview (with only the black separation visible). I haven't been able to find any scripts that "activate" a panel for me to manipulate.
      Any help would be much appreciated.
      ------ Additional information that you probably don't need to know but maybe you'll have some clever solution for my problem that I haven't thought of. ------
      If any graphic or text has InDesign [Black] applied to it, it doesn't output to our negative printer. This obviously causes problems if a designer fails to apply a colored swatch to a graphic or text and then fails to check the separation preview for [Black] items.
      I first thought that it'd be fine just to have the script notify the designer if any items in the job had InDesign [Black] applied... but there are two layers on every one of our jobs that use InDesign [Black]... so the "alert" script would have to omit those two layers when searching for instances of InDesign [Black]... and this all seemed much more complicated than just having a script activate the the Separations Panel with Black selected.)
      Again, thank you for your help.
