0 Replies Latest reply on Jul 12, 2013 9:09 AM by Jamo
    Error reading an Excel file with a leading "#" in a cell
    Jamo Level 2
      Any recommendations on how to read an Excel XLSX file (using CFSpreadsheet) that has a leading "#" in a cell?
      I checked and this bug was reported over 2 years ago:
      (Please test and, if you encounter the problem, upvote to get this bug reopened.)
      The issue has been marked as "closed/withdrawn/cannot reproduce", but I am encountering the bug on the latest versions of both ColdFusion 9 & 10. It doesn't matter which format the column/cell is in. I've tried both "general" and "text".
      Here's simple spreadsheet sample data that will cause ColdFusion to throw an error:
      In some cases, the column is non-essential and it'd be ok to identify the column & remove it from the spreadsheet, but this can't apparently be done without first successfully reading the spreadsheet.
      Are there any work arounds for this?  Thanks.
