12 Replies Latest reply on Aug 26, 2013 5:01 AM by tenorphoto
    Adobe Extension Manager CC doesn't work at all
    Robin Savas Savvidis
      Hello,
      I updated yesterday my Creative Suite from CS6 to CC.
      Everything works fine except the Extension Manager.
      Every time I start the App the small is working for ever ..
      Only when I klick in the Menu "About Extension Manager" it will stop and the following window will show up.
      Pay attention on Version: null
      I live in Germany so use the German Version: "null" means "zero"
      When I quit the App then Extension Manager is crashing.
      What can I do?
      Thank you so much for your help.
      Robin
      P.S. Extension Manager CS6 works fine.
        • 1. Re: Adobe Extension Manager CC doesn't work at all
          BillClag Level 1
          You can try downloading and installing Extension manager from here.  That fixed it for me:
          http://www.adobe.com/exchange/em_download/
          • 2. Re: Adobe Extension Manager CC doesn't work at all
            Robin Savas Savvidis Level 1
            Hey BillClag,
            unfortunately this didn't help me. Still thank you for your reply.
            • 3. Re: Adobe Extension Manager CC doesn't work at all
              Carl Sun Level 4
              Hi Robin,
              Please create a file named as ExManCoreLibLog.YES in "/Users/<UsreName>/Library/Application Support/Adobe/Extension Manager CC/Log" folder and a file named as ExManLog.YES in "/Applications/Adobe Extension Manager CC/Adobe Extension Manager CC.app/Contents/MacOS" folder. Ensure there is no hidden file extension after ".YES". Then start up Extension Manager CC. After it hangs, kill it. Send all the log files in "/Users/<UsreName>/Library/Application Support/Adobe/Extension Manager CC/Log" folder to exman.beijing@gmail.com. Thanks!
              • 4. Re: Adobe Extension Manager CC doesn't work at all
                Thank you Carl for you reply and excuse me for me delayed answer. I followed your advice .. I suppose I will get an answer via mail?
                Best regards Robin
                • 5. Re: Adobe Extension Manager CC doesn't work at all
                  Carl Sun Level 4
                  I suppose there should be three log files generated in the log folder: ExManCoreLibrary.log, ExtensionManager.log and log0.log (order from the most important to the least important). Unfortunately, you only sent me log0.log. I can't figure out the root cuase with only this file.
                  • 6. Re: Adobe Extension Manager CC doesn't work at all
                    I am sorry Carl, unfortunately only this file is to find in the folder. I repeated the process but still ... Would it help to send you the "crash report" that shows up after I kill the App?
                    • 7. Re: Adobe Extension Manager CC doesn't work at all
                      Carl Sun Level 4
                      Are you sure you have created ExManCoreLibLog.YES and it has no hidden extension (check it with "Get Info" in Finder)? Please try again. If it still doesn't work, please send crash report.
                      • 8. Re: Adobe Extension Manager CC doesn't work at all
                        Hey Carl, yes I am. I tried it 3 times and checked the extension after.YES .. Still only one file is created every time :-/ The update of Extension Manager last week had no impact. I did send you the crash report. I have no idea what to do.  Thank you, Robin
                        • 9. Re: Adobe Extension Manager CC doesn't work at all
                          tenorphoto Level 1
                          Did you ever get a fix for this issue? As I am having exactly the same problem with Extension Manager CC.
                          • 10. Re: Adobe Extension Manager CC doesn't work at all
                            Yuanyuan Liu Level 1
                            Hi tenorphoto,
                            Please check whether you have write permission to "/Library/Application Support/Adobe/Extension Manager CC/Configuration/DB" folder. If not, please grant youself permission then try to launch Extension Manager. If yes, please send the database file  ExMan.db in this folder to me and follow the steps below:
                            1. Rename all the CC product folders temporarily so that Extension Manager will not find them. e.g., rename "/Applications/Adobe Photoshop CC" to "/Application/Adobe Photoshop CC Bak".
                            2. Launch Extension Manager CC.
                            3. If it can be launched successfully, restore one CC product folder name then restart Extension Manager CC.
                            4. If it can be launched successfully, restore the next CC product folder name then restart Extension Manager CC, until Extension Manager CC hangs again. In this way you will find which product caused this problem.
                            5. Rename this product folder name again then repeat step 4. You will find all CC products which are related to this problem.
                            Tell me the result then we can take the next step.
                            • 11. Re: Adobe Extension Manager CC doesn't work at all
                              tenorphoto Level 1
                              Hi Yuanyuan,
                              I have given write permission to my user account but it still does not allow Extension Manager CC to launch under my user account other than the Admin account and any extensions installed under that account do not appear avaiable or installed in Dreamweaver when i launch it under my user account.
                              How do I send you the file you requested above?
                              I will try the steps you list above now and let you know what results I get.
                              Thanks for your help.
                              • 12. Re: Adobe Extension Manager CC doesn't work at all
                                tenorphoto Level 1
                                Hi YuanYuan,
                                I did the steps above but it has made no difference at all. Extension Manager CC crashed as soon as I launched it under my user account and gave the following error report: I hope that helps.
