At home, I am using ColdFusion Builder 1.0
When I have a file open and press ctl+shift+O, it outputs this
<cfoutput></cfoutput> or writeOutput();
When I have a file open and press ctl+shift+a, it outputs this:
<cfabort> or abort:
When I have a file open and press ctl+shift+d, it outputs this:
<cfdump var=""> or writeDump():
At work, I am using ColdFusion Builder 2.0.1. None of "features" described above work. I want to get them to work. What are the features called? Shortcuts? Do I need to download and install them separately? I have searched everywhere to find out how to make this happen and have had no luck. Please advise.
With a file open, press Command-T and you'll get a pop-up of the available shortcuts - for example:
Command-T-A will do your abort
Command-T-O will do your ouput
Command-T-D will do your dump
Hope that helps you.
