6 Replies Latest reply on Jul 29, 2013 9:29 AM by ctsuttle1908
    Help with buttons and timing
    ctsuttle1908 Level 1
      I have four buttons, each with an advanced action.  Only the first one works.  I know it's related to the button timing, but I can't figure out how to fix it.
        • 1. Re: Help with buttons and timing
          Hi there
          Can you please show us a screen shot of your timeline?
          Cheers... Rick
          • 3. Re: Help with buttons and timing
            The four buttons at the top have advanced actions to show a caption for 2 seconds.  The Michael_Next button to the bottom is the Next button that advances the screen.  The two clickboxes at the bottom are yes and no buttons that are like a quiz that appears are attached to an advanced action so they will appear when all four buttons (at the top) have been clicked.  But they won't work either.  Help!
            • 4. Re: Help with buttons and timing
              Wow, lots of objects on this slide!
              So I see at five seconds the first pause occurs. Another at seven, again at nine and the last one at 11.5. One might expect the playhead to be released at the five second mark when the button is clicked. But I think Advanced actions may keep it paused.
              Unfortuantely in this case it would seem a simple view of the timeline won't be sufficient as you have Advanced Actions happening too. So either we need to see a capture of what the Advanced actions are doing as well, or just have access to see the project first hand.
              Cheers... Rick
              • 5. Re: Help with buttons and timing
                RodWard Adobe Community Professional & MVP
                Let's try some troubleshooting 101.  Remove the complexity to isolate the issue.
                Try setting each button just to have a Continue action again and test. This will show whether the problem is with the buttons or with the Advanced Actions you've assigned to them.
                If the buttons work fine with Continue actions, try dragging your first button off the stage area into the scrap area and then test the slide again.  If the button that is first in line NOW works, but others don't, then I would look at these advanced actions carefully because there may be something in the logic that is fouling things up.
                For example, standard actions do not release the playhead unless you also add an extra Continue action line, whereas Conditional Actions do not require this same Continue action.
                Rod Ward
                http://www.infosemantics.com.au/troubleshoot-adobe-captivate
                • 6. Re: Help with buttons and timing
                  How would I be able to give you viewing access to the file?
