1. Re: find rectangle fillcolor below 100
S Hopkins Jul 12, 2013 4:46 PM (in response to indegn5)I am a little confused. Will your rectangles have both fill tint and transparency?
If you use app.findObject() to get an array of page items, make sure you set findChangeObjectOptions:
findChageOptions();
function findChangeOptions() {
var optionPref = app.findChangeObjectOptions;
optionPref.includeHiddenLayers = true;
//can be TEXT_FRAMES_TYPE, ALL_FRAMES_TYPE, UNASSIGNED_FRAMES_TYPE;
optionPref.objectType=ObjectTypes.GRAPHIC_FRAMES_TYPE;
optionPref.includeLockedLayersForFind=true;
optionPref.includeMasterPages=true;
Also, don't use select for moving items to layers. Parse through the array of found items (frameArr) and set the itemLayer property to a reference to the layer (layerRef):
var frameArr = myDoc.rectangles;
var layerRef = myDoc.layers.itemByName("Transparency");
for (var i = 0; i < frameArr.length; i++) {
if (frameArr[i].fillTransparencySettings.blendingSettings.opacity < 100) {
frameArr[i].itemLayer=layerRef;
Hope this helps.
2. Re: find rectangle fillcolor below 100
indegn5 Jul 13, 2013 5:41 AM (in response to S Hopkins)Hi Hopkins,
Thanks for your answer and solutions.
I have got result for transparency, but when i tried to moved all the rectangles below 100% tint, it moves all the rectangles including 100% tint to the layers.
var layerRef = myDoc.layers.itemByName("Miki");
if (frameArr[i].fillTint < 100) {
and about transparency;
without mentioning object "rectangle", how can i move any object which has transparency options applied on it to a particular layers...
thanks so much for your solution.....
3. Re: find rectangle fillcolor below 100
[Jongware] Jul 14, 2013 4:01 PM (in response to indegn5)Draw a rectangle. Fill it with 100% black. Select it. Run this script
alert (app.selection[0].fillTint);
and see what value it shows. Change the tint to 99% and run the script. Then change it back to 100% and run the script again.
4. Re: find rectangle fillcolor below 100
indegn5 Jul 14, 2013 9:59 PM (in response to [Jongware])Hi [Jongware],
After following your instruction, while checking 100% black, alert value is; -1 for 100 and 99 for 99%.
It means that it is not possible to select rectangle without defining the specific value.
However, please advice me, if there any solution to select and move the rectangle which has fill color below 100% value.
Many thanks [Jongware]. J.
5. Re: find rectangle fillcolor below 100
indegn5 Jul 14, 2013 10:20 PM (in response to indegn5)Hi,
I'm trying to move different percentage fillTints to different Layers. As Mr. [Jongware] said, I can't able to move 100% fillTint to move to 100% Layer.
var layerRef = myDoc.layers.itemByName("80% Tints");
if (frameArr[i].fillTint ==80) { // if I use value 100 it is not considered as value 100 (as -1 infact). And it is not moved or it moves to the layers alongwith the other % tints, where commanded to move.
app.select(frameArr[i]);
frameArr[i].itemLayer="80% Tints";
else {
frameArr[i].itemLayer="Mixed% Tints";
6. Re: find rectangle fillcolor below 100
indegn5 Jul 15, 2013 12:40 AM (in response to indegn5)Well!
I found the way to move 100% fillTints.
app.findObjectPreferences.fillTint = -1;
var myfound = app.findObject();
for (i=0; i<myfound.length; i++) {
app.select(myfound[i]);
myfound[i].itemLayer = "100% fillTints";
Can i get help from forum to do as per below request,
100% tints should not be moved alongwith the "tints less than 100% value".
Because again i have to move the 100% tints to the original location using above script.
7. Re: find rectangle fillcolor below 100
indegn5 Jul 15, 2013 10:38 PM (in response to indegn5)HI Forum,
This is what i'm lookig for.
To move different fillTints of the rectangle to different Layer.
i.e. 20% of fillTint to be moved to itemLayer = "20% fillTints".
30% to itemLayer = "30% fillTints"
the above 2 script moved the 100% fillTints to separate Layers and moves rest all the fillTints to one Layer.
HOw can I find different fillTints to move on its Own Layers.
8. Re: find rectangle fillcolor below 100
S Hopkins Jul 16, 2013 1:19 PM (in response to indegn5)I have been playing with your script problem while testing InDesign CC. I have found a small problem with this version; haven't tested in other versions yet. Anyway, notice in the code below that I am getting the ID for all rectangles and then resolving the reference to the rectangles using the ID. If I use
rectArr = docRef.rectangles; the loop that processes the rectangles does not produce consistent results.
Just thought I should mention why I am using the rectangle id's. It just works consistently.
/*Moves rectangles with 100% fill tint to specified layer;
rectangles with other tint values are moved to layers named using tint value
tested in Adobe InDesign CC*/
var docRef = app.documents.item(0);
//identify layer for items having 100% fill tint
var testLayer = docRef.layers.itemByName("Test");
var rectArr = docRef.rectangles.everyItem().id;
var tintVal, layerRef, rectRef, itemId;
//parse through list of rectangle ids and move to layers depending on tint value
for (var i = 0; i < rectArr.length; i++) {
itemId = rectArr[i];
rectRef = docRef.rectangles.itemByID(itemId);
tintVal = rectRef.fillTint;
if (tintVal == -1) {
rectRef.itemLayer = testLayer;
} else {
layerRef = checkLayer (docRef, tintVal);
rectRef.itemLayer = layerRef;
//checks to see if layer exists; if not, layer is created;
//note isValid only works with later versions of InDesign; otherwise check for null value
function checkLayer (docRef, tintVal) {
var testLayer;
var layerName = ("" + tintVal + "% fillTints");
if (!docRef.layers.itemByName(layerName) .isValid){
testLayer = docRef.layers.add({name:layerName});
} else {
testLayer = docRef.layers.itemByName(layerName);
return testLayer;
