1. Re: R27 App Builder rebuilt dev app won't install
Bob Bringhurst Jul 16, 2013 9:11 AM (in response to pintstabilo)You're talking about adding the dev app to iTunes, not submitting the distribution app to Apple, right? Have you tried removing the app from both iTunes and the device, syncing, and then adding the dev app again? Before you sync, make sure the app is set to be installed.
2. Re: R27 App Builder rebuilt dev app won't install
pintstabilo Jul 16, 2013 9:35 AM (in response to Bob Bringhurst)Hi Bob.
Yes it's a dev app.
I generally use XCode organiser to install dev apps, but iTunes also fails with all of the above tried. Also on 2 other Mac's with different version of XCode too.
The pre R27 App Builder build still installs ok.
It's anything (I have numerous apps) built with R27 AB fails, and fails silently (within a couple of seconds) in iTunes and XCode. There's no indication of failure in any logs.
However, as I said, the app will install via a itms-services link but very fustrating as in middle of development and forced to upgrade to R27. Had enough issues when forced to R26.
I also had numerous other issues all weekend with the Nav Tool bar Auto Launch button sticking on for all custom slots after I'd relaunched AB but this seems to have miraculously corrected itself today.
Thanks for the reply.
3. Re: R27 App Builder rebuilt dev app won't install
pintstabilo Jul 16, 2013 9:38 AM (in response to pintstabilo)Ok, I've downloaded the app from App Builder i.e. resigned the app on a 2 different Macs (running Lion/Mountain Lion) as well now and that fails so that should eliminate the signing process.
4. Re: R27 App Builder rebuilt dev app won't install
pintstabilo Jul 16, 2013 9:41 AM (in response to pintstabilo)And the same happens on different devices e.g. iPad Mini, iPad 1, iPhone 4.
5. Re: R27 App Builder rebuilt dev app won't install
Bob Bringhurst Jul 16, 2013 10:22 AM (in response to pintstabilo)I can't reproduce this problem, so I'm not sure how to help. Please contact support about this issue.
6. Re: R27 App Builder rebuilt dev app won't install
pintstabilo Jul 16, 2013 10:33 AM (in response to Bob Bringhurst)Ok, thanks Bob
