0 Replies Latest reply on Jul 16, 2013 3:52 AM by s_ashok
    Creating menu
    s_ashok
      The script was running at the first time. when i close and reopen the application its error message i have attached screen shot for you reference.
      #targetengine "HarbsTestMenu"
      menuInstaller();
      function menuInstaller() {
          // SET THE FILES THAT ARE TRIGGERED BY MENU ITEMS
          //var myFolder = Folder(app.activeScript.path);
          menuItem1Handler = function( /*onInvoke*/ ){
              app.doScript( File(myFolder + '1.jsx') );
          menuItem2Handler = function( /*onInvoke*/ ){
              app.doScript( File(myFolder + '2.jsx') );
      menuItem3Handler = function( /*onInvoke*/ ){
              app.doScript( File(myFolder + '3.jsx') );
      menuItem4Handler = function( /*onInvoke*/ ){
              app.doScript( File(myFolder + '4.jsx') );
          subMenuItem1Handler = function( /*onInvoke*/ ){
              app.doScript( File(myFolder + 'Ballart Tiping.jsx') );
      sub1TMenuItem1Handler = function( /*onInvoke*/ ){
            app.doScript( File(myFolder + 'test.jsx') );
         subMenuItem2Handler = function( /*onInvoke*/ ){
          app.doScript( File(myFolder + 'AddPoints.jsx') );
          // SET GENERAL VARIABLES
          try {
              myFolder = app.activeScript;
          catch(e) {
              myFolder = File(e.fileName);  // we are running from the ESTK
          myFolder = myFolder.parent.parent  + '/Scripts Panel/' ;  //this file is in the "startup scripts" subfolder
          var menuItem1T = "Rename_Links",
             menuItem2T = "Conver RGB image to CMYK",
             menuItem3T = "Conver ALL image to Gray",
             menuItem4T = "Add & Remove Unwated Swatches/Convert RGB,Spot Colors to CMYK",
             subMenuItem1T = "Ballart Footy Tipping",
             sub1TMenuItem1T = "To Come",
            subMenuItem2T = "AddPoints",
             menuT = "2adpro_Automation",
             subT = "Ballart",
             sub1T = "Wagga wagga",
             subs = app.menus.item("$ID/Main").submenus, mnu;
          var refItem = app.menus.item("$ID/Main").submenus.item("$ID/&Help");
          // CREATE MENU ITEMS
          subMenu1 = app.scriptMenuActions.item(menuItem1T);
          if( subMenu1 == null ) {
              subMenu1 = app.scriptMenuActions.add(menuItem1T);
          subMenu1.eventListeners.add("onInvoke", menuItem1Handler);
          subMenu2 = app.scriptMenuActions.item(menuItem2T);
          if( subMenu2 == null ) {
              subMenu2 = app.scriptMenuActions.add(menuItem2T);
          subMenu2.eventListeners.add("onInvoke", menuItem2Handler);
          subMenu3 = app.scriptMenuActions.item(menuItem3T);
          if( subMenu3 == null ) {
              subMenu3 = app.scriptMenuActions.add(menuItem3T);
          subMenu3.eventListeners.add("onInvoke", menuItem3Handler);
      subMenu4 = app.scriptMenuActions.item(menuItem4T);
          if( subMenu4 == null ) {
              subMenu4 = app.scriptMenuActions.add(menuItem4T);
          subMenu4.eventListeners.add("onInvoke", menuItem4Handler);
          subSubMenu1 = app.scriptMenuActions.item(subMenuItem1T);
          if( subSubMenu1 == null ) {
              subSubMenu1 = app.scriptMenuActions.add(subMenuItem1T);
          subSubMenu1.eventListeners.add("onInvoke", subMenuItem1Handler);
          subSubMenu2 = app.scriptMenuActions.item(subMenuItem2T);
          if( subSubMenu2 == null ) {
              subSubMenu2 = app.scriptMenuActions.add(subMenuItem2T);
          subSubMenu2.eventListeners.add("onInvoke", subMenuItem2Handler);
         sub1TSubMenu1 = app.scriptMenuActions.item(sub1TMenuItem1T);
          if( sub1TSubMenu1 == null ) {
              sub1TSubMenu1 = app.scriptMenuActions.add(sub1TMenuItem1T);
          sub1TSubMenu1.eventListeners.add("onInvoke", sub1TMenuItem1Handler);
          mnu = subs.item(menuT);
          if( mnu == null ) {
              mnu = subs.add(menuT, LocationOptions.after, refItem);
          subsSubs = app.menus.item( '$ID/Main' ).submenus.item( menuT ).submenus;
          mnuSubMenu = subsSubs.item( subT );
          if( mnuSubMenu == null ) {
              mnuSubMenu = subsSubs.add( subT);
          mnuSub1TMenu = subsSubs.item( sub1T );
          if( mnuSub1TMenu == null ) {
              mnuSub1TMenu = subsSubs.add( sub1T);
          mnu.menuItems.add(subMenu1,LocationOptions.BEFORE,mnuSubMenu);
          mnu.menuItems.add(subMenu2,LocationOptions.BEFORE,mnuSubMenu);
          mnu.menuItems.add(subMenu3,LocationOptions.BEFORE,mnuSubMenu);
          mnu.menuItems.add(subMenu4,LocationOptions.BEFORE,mnuSubMenu);
          mnu.menuSeparators.add(LocationOptions.BEFORE,mnuSubMenu);
          mnuSubMenu.menuItems.add(subSubMenu1,LocationOptions.AFTER,mnuSubMenu);
          mnuSub1TMenu.menuItems.add(sub1TSubMenu1,LocationOptions.AFTER,mnuSub1TMenu);
          mnuSubMenu.menuItems.add(subSubMenu2,LocationOptions.AFTER,mnuSubMenu);
