5 Replies Latest reply on Jul 16, 2013 2:32 AM by Sajeev Sridharan
    Getting first occurrence of XML elements
    Sajeev Sridharan Level 4
      Hi All,
      My XML tag looks like this:
      <xref rid="id001" ref-type="Test">
      <xref rid="id002" ref-type="Test">
      <xref rid="id003" ref-type="Test">
      <xref rid="id004" ref-type="Test">
      Code:
      var root = app.activeDocument.xmlElements[0];
      var xrefRid = root.evaluateXPathExpression('//xref[@rid]');
      var xrefType = root.evaluateXPathExpression('//xref[@ref-type]');
      for(i=0; i<xrefRid.length; i++)
          var refTypeValue =xrefRid[j].xmlAttributes.itemByName("ref-type").value;
          var ridValue =xrefType[j].xmlAttributes.itemByName("rid").value;
           if(refTypeValue == "Test")
                alert(ridValue);
      In my document multiple number of same "rid" is there, but I want the first occurence of the xref tag.
      For example, if <xref rid="id001" ref-type="Test"> will occur on different pages in a book, but i need the first occurence of the elements.
      Hope someone can help me...
      Vandy
        • 1. Re: Getting first occurrence of XML elements
          Fred Goldman Level 3
          If they are all in the same story I sort them by insertionPoint index using the Array.sort() method. I wonder if someone here has a better way.
          • 2. Re: Getting first occurrence of XML elements
            drerol74 Level 2
            Hello Vandy,
            I do not know how your XML structure is built up, but perhaps in this way:
            var _firstXref = _root.evaluateXPathExpression("//Story[position()=1]/xref[@rid][position()=1]");
            Roland
            • 3. Re: Getting first occurrence of XML elements
              Thanks for your reply roland.
              But it is not working fine. My XML structure will looks like this,
              <DOCUMENT>
              <CN>1</CN>
              <CT>Title</CT>
              <p1>Sample Text Sample Text Sample Text Sample Text Sample Text Sample Text</p1>
              <p>Sample Text Sample Text Sample Text <xref rid="id001" ref-type="Test"> Sample Text Sample Text Sample Text</p>
              <p>Sample Text Sample Text <xref rid="id002" ref-type="Test"> Sample Text Sample Text Sample Text Sample Text</p>
              <p>Sample Text Sample Text <xref rid="id001" ref-type="Test"> Sample Text Sample Text Sample Text Sample Text</p>
              </DOCUMENT>
              I want the first occurence of the xref tag, which I have highlighted in bold face.
              Vandy
              • 4. Re: Getting first occurrence of XML elements
                drerol74 Level 2
                If your structure is built in the same way as above, this XPath works fine:
                var _root = app.activeDocument.xmlElements.firstItem();
                var _firstXrefID001andID002 = _root.evaluateXPathExpression("//p[position()=1]/xref[@rid='id001']|//p[position()=2]/xre f[@rid='id002']");
                app.select(_firstXrefID001andID002);
                If other positions of <p> are possible, e.g.
                <DOCUMENT>
                      <CN>1</CN>
                      <CT>Title</CT>
                      <p>Sample Text Sample Text Sample Text <xref rid="id001" ref-type="Test"/> Sample Text Sample Text Sample Text</p>
                      <p>Sample Text Sample Text <xref rid="id002" ref-type="Test"/> Sample Text Sample Text Sample Text Sample Text</p>
                      <p>Sample Text Sample Text <xref rid="id001" ref-type="Test"/> Sample Text Sample Text Sample Text Sample Text</p>
                </DOCUMENT>
                You can try these XPathsExpressions and take the first element of resulting Arrays:
                var _firstXrefID001 = _root.evaluateXPathExpression("//p/xref[@rid='id001']");
                app.select(_firstXrefID001[0]);
                var _firstXrefID002 = _root.evaluateXPathExpression("//p/xref[@rid='id002']");
                app.select(_firstXrefID002[0]);
                Roland
                • 5. Re: Getting first occurrence of XML elements
                  Thanks Roland for your speedy reply.
                  Really helps a lot.
                  Vandy
