• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Skins
Explorer ,
Jul 18, 2013 Jul 18, 2013
This question was posted in response to the following article: http://help.adobe.com/en_US/robohelp/robohtml/WS154224F0-4F34-40e4-82E2-D21D52E45CE9.html
Views
714
Translate
Translate
Report
Report
Community guidelines
community guidelines
New Here ,
I don't see where the window selection comes in. There's Skin, Layout, but no way to assign a customized window to a Webhelp project. (Long, long bulleted lists are hard to read and do not make good help, BTW)
Votes
Translate
Translate
Report
Report
LEGEND ,
Votes
Translate
Translate
Report
Report
New Here ,
Jul 22, 2013 Jul 22, 2013
Create a new skin from the Project set up pod.  Name the skin.  To generate web help file navigate to the Single source layout pod and right click WebHelp.  Select properties. Navigate to Navigation option from the WebHelp Settings dialog.  Click Skin selection drop down list from the right panel and select the skin name that you had created.
Soni
Votes
Translate
Translate
Report
Report
New Here ,
Create a skin and then name the skin. Right click Web Help from the Single Source Layout. Select Properties. In the Web Help Settings dialog, navigate to the Navigation option. Click the Skin selection drop down list from the right pane and select the skin name. The skin that you had created.
Votes
Translate
Translate
Report
Report
New Here ,
Aug 15, 2013 Aug 15, 2013
How do we apply skins to the .chm help files (MHTML output)? I read RH 10 version could do that but it doesn't seem so. I tried that nor is it mentioned in the help.
Votes
Translate
Translate
Report
Report
LEGEND ,
Hi there
To apply a skin you need to first generate WebHelp with the skin you want. Once you do that, open the Script Explorer pod and you should find a script named WebHelp to CHM Converter. Run that.
Cheers... Rick
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
Thanks a lot Rick. It wasn’t very obvious as such. I then got to watch a video on Adobe TV, which helped a lot. Thanks again for your quick response.
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
