Everytime I try to re install Photoshop I get these same errors.
dame143 Jul 11, 2013 8:10 AMEverytime I remove and re download photoshop I get these same exact errors.
Exit Code: 6 Please see specific errors below for troubleshooting. For example, ERROR: DF012, DF023,D ... -------------------------------------- Summary -------------------------------------- - 0 fatal error(s), 16 error(s) ----------- Payload: Recommended Common Fonts Installation 3.0.0.0 {4574D206-D61E-4555-B146-A16B01985E0B} ----------- ERROR: DF012: Unable to find file(Seq 27) ERROR: DF024: Unable to preserve original file at "C:\Windows\Fonts\CharlemagneStd-Bold.otf" Error 32 The process cannot access the file because it is being used by another process.(Seq 27) ----------- Payload: Recommended Common Fonts Installation x64 3.0.0.0 {9CA50986-FAD4-48DC-8362-1C2E201900BE} ----------- ERROR: DF012: Unable to find file(Seq 28) ERROR: DF024: Unable to preserve original file at "C:\Windows\Fonts\CharlemagneStd-Bold.otf" Error 32 The process cannot access the file because it is being used by another process.(Seq 28) ----------- Payload: Required Common Fonts Installation 3.0.0.0 {2A5D70AD-E4C3-4C3D-A18F-38B1CA51CE47} ----------- ERROR: DF012: Unable to find file(Seq 49) ERROR: DF024: Unable to preserve original file at "C:\Windows\Fonts\MyriadPro-CondIt.otf" Error 32 The process cannot access the file because it is being used by another process.(Seq 49) ----------- Payload: Required Common Fonts Installation x64 3.0.0.0 {FDA0F184-FB72-47E7-A8DB-FF7D25E8BF8C} ----------- ERROR: DF012: Unable to find file(Seq 50) ERROR: DF024: Unable to preserve original file at "C:\Windows\Fonts\MyriadPro-CondIt.otf" Error 32 The process cannot access the file because it is being used by another process.(Seq 50) ERROR: DF023: Unable to delete file copy at "C:\Windows\Fonts\MyriadPro-BoldCond.otf" Error 5 Access is denied.. Try setting correct permissions to the specified file/folder or parent folder, so that admin has rights to modify it.(Seq 46) ERROR: DW063: Error rolling back command ARKMoveFileCommand(Seq 46) ERROR: DF024: Unable to move file at "C:\Program Files\Common Files\Adobe\SavedFonts\current\MyriadPro-BoldCond.otf" to "C:\Windows\Fonts\MyriadPro-BoldCond.otf" Error 5 Access is denied.. Try setting correct permissions to the specified file/folder or parent folder, so that admin has rights to modify it.(Seq 46) ERROR: DW063: Error rolling back command ARKMoveFileCommand(Seq 46) ERROR: DF037: Unable to delete directory "C:\Program Files\Common Files\Adobe\SavedFonts\current". Error 145 The directory is not empty.. Check and correct folder & parent directory permissions and then try again.(Seq 4) ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 4) ERROR: DF037: Unable to delete directory "C:\Program Files\Common Files\Adobe\SavedFonts". Error 145 The directory is not empty.. Check and correct folder & parent directory permissions and then try again.(Seq 4) ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 4) ------------------------------------------------------------------------------------- Can someone help
