3 Replies Latest reply on Jul 18, 2013 4:22 AM by AMULI
    How to reset timer?
    desziner
      Hello,
      i have a timer that counts down to zero when selected then advances the main timeline.
      I would like it to repeat this action when the button is clicked again but the timer only works once.
      Here is the code:
           var timerCount=4; // This is the variable set for the timer display
           var tCounter=setInterval(timer, 1000); //1000 will run the timer every 1 second
               function timer()
                 timerCount=timerCount-1;
                 if (timerCount <= -1)
                sym.getComposition().getStage().getSymbol("set_1").play();
                    return;
                 sym.getSymbol("timer_sym").$("timer_txt").html(timerCount); // Display the timer value
      Any suggestions?
        • 1. Re: How to reset timer?
          AMULI Level 4
          Hi desziner,
          The code is not sufficient. You should at least explain where it is : in your button.click event handler ?
          You could also make a ZIP of your project available on a service like www.box.com (where you can create a free account) and post the link.
          Gil
          • 2. Re: How to reset timer?
            Zaxist Level 4
            Just add this line at the end of your Code to make it works again
            clearInterval(tCounter);
            Zaxist
            • 3. Re: How to reset timer?
              AMULI Level 4
              1) You could avoid any interval by making the countdown animation in a symbol countdDown.
              Three states => three points in the timeline labelled wait, count and start.
              The stage symbol has its autoplay property set to false, so the headline stops at wait.
              goBtn.click event handler : sym.stop('count');
              The countDown symbol alos has its autoplay property set to false. A play command is inserted at count (see the arrow on white rectangle in the screen shot).
              At the end of the animation, in the symbol's timeline there is a trigger to start the main animation :
              sym.getParentSymbol().play('start');
              againBtn.click event handler : sym.stop('wait');
              2) With an interval, modifying the timing is just a matter of changing values in the code (in the first case you would have to edit the countdDown timeline).
              The structure remains, with the same three states.
              There is now a trigger at count in the main timeline (see the orange diamond in the screen shot). As Zaxist says, clear your interval when finished :
              timerCount = 5;
              sym.$("counter_txt").html( timerCount);
              tCounter = setInterval( timer, 1000);
              function timer()
                timerCount -= 1;
                if (timerCount < 1)
                  sym.play('start');
                  clearInterval( tCounter);
                  return;
              Downloadable examples here : https://app.box.com/s/cmjmr01802p8k1tgcmhk
              Gil
