1. Re: Cant see text and cant drag and drop images
c.pfaffenbichler Jul 12, 2013 12:39 AM (in response to dame143)Good day!
Please be more specific about the operations.
What is your OS, do you drag&drop from the Finder (edit: I’m a Mac user, I forgot what the OS surface is called on Windows), what are the specifics of the intended receiving document, insert text how exactly, …?
Regards,
Pfaffenbichler
2. Re: Cant see text and cant drag and drop images
phosphorspitter Jul 12, 2013 12:55 AM (in response to dame143)On the side is called Layer Palette there dopple click on the T then go to the Move Tool. It should scow now.
3. Re: Cant see text and cant drag and drop images
c.pfaffenbichler Jul 12, 2013 1:05 AM (in response to phosphorspitter)On the side is called Layer Palette there dopple click on the T then go to the Move Tool. It should scow now.
You might be mixing up stuff.
So there is a Text Layer (signified by an Icon with a »T« in the Layers Panel)?
Does it contain text yet?
When you double click that the text should become selected, but the Move Tool has nothing to do with this.
Could you please post a screenshot with the Layers Panel visible?
4. Re: Cant see text and cant drag and drop images
phosphorspitter Jul 12, 2013 1:13 AM (in response to c.pfaffenbichler)You started already 3 discussions.
Why?
5. Re: Cant see text and cant drag and drop images
c.pfaffenbichler Jul 12, 2013 1:21 AM (in response to phosphorspitter)phosphorspitter, I mistook you for the OP and you seem to have done the same thing in reverse.
I have started more than three discussions (edit: on other Fora), but this is not one of them.
6. Re: Cant see text and cant drag and drop images
dame143 Jul 12, 2013 2:47 PM (in response to phosphorspitter)What do you mean by this
7. Re: Cant see text and cant drag and drop images
dame143 Jul 12, 2013 2:49 PM (in response to dame143) -
8. Re: Cant see text and cant drag and drop images
c.pfaffenbichler Jul 13, 2013 1:18 AM (in response to dame143)Could it be you are working at a very low resolution (Image > Image Size)?
Because it seems like there is some very small text highlighted in the upper left corner.
Have you tried increasing the font size?
9. Re: Cant see text and cant drag and drop images
cagiali Jul 13, 2013 2:18 AM (in response to dame143)I also noticed that you are zoomed out to 2% scale, try to zoom in.
do you need such a large canvas? if not, make sure to check your resolution settings when creating a new document.
10. Re: Cant see text and cant drag and drop images
dame143 Jul 13, 2013 9:17 AM (in response to c.pfaffenbichler)Yes I have
11. Re: Cant see text and cant drag and drop images
dame143 Jul 13, 2013 9:20 AM (in response to cagiali)I do need it at that size
12. Re: Cant see text and cant drag and drop images
dame143 Jul 14, 2013 8:08 AM (in response to dame143)bump
13. Re: Cant see text and cant drag and drop images
c.pfaffenbichler Jul 14, 2013 8:28 AM (in response to dame143)Could you please provide a screenshot with the larger font size?
14. Re: Cant see text and cant drag and drop images
dame143 Jul 14, 2013 5:40 PM (in response to c.pfaffenbichler) -
15. Re: Cant see text and cant drag and drop images
c.pfaffenbichler Jul 14, 2013 11:09 PM (in response to dame143)I don’t seem to understand what the problem is.
Do you want to paste in another text?
What is the file’s resolution (Image > Image Soze)?
16. Re: Cant see text and cant drag and drop images
Alec Molloy Jul 15, 2013 8:58 AM (in response to dame143)Hi dame143, it seems to be that your text is pasting in just fine. Your problem is that your document size is so unusually large that your text is showing up too small. Either try reducing the size of your canvas, or make your type bigger.
17. Re: Cant see text and cant drag and drop images
dame143 Jul 17, 2013 11:22 AM (in response to Alec Molloy)how do i make my type bigger? I watched a video and the person had the same dimensions and it worked fine!
18. Re: Cant see text and cant drag and drop images
dame143 Jul 17, 2013 11:29 AM (in response to Alec Molloy)Many other people hvae the same dimensions and their banner is FINE!
19. Re: Cant see text and cant drag and drop images
Alec Molloy Jul 17, 2013 11:48 AM (in response to dame143)It looks like your document is almost a half a gigabyte large. Are you trying to make a large-format poster? Doing a quick calculation, it looks like you want something that is around 100 inches by 16 inches if you have your document set to 300dpi.
There isn't anything wrong with your banner, it is just that you need to use a font size that is big enough for your poster.
To help explain I made a short video. Please correct me if I am wrong about your document size.
20. Re: Cant see text and cant drag and drop images
dame143 Jul 17, 2013 3:35 PM (in response to Alec Molloy)ok well I spent at least 45 min creating a doc to only find that it is ""Too bing to save to web"" please help this is what im referring to his doc is the same as mine yet he only has to use 30 pt
21. Re: Cant see text and cant drag and drop images
Alec Molloy Jul 18, 2013 9:27 AM (in response to dame143)
