2 Replies Latest reply on Jul 19, 2013 9:57 AM by aditya p
    How to trigger an email when workflow instance fails??
    aditya p Level 1
      Hello,
      We have a requirement where in a mail should be triggered to the system administrator in case a workflow instance fails.
      I tried setting up a launcher (to trigger a Test Workflow that sends mail) with following configuration but it doesn't get triggered.
      The same launcher on cq:workflow node modification under /etc/workflow/instances/....... triggers my Test workflow if I change the Launcher Glob Path to /etc/workflow(/.*)
      So, I have a couple of questions:
      • Is this feature is available out of the box in CQ 5.6?
      • If not, then how should this requirement be implemented?
      Thanks!!
        • 2. Re: How to trigger an email when workflow instance fails??
          aditya p Level 1
          CQ provides a way to listen to workflow events and lets us handle events specifically. We have to implement org.osgi.service.event.EventHandler for this purpose.
          Here is a sample implementation for reference:
          package com.mycompany.test;
          import javax.jcr.RepositoryException;
          import javax.jcr.Session;
          import org.apache.sling.jcr.api.SlingRepository;
          import org.osgi.service.event.Event;
          import org.osgi.service.event.EventHandler;
          import org.slf4j.Logger;
          import org.slf4j.LoggerFactory;
          import com.day.cq.workflow.WorkflowException;
          import com.day.cq.workflow.WorkflowService;
          import com.day.cq.workflow.WorkflowSession;
          import com.day.cq.workflow.event.WorkflowEvent;
          import com.day.cq.workflow.exec.WorkItem;
          import com.day.cq.workflow.exec.Workflow;
          * WorkflowEventCatcher is listening to workflow events
            @Component( immediate=true)
            @Service
            @Property( name="event.topics", value=com.day.cq.workflow.event.WorkflowEvent.EVENT_TOPIC )
            public class WorkflowEventCatcher implements EventHandler {
            private static final Logger log = LoggerFactory.getLogger(WorkflowEventCatcher.class
            @Reference
            private WorkflowService workflowService;
            @Reference
            private SlingRepository repository;
            public void handleEvent(Event event) {
                  log.debug("Received event of topic: " + event.getTopic());
                  String topic = event.getTopic();
                  WorkflowSession wfSession = getWorkflowSession();
                  try {
                      if (topic.equals(WorkflowEvent.EVENT_TOPIC)) {
                          Object eventType = event.getProperty(WorkflowEvent.EVENT_TYPE);
                          String instanceId =
                                  (String) event.getProperty(WorkflowEvent.WORKFLOW_INSTANCE_ID);
                          Workflow instance = null;
                          try {
                              instance = (instanceId != null) ? wfSession.getWorkflow(instanceId) : null;
                          } catch (WorkflowException we) {
                              log.warn("Unable to load workflow instance", we);
                          if (instance != null) {
                              // workflow instance events
                              if (eventType.equals(WorkflowEvent.WORKFLOW_STARTED_EVENT) ||
                                      eventType.equals(WorkflowEvent.WORKFLOW_RESUMED_EVENT) ||
                                      eventType.equals(WorkflowEvent.WORKFLOW_SUSPENDED_EVENT)) {
                                   // your code comes here...
                              } else if (
                                      eventType.equals(WorkflowEvent.WORKFLOW_ABORTED_EVENT) ||
                                      eventType.equals(WorkflowEvent.WORKFLOW_COMPLETED_EVENT)) {
                              // workflow node event
                              if (eventType.equals(WorkflowEvent.NODE_TRANSITION_EVENT)) {
                                  WorkItem currentItem =
                                          (WorkItem) event.getProperty(WorkflowEvent.WORK_ITEM);
                  } finally {
                        if (wfSession != null) {
                           wfSession.logout();
                  return true;
              //----------< helper >-----------------------------------------------------
              private WorkflowSession getWorkflowSession() {
                  try {
                      Session adminSession = repository.loginAdministrative(null);
                      return workflowService.getWorkflowSession(adminSession);
                  } catch (RepositoryException re) {
                            log.error("RepositoryException: " + re);
                  return null;
          Aditya
