7 Replies Latest reply on Jul 16, 2013 12:22 AM by MarcGriebenow
    Windows Service failing to start
      Hello Everyone,
      I'm trying to run CQ 5.6.1 as a service on Windows Server 2008 R2 SP1 64-bit.
      I've replaced prunsrv in instsrv.bat with prunsrv_amd64.
      Installing the service seems fine, as does uninstalling.
      This is the kind of entry I see in my c:\CQ\5.6.1\publish\crx-quickstart\logs\commons-daemon.2013-07-11.log file after I try start the service:
      [2013-07-11 15:45:10] [info]  Commons Daemon procrun ( 64-bit) started
      [2013-07-11 15:45:10] [info]  Running 'cq5' Service...
      [2013-07-11 15:45:10] [info]  Starting service...
      [2013-07-11 15:45:10] [error] Failed creating java
      [2013-07-11 15:45:10] [error] Cannot create a file when that file already exists.
      [2013-07-11 15:45:10] [error] ServiceStart returned 1
      [2013-07-11 15:45:10] [info]  Run service finished.
      [2013-07-11 15:45:10] [info]  Commons Daemon procrun finished
      The corresponding entry in the Event Log shows the following:
      <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
          <Provider Name="Service Control Manager" Guid="{555908d1-a6d7-4695-8e1e-26931d2012f4}" EventSourceName="Service Control Manager" />
          <EventID Qualifiers="49152">7024</EventID>
          <TimeCreated SystemTime="2013-07-11T19:45:10.423634500Z" />
          <Correlation />
          <Execution ProcessID="516" ThreadID="1356" />
          <Security />
          <Data Name="param1">cq5</Data>
          <Data Name="param2">%%0</Data>
      This same behavior is exhibited across three separate servers each with their own installation of CQ (one as an author and two as publish).
      Any ideas what could be going wrong or where I can find more detailed information about where and what is trying to create a "java" file?  Is the start-service.bat used at all?
        • 1. Re: Windows Service failing to start
          is your JAVA_HOME properly set?
          echo %JAVA_HOME%
          Something went wrong at installing the service... How did you install it?
          Best way for me was to fill in the vars in instsrv.bat and run it without a parameter to install the service
          Theres a little bug in instsrv.bat as the option
          set jvm_mx=16384m
          isnt properly handled by the script. You have to add the param to the jvm_options underneath
          • 2. Re: Windows Service failing to start
            garth914 Level 1
            Hi Marc,
            Thanks for your reply!
            JAVA_HOME is set.  It echoes out c:\Program Files\jdk1.7.0_25\jre.
            I installed the service as described by the documentation for the process.
            I've also applied the jvm_mx correction to jvm_options (as outlined by the documentation link above).
            No errors are reported during the installation, but evidently it's being installed misconfigured.  Adjusting instsrv.bat to only echo out the commands it runs gives back the following:
            C:\CQ\5.6.1\publish\crx-quickstart\opt\helpers>instsrv.bat cq5
            Installing service cq5
                runs in   C:\CQ\5.6.1\publish\crx-quickstart
                uses      C:\CQ\5.6.1\publish\crx-quickstart\opt\helpers\\..\..\app\cq-quickstart-5.6.1-standalone. jar
                starts    org.apache.sling.launchpad.app.Main
                redirects output to: C:\CQ\5.6.1\publish\crx-quickstart\logs\startup.log
            chdir /D C:\CQ\5.6.1\publish\crx-quickstart\opt\helpers\
            prunsrv_amd64 //IS//cq5 --Description="Adobe CQ5" --DisplayName="cq5" --Startup=
            ""auto"" --StartPath=C:\CQ\5.6.1\publish\crx-quickstart --Classpath=C:\CQ\5.6.1\publish\crx-quickstart\opt\helpers\\..\..\app\cq-quickstart-5.6.1 -standalone.jar --JvmMx=1792m --JvmOptions=-XX:MaxPermSize=256M;-Xmx1792m#-Dsling.run.modes="publish" --StdOutput=C:\CQ\5.6.1\publish\crx-quickstart\logs\startup.log --StdError=C:\CQ\5.6.1\publish\crx-quickstart\logs\startup.log --LogPath=C:\CQ\5.6.1\publish\crx-quickstart\logs --PidFile=..\conf\cq.pid --StartMode jvm --StartClass=org.apache.sling.launchpad.app.Main --StartParams=start#-c#.#-i#launchpad#-p#4503#
            -j#63000 --StopMode=jvm --StopClass=org.apache.sling.launchpad.app.Main --StopParams=stop --Jvm="auto"
            Do you think anything still looks wrong in there?
            • 3. Re: Windows Service failing to start
              MarcGriebenow Level 1
              Don't see big failures there
              The --Startup= ""auto""  is double double quoted, but thats the same in my skript
              At the JvmOptions we have used the semicolon in double quotes, like this
              and there's a # after your JvmOptions I think shouldn't be there. In my script the -Dsling.run.modes... is appended to startparams  (CQ5.5)
              Biggest problem here was the parameter at instsrv.bat cmd call. Please try it without the "cq5", just instsrv.bat
              It should get the service name from parameters inside the script
              Everything refers to cq5.5 instsrv.bat, don't know if it was edited
              • 4. Re: Windows Service failing to start
                garth914 Level 1
                Thanks for your help, but sadly there's still no difference.  Everything appears to be set as necessary and running the script with or without the service name still results in failure when I try to start the service.
                Unless any additional suggestions are forthcoming, it looks like I may need to submit a ticket to Adobe.
                • 5. Re: Windows Service failing to start
                  Additionally to Adobe Ticket, you can look into registry at
                  HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Apache Software Foundation\Procrun 2.0\{YOUR SERVICE NAME}\Parameters
                  if everything is set properly
                  There should be the folders Java, Log, Start and Stop
                  If you like you can post the reg keys here
                  • 6. Re: Windows Service failing to start
                    garth914 Level 1
                    Hrm... there's nothing in the Apache Software Foundation node at all!  Was there a setup step I missed somewhere that required these be registered before hand?  I'm guessing that this is part of what prunsrv_amd64 is supposed to do?
                    • 7. Re: Windows Service failing to start
                      In service property dialog of your CQ5 service there has to be a label "Path to executable" with the prunsrv.exe like the following
                      YOUR_PATH_TO\crx-quickstart\opt\helpers\prunsrv_amd64.exe //RS//CQ5-Author
                      The string after //RS// you can search via regedit
                      Maybe its in a different location
                      Did you try to reinstall your cq5 instance?
