9 Replies Latest reply on Aug 12, 2013 8:41 AM by Xoco
      • 1. Re: how do you create & use global variables in edge animate?
        AMULI Level 4
        Hi maulshre,
        1) Preceding the name of a variable with var makes it local.
        2) « Global » (but local to a symbol)  variable:
        You can define in the Stage.compositionReady event handler a function callable from somewhere else in the Stage symbol :
        instanceNum = function( eRollover)
          console.log( eRollover.target.getAttribute("id"));
        Then each of the instances on stage of a given symbol yellowRect (with instance names yellowRect1, yellowRect2, yellowRect3 and yellowRect4) can have a mouseover event handler which is a call to the global function :
        instanceNum( e);
        3) Truly global variable (accessible from every symbol) :
        Definition in a symbol (usually inside the Stage.compositionReady event handler, a good place for global stuff) :
        sym.globalFunction = function()
          // statements
        To call this function from another symbol :
        sym.getComposition().getStage().globalFunction();
        Here the variable holds a function, but it could hold a number, string, etc.
        Gil
        • 2. Re: how do you create & use global variables in edge animate?
          maulshre Level 1
          thanks for the response and listing various options...
          i'm trying to use your option3 to target cumulative addition of numbers with previous retained value whenever that function is called.
          eg, the statement within my globalFunction() is total=total+x. Here i'm facing two problems:
          Q.1 how to initialize total to 0 without including that in my function else my cumulative total will again get reset whenever the function is called?
          Q.2 Is there any specific format for passing a numeral value (x) in this function?
          • 3. Re: how do you create & use global variables in edge animate?
            Endoplasmic Level 2
            this will get ya done:
            Symbol.bindSymbolAction(compId, symbolName, "creationComplete", function(sym, e) {
                 var total = 0; //this is private
                 sym.globalFunction = function(value){
                      //this is global you can call it by getting an instance of the symbol ie. sym.getSymbol('whatever').globalFunction(5);
                     total += value;
            //Edge binding end
            • 4. Re: how do you create & use global variables in edge animate?
              AMULI Level 4
              For example, if you increment the variable by the number of the clicked instance and display this cumulative count in a text field :
              You must initialize your variable outside of the function.
              Stage.compositionReady event handler :
              total = 0;
              incrementByInstanceNum = function( eClick)
                // console.log( eClick.target.getAttribute("id"));
                // => "Stage_yellowRect1_RoundRect", "Stage_yellowRect2_RoundRect", etc.
                var num = eClick.target.getAttribute("id").substr(16,1);
                total += parseInt( num);
                sym.$("total").html( "total " +total);
              See that thread for explanations about the use of the event objet (eClick here) :
              http://forums.adobe.com/message/5513055#5513055
              Each of the yellowRect<i>.click event handler :
              incrementByInstanceNum( e);
              Downloadable example here : https://app.box.com/s/aiysjhmvx8eb9do60s5u
              Gil
              PS : it's option 2, because there is no need to communicate between symbols,
              as the instances are all in the symbol Stage.
              • 5. Re: how do you create & use global variables in edge animate?
                AMULI Level 4
                For some reason, you may actually need to call the function from inside another symbol (and not from the instances as before). New version of the same exercise with the following structure where each rectangle and the associated text is wrapped in a symbol object<i> :
                To make the function accessible from another symbol, you add sym. (the parameter of substr() is also adapted to the new id)
                total = 0;
                sym.incrementByInstanceNum = function( eClick)
                  // => "Stage_object2_yellowRect2_RoundRect" for example
                  var num = eClick.target.getAttribute("id").substr(12,1);
                Each of the object<i>.yellowRect<i>.click event handler becomes :
                sym.getComposition().getStage().incrementByInstanceNum( e);
                The link given above has been updated and now includes this second version.
                Gil
                • 6. Re: how do you create & use global variables in edge animate?
                  maulshre Level 1
                  Thanks a tonne S. Amuli. Really appreciate your time and effort.
                  • 7. Re: how do you create & use global variables in edge animate?
                    AMULI Level 4
                    You're welcome, Maulshre
                    I remember some time ago when all this made me crazy
                    Gil
                    • 8. Re: how do you create & use global variables in edge animate?
                      maulshre Level 1
                      hee..hee ... i agree... considering i started just one week back...
                      • 9. Re: how do you create & use global variables in edge animate?
                        Xoco Level 3
                        Also you can get/set the values from a textbox (or rectangle element too) hidden or out of Stage:
                        // set or initialise values
                        sym.$("globalVariables").data("globalVariable1",0);
                        sym.$("globalVariables").data("globalVariable2","No");
                        sym.$("globalVariables").data("globalVariable3","red");
                        // get values
                        color = sym.$("globalVariables").data("globalVariable3");
                        Maybe is not elegant but it's simple and works fine.
                        http://www.w3schools.com/jquery/misc_data.asp
