6 Replies Latest reply on Jul 20, 2013 2:06 PM by iccsi
    pass parameter from user choice to a query
    iccsi Level 1
      I have a CFSELECT on the form and link to a query.
      I would like to fill details information when user select thew option.
      The option is at client side, since user select the option which I need pass my query to get information to fill on the details form on the same form.
      I tried to use following JavaScripts which fill the details information, but browser goes to the page which I want to fill the details informaiton on the same form.
      function FillInfo()
      /*Fill Details Information*/
        var url = 'ccdDetailsInfo.cfm?MyAccount=' + document.getElementById('frmEntry').lstNumber.value;
      I tried to use iFrame, it works and fill on the same form, but everything under iFrame disappear like footer and all other controls in the table.
      <iframe id="DetailsFrame"  src="ccdDetailsInfo.cfm"</iframe>
      I tried to use CFINCLUDE the file, but it does not take the paramter from client side.
      The problem is the query paramter is server side query.
      I am looking for a way can pass the client data to server parameter to run the query and to fill details form.
      I did some reasearch for this on Google, but no luck,
      If you can give me some link regarding pass parameters between client and CF server would be appreciated,
      Regards,
      Iccsi,
        • 1. Re: pass parameter from user choice to a query
          p.sim Level 3
          Use HTML select instead of cfselect; and use AJAX instead of iFrame.
          See this link: http://www.w3schools.com/jquery/ajax_ajax.asp
          Replace url:"demo_test.txt" with e.g. url:"get_data.cfm"
          • 2. Re: pass parameter from user choice to a query
            iccsi Level 1
            Thanks for the message and help,
            If I understand correctly, the sample read demo_test.txt and put the content on div1.
            which I can read from external text file.
            I want to pass my value on the select to my query parameter.
            In this case, I need create an external file using my client page or I can read any variable on the demo_test.txt?
            Please let me know if I am wrong,
            Thanks again for helping,
            Regards,
            Iccsi,
            • 3. Re: pass parameter from user choice to a query
              p.sim Level 3
              <!--- my_form.cfm --->
              <script src="http://code.jquery.com/jquery-1.9.1.js"></script>
              jQuery(document).ready(function() {
                        jQuery("#product_id").change(function() {
                                  jQuery.ajax({
                                            url: "get_detail.cfm?product_id=" + jQuery("#product_id").val()
                                            , type: "get"
                                            , success: function(result) {
                                                      jQuery("#product_detail").html(result);
              </script>
              <form method="post" action="">
                        <select id="product_id">
                                  <option value="1">Apple</option>
                                  <option value="2">Banana</option>
                                  <option value="3">Cherry</option>
                        </select>
                        <div id="product_detail"></div>
              </form>
              <!--- get_detail.cfm --->
              <!--- You replace this with query --->
              <cfswitch expression="#url.product_id#">
                        <cfcase value="1">My color is red.</cfcase>
                        <cfcase value="2">My color is yellow.</cfcase>
                        <cfcase value="3">My color is dark red.</cfcase>
                        <cfdefaultcase>Invalid product id</cfdefaultcase>
              </cfswitch>
              • 4. Re: pass parameter from user choice to a query
                iccsi Level 1
                Thanks for the information and help,
                If I understand correctly, jQuery create above link with parameter and
                using CFINCLUDE to have  get_detail.cfm in Product_Detail div that get_detail.cfm will accept #product_id  parameter.
                Regards,
                Iccsi,
                • 5. Re: pass parameter from user choice to a query
                  p.sim Level 3
                  jQuery("#product_id").val() -- is to get the value of selected option.
                  The value is concatenated to the "get_detail.cfm?product_id="
                  When get_detail.cfm is called, it will return a string as a "result" in the jQuery. Then, the result is inserted to the div tag which is "product_detail".
                  Go to jQuery documentation to learn more about ajax(), val(), and html(). The doc explains very clear and it has some examples how to use them.
                  • 6. Re: pass parameter from user choice to a query
                    iccsi Level 1
                    Thanks a million for helping and information,
                    regards,
                    iccsi,
