• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
top.frames[1].bsscright.location
Explorer ,
Jul 11, 2013 Jul 11, 2013
I am modifying whtbar.js and need an alternative to top.frames[1].bsscright.location that would work in Chrome.
function ViewTopicInPrintWindow()
// opens the current topic htm file in a new window for printing
var strCurPage = top.frames[1].bsscright.location;
strCurPage += "?print=true"
var newWindow = window.open(strCurPage, newWindow, "toolbar=no,location=no,status=no,menubar=yes,scrollbars=yes");
This works fine in IE/FF but does not work in Chrome.
Specifically Chrome does not understand top.frames[1].bsscright.location; and the javascript just stops executing at that line and does not open up a new window.
I could change that to something like document.location and then the code works and the window actually opens but with the wrong HTM file: whskin_tbars.htm.
Thanks.
Views
533
Translate
Translate
Report
Report
Community guidelines
community guidelines
Explorer , Jul 11, 2013 Jul 11, 2013
The issue seems to be that Chrome does not allow access to other frames as a security measure. The Print View button is in the top bar so can only access the location of the skin HTM file.
I have a Show/Hide TOC + To Top persistent floating icons at the left middle of the topic pane. So in Chrome the user can hide the RoboHelp framework and show only the topic if they need to print.
Votes
Translate
Translate
Explorer ,
Votes
Translate
Translate
Report
Report
Community Expert ,
What version of Rh are you using and where is the help installed?
@petergrainge
Votes
Translate
Translate
Report
Report
Explorer ,
Jul 12, 2013 Jul 12, 2013
LATEST
I've verified that this is an issue related to Chrome as opposed to RoboHelp, the newer/newest versions do not help. The help is designed to be run locally or from a network share.
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
