0 Replies Latest reply on Jul 11, 2013 12:29 PM by ramashish13
    How to handle DRM_AUTHENTICATE Event in VideoElement
    ramashish13
      I'm building a player that should be able to play DRM protected Videos. To do this, I'm using org.osmf.elements.VideoElement along with spark VideoPlayer. I need to listen to DRM_AUTHENTICATE event and supply the credentials for DRM.
      How should I go about doing this? I've tried adding the event listeners on VideoElement object, but it seems VideoElement doesn't dispatch DRM_AUTHENTICATE. NetStream seems to dispatch it, but I didn't find a way to get NetStream object from VideoElement.
      Here is a sample code that I'm using-
      var netLoader:NetLoader = new NetLoader();
      var videoElement:VideoElement = new VideoElement(new URLResource(path), netLoader);
      // The below doesn't work, the registered listeners do not get called for DRM video
      videoElement.addEventListener(DRMAuthenticateEvent.DRM_AUTHENTICATE, setDRMCredentials);
      videoElement.addEventListener(DRMAuthenticationErrorEvent.AUTHENTICATION_ERROR, onDRMAuthenticationError);
      videoPlayer.source = videoElement;
      videoPlayer.play();
      Thanks in advance,
      Ramashish
