1. Re: Enable Arabic in Ai CC?
Monika Gause Jul 16, 2013 3:02 PM (in response to dwalk75)Try and activate the Indic type support in preferences.
Then in paragraph panel select the arabic & indic type composer.
Also align right.
Does that work for you?
2. Re: Enable Arabic in Ai CC?
dwalk75 Jul 16, 2013 5:20 PM (in response to Monika Gause)Yes this worked! Thanks so much, Adobe should send you the pay check of the tech I spoke to. This was a simple task to achieve, I can't believe tech support couldn't tell me this.
Take care!
3. Re: Enable Arabic in Ai CC?
Monika Gause Jul 16, 2013 5:54 PM (in response to dwalk75)You're welcome
4. Re: Enable Arabic in Ai CC?
SUnOregano Nov 4, 2013 6:44 AM (in response to Monika Gause)Hi Monica,
Thanks for your enlightement. It really worked well for me too.
Have a great day
5. Re: Enable Arabic in Ai CC?
BasBous Feb 13, 2014 5:57 PM (in response to Monika Gause)that was simple thank you Monika!
6. Re: Enable Arabic in Ai CC?
Mir Israr Mar 9, 2014 5:32 AM (in response to Monika Gause)hello monika, thanks for the help however this seems to solve half of the arabic problem, by doing this i am able to copy paste arabic into text format however its not reading from right to left, the problem is with full stop at the end of the sentence, please help.
7. Re: Enable Arabic in Ai CC?
Bahraini May 4, 2014 11:45 AM (in response to Monika Gause)Hey Monika
Thanks for this
The adobe tech support guy wasn't helpful at all
I didn't even get the answer at the end
You're a lifesaver and you're awesome
8. Re: Enable Arabic in Ai CC?
christianmercado Jun 25, 2014 3:04 AM (in response to dwalk75)im looking for this answer as well... it worked fine with me..
Thank you so much guys
9. Re: Enable Arabic in Ai CC?
tuahabadarshaikh Nov 26, 2014 11:08 PM (in response to dwalk75)Okay I got it better way, that worked for me, just download arabic cs4 template and open that file into illustrator cc. (Make sure that you check the box 'convert layers to object') also make sure you have arabic keyboard enabled and start typing on illustrator. Hope this helps.
10. Re: Enable Arabic in Ai CC?
m.boodai Dec 1, 2014 10:38 PM (in response to Monika Gause)thanks Monica for you smat solution
