1. Re: Mouse flickering on top of brush point in Photoshop CS4...
Chris CoxJul 17, 2013 2:00 PM (in response to JZais)
1 person found this helpfulWhat OS version?
What changed on your system since it was working correctly?
2. Re: Mouse flickering on top of brush point in Photoshop CS4...
JZais Jul 17, 2013 2:12 PM (in response to Chris Cox)Mac OSX 10.8.4
I really can't think of anything that has changed. I've just been using Photoshop the way I usually use it. I wish I could think of an easy fix! It strange because I don't even know where brush point is going to start working when I click because the arrow will sometimes flicker on top of the brush point and then sometimes an inch or more away from where the invisible brush is. I wish I could explain it more clearly. I tried to take a screenshot but arrows dissapear in screenshots. : S
Thank you for trying to help!
3. Re: Mouse flickering on top of brush point in Photoshop CS4...
Chris CoxJul 17, 2013 3:19 PM (in response to JZais)
1 person found this helpfulSo something is causing the cursor to change outside of Photoshop's control.
Are you using a wacom tablet?
Do you have any system utilities installed that might modify or otherwise mess with the cursor?
4. Re: Mouse flickering on top of brush point in Photoshop CS4...
JZais Jul 17, 2013 3:56 PM (in response to Chris Cox)I'm not using a wacom tablet. I don't have any system utilities that I can think of that would mess with the cursor. Sorry - I wish I could give you more to go on!
5. Re: Mouse flickering on top of brush point in Photoshop CS4...
Chris CoxJul 17, 2013 6:24 PM (in response to JZais)
Well, something other than Photoshop is changing the cursor and moving the cursor hotspot -- but only on your system.
6. Re: Mouse flickering on top of brush point in Photoshop CS4...
station_two Jul 17, 2013 7:29 PM (in response to JZais)Have you tried a different mouse?
7. Re: Mouse flickering on top of brush point in Photoshop CS4...
JZais Jul 18, 2013 2:26 PM (in response to Chris Cox)Thanks for trying to help Chris! It's strange; I restarted my computer again (I had tried a couple times before) and for some reason this time it fixed the problem! Hopefully it doesn't happen again. I appreciate your input!
8. Re: Mouse flickering on top of brush point in Photoshop CS4...
JZais Jul 18, 2013 2:27 PM (in response to JZais)Yes I did but thanks for the suggestion! I ended up restarting my computer again (I had tried a couple times before) and for some reason this time it fixed the problem! Hopefully it doesn't happen again. I appreciate your input!
