10 Replies Latest reply on Oct 11, 2013 4:12 PM by Noel Carboni
    Photoshop CC transparency issues with gradients
    HnerraD
      I found an issue with how Photoshop CC is dealing with gradients and other soft edge transitions on a transparent background with Adobe RGB.
      I made a new document, 2"x2" at 300 ppi and Adobe RGB, added a new layer, used a black to transparent gradient across the document, and made sure the background layer was turned off.
      In CS6 I get a nice smooth transition, but in CC there is an abrupt and ugly transition. If I turn a white background layer on gradient looks nearly identical other than CC showing slightly worse banding. Changing the color mode to CMYK produces a smooth gradient on both. Soft brushes produce the same effect. I noticed it when using a soft brush on a mask.
      All settings are the same and I have checked the results on two co-worker computers (all 3 are Mac Pros) with the same outcome.
      has anybody else experienced this? Known Bug? Fix?
      CC is on left CS6 on right
      Darren
