2 Replies Latest reply on Jul 11, 2013 2:38 AM by panky245
    remove specific text variables (IDCS6)
    panky245
      Hello everybody,
      Is it true we cannot delete text variables in InDesign? I am trying something below:
      #target "InDesign"
      if(app.documents.length > 0){
        var myVariables = myDoc.textVariables;
      for(var i = 0; i < myVariables.length; i++){
      if(myVariables[i].variableType == VariableTypes.CUSTOM_TEXT_TYPE){
          var MyTextVarName=myVariables[i].name;
      if(MyTextVarName="TXT"){
          MyTextVarName.remove();//getting error here. Though when I refer to InDesign CS6 Object Reference (thanks to Jongware), function seems to be available.  Any clues
      I have got work around with but I still need to delete specific text variables.
      1. app.activeDocument.textVariables.item ('TXT').variableOptions.contents = "";
      TIA,
      Pankaj
        • 1. Re: remove specific text variables (IDCS6)
          -hans- Level 4
          MyTextVarName is a string, not a reference.
          Also your approach is to complicated so as you already know the name of the variable you want to remove and there's not need for looping so.
          var myCustomTextVariableName = 'sampleTV'
          var tV =  app.activeDocument.textVariables.itemByName(myCustomTextVariableName);
          if(tV.isValid){
              tV.remove();
              }else{
                  alert('Textvariable ' + myCustomTextVariableName + ' is not valid in active Document')
          • 2. Re: remove specific text variables (IDCS6)
            panky245 Level 1
            Thanks -hans-. Ican see the error pointed by you.
            Little bit of modification and things works as required.
            Much appreciated.
            Best,
            Pankaj
