1. Re: Slider Not Working
thetrickster888 Jul 13, 2013 12:29 PM (in response to Asad 6SM)I;m seeing your slider work correctly and there are no javascript errors in the console. You ok on this one?
2. Re: Slider Not Working
Liam Dilley Jul 13, 2013 3:36 PM (in response to thetrickster888)Im on a mac, able to look at IE?
Other browsers dont halt on all errors thetrickster like IE does.
IE will die if you dont close of with ; and will die if you have a , at the end of an object where there is no following object and more. Its use for me is javascript debugging, lol.
Jslint of course is the daddy of validation.
3. Re: Slider Not Working
thetrickster888 Jul 13, 2013 4:16 PM (in response to Liam Dilley)Tested on IE10-7 and the slider works and looks great on IE10-8 but looks a little messy on IE7 but still functions. No javascript errors on any of the IE versions i tested.
I think that it must be fixed by the time we got to see it
4. Re: Slider Not Working
Liam Dilley Jul 13, 2013 4:26 PM (in response to thetrickster888)IF he does not post back I will mark it as solved in a while.
5. Re: Slider Not Working
Asad 6SM Jul 14, 2013 10:44 AM (in response to Asad 6SM)Hi All
Apologies for the late reply. I managed to fix it after going through some of the code. I have noticed that BC changes the code for the orbit slider when copying trmplates across so you have to make shanges in dreamweaver and then upload the template.
All good and working now
Thanks for your replies though.
