1 Reply Latest reply on Jul 16, 2013 2:54 AM by try67
    Script to complete date field and deactivate form
    KCott46
      Hi all,
      With little experience of Adobe I have been tasked to create a set of PDF forms for use within my company. I have designed the forms using Pro but I require a digital signature field that will complete a seperate date field upon signing and also deactivate certain fields within the form. At the moment I can get it to do either one or the other but I cannot get it to do both.
      Is there a script which I can use to carry out these functions?
      KC
        • 1. Re: Script to complete date field and deactivate form
          As you probably saw, there's an option under the Signed tab to execute a script when a digital signature is applied.
          To do what you described the following code can be used (of course, you'll need to adjust the field name):
          this.getField("SignatureTime").value = util.printd("mm/dd/yyyy", new Date()); // populate the date field with the current date
          this.getField("Text1").readonly = true; // Set some fields as read-only
          this.getField("Text2").readonly = true;
          this.getField("Text3").readonly = true;
          this.getField("Text4").readonly = true;
          etc.
