1 Reply Latest reply on Jul 17, 2013 1:21 PM by dnelson42
    Cannot Debug CQ 5.6 in MyEclipse
    dnelson42 Level 1
      When I try to connect the debugger I get an error "Failed to connect to remote VM. Connection refused". I have tried in both eclipse and MyEclipse. It used to work but I cant figure out what has changed. I am stumped.
      More details:
      I have my Remote Java Application host & port set to localhost and 30303 respectively. The correct project is set.
      I am initiating a debug from the windows command line using:
      java -Xdebug -Xnoagent -Djava.compiler=NONE -Xrunjdwp:transport=dt_socket,server=y,suspend=n,address=30303 -XX:+HeapDumpOnOutOfMemoryError -XX:MaxPermSize=512M -Xmx1280m -Dorg.apache.sling.commons.log.level=INFO -jar cq5-author-p4502.jar -p 4502 -verbose -nofork
      I get the following back:
      Listening for transport dt_socket at address: 30303
      Loading quickstart properties: default
      Loading quickstart properties: instance
      Low-memory action set to fork
      Using 64bit VM settings, min.heap=1024MB, min permgen=256MB, default fork argume
      nts=[-Xmx1024m, -XX:MaxPermSize=256m]
      The JVM reports a heap size of 1137 MB, meets our expectation of 1024 MB +/- 20
      The JVM MBean:PS Perm Gen reports a maximum size of 512 MB, meets our expectatio
      n of 256 MB +/- 20
      Setting properties from filename 'C:/adobe/CQ5.6/author/cq5-author-p4502.jar'
      Option '-quickstart.server.port' set to '4502' from filename cq5-author-p4502.ja
      Verbose mode - stdout/err not redirected to files, and stdin not closedResourceP
      rovider paths=[/gui, /gui/default]
      DiskSpaceUtil.getMaxOpenFiles() reports a maximum of 2147483647 open files, meet
      s our requirement (8192)
      PortSelector: Selecting server port from supplied list: 4502
      PortSelector: Trying port 4502
      PortSelector: Successfully bound to port 4502, will use it
      PortSelector: Selected port 4502
      Build number not changed, software update not needed
      UpgradeUtil.handleInstallAndUpgrade has mode RESTART
      Upgrade: no files to restore from pre-upgrade backup
      Press CTRL-C to shutdown the Quickstart server...
      Sling Home: C:\adobe\CQ5.6\author\.\crx-quickstart
      Launchpad Home: launchpad
      Sling Properties: conf/sling.properties
      Application arguments: {sling.launchpad=launchpad, sling.home=C:\adobe\CQ5.6\aut
      hor\.\crx-quickstart, sling.properties=conf/sling.properties, org.osgi.service.h
      Quickstart application directory: C:\adobe\CQ5.6\author\.\crx-quickstart/app
      App classpath:
      - file:/C:/adobe/CQ5.6/author/./crx-quickstart/app/cq-quickstart-5.6.0-standalo
      Main class: org.apache.sling.launchpad.app.Main
      16.07.2013 18:00:46.079 *INFO * [main] Setting sling.home=C:\adobe\CQ5.6\author\
      .\crx-quickstart (command line)
      16.07.2013 18:00:46.081 *INFO * [main] Starting Apache Sling in C:\adobe\CQ5.6\a
      16.07.2013 18:00:46.088 *INFO * [main] Checking launcher JAR in folder C:\adobe\
      16.07.2013 18:00:46.098 *INFO * [main] Existing launcher is up to date, using it
      : 2.4.1.R1416835 (org.apache.sling.launchpad.base.jar)
      16.07.2013 18:00:46.102 *INFO * [main] Loading launcher class org.apache.sling.l
      aunchpad.base.app.MainDelegate from org.apache.sling.launchpad.base.jar
      16.07.2013 18:00:46.112 *INFO * [main] Setting sling.launchpad=C:\adobe\CQ5.6\au
      16.07.2013 18:00:46.113 *INFO * [main] Setting sling.home=C:\adobe\CQ5.6\author\
      16.07.2013 18:00:46.114 *INFO * [main] Setting sling.properties=conf/sling.prope
      16.07.2013 18:00:46.116 *INFO * [main] Setting org.osgi.service.http.port=4502
      16.07.2013 18:00:46.117 *INFO * [main] Starting launcher ...
      16.07.2013 18:00:46.118 *INFO * [main] HTTP server port: 4502
