I get "no connection" when trying to activate Adobe Photoshop CS3 (firewall, antivirus is off). Also I called provided number and I didn't get activation code and was told to contact support. Chat support didn't help. What can I do to actiavate CS3 or it's impossible to do?
Then check you end make sure there is no file "host' that is redirect any of Adobe web site names like"
activate.adobe.com
practivate.adobe.com
ereg.adobe.com
activate.wip3.adobe.com
wip3.adobe.com
3dns-3.adobe.com
3dns-2.adobe.com
adobe-dns.adobe.com
adobe-dns-2.adobe.com
adobe-dns-3.adobe.com
ereg.wip3.adobe.com
activate-sea.adobe.com
wwis-dubc1-vip60.adobe.com
activate-sjc0.adobe.com
hl2rcv.adobe.com
CS3 activation servers are no longer on line so CS3 cannot be activated. For a time Adobe provided non activating versions of CS2 and CS3 but these are no longer available.
The pages below describe the end of life policy from Adobe
https://helpx.adobe.com/support/programs/support-periods.html
https://helpx.adobe.com/support/programs/eol-matrix.html#NZ
Not what you are looking for , I know 😞
Dave
Call Adobe I think they may have turned off their CS3 activation servers. CS3 they say is OLD. Remind Adobe you have licenced from them that gives you the right to use CS3. That they need to help you activate CS3.
Not easy to do... can't find a support phone number.
Do you have one?
This question is old and has been marked as answered. If you need help, open a new question with the suggested details and you will more likely get help.
Tips for effective posting
Title: Clearly describe the main problem in the title, but be brief. For example, "Photoshop Elements crashes on launch since updating to version 13" or "Output doesn’t look correct when sending PDF to Fiery RIP." (Titles such and “Help” or “Urgent” aren’t descriptive enough.)
Message body: Include details, such as:
old or not, the problem is relevant and still exists. hosts file is not an issue since I tried to connect from multiple pc's, windows 10, windows 8 and windows 7. some of which do not have cs3 installed at all (or any adobe products) one pc is a brand new install!
I feel like adobe has abandoned old owners. activation is difficult. I got into vmail hell trying to find an answer that does not state the product is no longer supported.
web connect activation is not working. I signed in and all I can find is HOW to activate. Come on, I am using CS3, ok? Now that I have a new pc and still want to use this software, I am stuck.
Any suggestions?
Yes, start a new topic about your problem so you will get more attention. This question is already marked as answered and is considered solved.
You need to provide system information. The CS3 servers are just fine, but something on your end is not working...
Mylenium
activate.adobe.com
ereg.adobe.com
wip3.adobe.com
3dns-3.adobe.com
3dns-2.adobe.com
adobe-dns.adobe.com
ereg.wip3.adobe.com
hl2rcv.adobe.com
JJMack thank you very much! There was a redirection from "activate.adobe.com" to localhost. I have no clue why and it did not come to my mind that something this basic could be the cause.
"JJMack thank you very much! There was a redirection from "activate.adobe.com" to localhost. I have no clue why and it did not come to my mind that something this basic could be the cause."
How EXACTLY do you fix this?
Activation has been closed for CS3. Visit the link to trade your serial number for a new serial number and activation-free CS3.
Be sure to uninstall the old CS3 and checkmark "remove old serial number" before installing your new copy.
Activation or connection error when starting CS3 or Acrobat 8
Hello gener7
Just curious where you checked the "remove old serial number" box when installing new version. I didn't notice it when uninstalling my old version and reinstalling the new version
Mike
When you run your old CS3 uninstaller, it should. But no problem. Just uninstall your old CS3 before installing the new one.
When installing the replacement CS3, you input the new serial number. If it asking for activation, which it should not, the old serial number is lurking about.
Try deleting the cache.db file from
Program Files (x86)/Common Files/Adobe/Adobe PCD/cache
Then repeat the install with the new serial.
I had the same problem and this also worked for me. Thank you very much!
Dear JJMack
Please help me understand where to find these "hosts" that you speak of
This is my problem also - and the "Activate" option under "Help" is also greyed out.
I want to try your solution
But I don't know how - do I do a search for those files you listed, and if I find any,
delete them??
I do hope you can help.
I am the genuine owner of my CS3 Master Collection
I still have receipts and codes and all
I don't understand why it won't work anymore
(I just reloaded it after reformatting my laptop)
yours hopefully, Jeni
where does one look for these "Hosts" that you speak of
and should I delete them??
(this might be just the right solution for me also...if I can deal with the 'hosts') thank you
Do not delete system files like hosts. JJ Mack will get back to you.
Not very helpful. If there is a redirect... how should it be directed back to the correct IP.
It states you answer is correct but I find no value in it at all.
Has anyone been able to decipher you cryptic answer and solve the problem?
Can you be more specific?
I have this same problem but I find the posts here confusing and do not help. I get "no connection" when trying to activate Adobe Photoshop CS3. No phone activation is available and chat support didn't help. What can I do to activate CS3? The posts here talk about ‘host’ files but these are very confusing giving no real instruction how to find them or what to do if you do find them. Simple answers are what most people need!
I just had the same problem and was able to get it fixed. Adobe Photoshop CS3 was prompting for the 'activate' but none of the options worked.
Used adobe chat support and provided them with a screen shot of the settings that appear when you choose manual mode (note: this only appears after you attempt to connect automatically and it fails). On this screen is the serial number and activation number.
I waited for almost an hour in the chat queue and it took the agent < 4 minutes to generate the updated authentication code. worked immediately soon as I entered it.
When I asked why it happened they said something to the effect that it was a technical glitch.
Not very helpful. I have the same problem. The re-activation searches for my internet connection but can't find it. Telephone re-activation no longer supported.
no true. my end is fine!
I have the same problem. Photoshop CS3. unable to activate via internet. phone support not working. I created a chat to Adobe Support. I gave them the activation code found when you select the phone support option then they gave me the authorization code. then boom! activated. problem solved.
how do you create a chat to adobe support??