                                Process:         Adobe Extension Manager CC [566]
                                Path:            /Applications/Adobe Extension Manager CC/Adobe Extension Manager CC.app/Contents/MacOS/Adobe Extension Manager CC
                                Identifier:      com.adobe.ExtensionManager
                                Version:         7.0.1.17 (7.0.1.17)
                                Code Type:       X86 (Native)
                                Parent Process:  launchd [356]
                                User ID:         502
                                Date/Time:       2013-08-26 12:58:35.977 +0100
                                OS Version:      Mac OS X 10.8.4 (12E55)
                                Report Version:  10
                                Interval Since Last Report:          132547 sec
                                Crashes Since Last Report:           4
                                Per-App Interval Since Last Report:  4871 sec
                                Per-App Crashes Since Last Report:   2
                                Anonymous UUID:                      189E1B0D-CBD2-D296-CD8C-15232A3FFEB5
                                Crashed Thread:  0  Dispatch queue: com.apple.main-thread
                                Exception Type:  EXC_BAD_ACCESS (SIGBUS)
                                Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
                                VM Regions Near 0:
                                --> __PAGEZERO             0000000000000000-0000000000001000 [    4K] ---/--- SM=NUL  /Applications/Adobe Extension Manager CC/Adobe Extension Manager CC.app/Contents/MacOS/Adobe Extension Manager CC
                                    __TEXT                 0000000000001000-00000000000d8000 [  860K] r-x/rwx SM=COW  /Applications/Adobe Extension Manager CC/Adobe Extension Manager CC.app/Contents/MacOS/Adobe Extension Manager CC
                                Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
                                0   ???                                     0000000000 0 + 0
                                1   com.adobe.ape.engine                    0x063dee8d APXGetHostAPI + 3708637
                                2   com.adobe.ape.engine                    0x064913e9 APXGetHostAPI + 4439097
                                3   com.adobe.ape.engine                    0x0649c246 APXGetHostAPI + 4483734
                                4   com.adobe.ape.engine                    0x0649c8b4 APXGetHostAPI + 4485380
                                5   com.adobe.ape.engine                    0x064f0888 SWFLPlayer_Initialize + 9960
                                6   com.apple.CoreFoundation                0x9284204f __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 15
                                7   com.apple.CoreFoundation                0x92841a79 __CFRunLoopDoSources0 + 233
                                8   com.apple.CoreFoundation                0x92867826 __CFRunLoopRun + 934
                                9   com.apple.CoreFoundation                0x9286701a CFRunLoopRunSpecific + 378
                                10  com.apple.CoreFoundation                0x92866e8b CFRunLoopRunInMode + 123
                                11  com.apple.HIToolbox                     0x90316f5a RunCurrentEventLoopInMode + 242
                                12  com.apple.HIToolbox                     0x90316cc9 ReceiveNextEventCommon + 374
                                13  com.apple.HIToolbox                     0x90316b44 BlockUntilNextEventMatchingListInMode + 88
                                14  com.apple.AppKit                        0x92dd793a _DPSNextEvent + 724
                                15  com.apple.AppKit                        0x92dd716c -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 119
                                16  com.apple.AppKit                        0x92dcd5cc -[NSApplication run] + 855
                                17  com.apple.AppKit                        0x92d705f6 NSApplicationMain + 1053
                                18  com.adobe.ExtensionManager              0x0004ef7b main + 1193
                                19  com.adobe.ExtensionManager              0x000025c5 start + 53
                                Thread 1:
                                0   libsystem_kernel.dylib                  0x96f6c0ee __workq_kernreturn + 10
                                1   libsystem_c.dylib                       0x99fe60ac _pthread_workq_return + 45
                                2   libsystem_c.dylib                       0x99fe5e79 _pthread_wqthread + 448
                                3   libsystem_c.dylib                       0x99fcdd2a start_wqthread + 30
                                Thread 2:: Dispatch queue: com.apple.libdispatch-manager
                                0   libsystem_kernel.dylib                  0x96f6c9ae kevent + 10
                                1   libdispatch.dylib                       0x9490ec71 _dispatch_mgr_invoke + 993
                                2   libdispatch.dylib                       0x9490e7a9 _dispatch_mgr_thread + 53
                                Thread 3:
                                Thread 4:
                                Thread 5:
                                Thread 6:
                                0   libsystem_kernel.dylib                  0x96f698e6 mach_wait_until + 10
                                1   libsystem_c.dylib                       0x9a074c10 nanosleep + 375
                                2   com.adobe.ExtensionManager              0x00083c09 ScObjects::Thread::sleep(unsigned int) + 143
                                3   com.adobe.ExtensionManager              0x00083c69 ScObjects::Thread::wait(unsigned int) + 23
                                4   com.adobe.ExtensionManager              0x0007b4b6 ScObjects::BridgeTalkThread::run() + 332
                                5   com.adobe.ExtensionManager              0x0008408f ScObjects::Thread::go(void*) + 239
                                6   libsystem_c.dylib                       0x99fe35b7 _pthread_start + 344
                                7   libsystem_c.dylib                       0x99fcdd4e thread_start + 34
                                Thread 7:
                                0   libsystem_kernel.dylib                  0x96f6b8e2 __psynch_cvwait + 10
                                1   libsystem_c.dylib                       0x99fe8280 _pthread_cond_wait + 833
                                2   libsystem_c.dylib                       0x9a06e095 pthread_cond_wait$UNIX2003 + 71
                                3   com.adobe.ape.engine                    0x062d889f APXGetHostAPI + 2633967
                                4   com.adobe.ape.engine                    0x06069d9f APXGetHostAPI + 83439
                                5   com.adobe.ape.engine                    0x062d898e APXGetHostAPI + 2634206
                                6   com.adobe.ape.engine                    0x062d89f7 APXGetHostAPI + 2634311
                                7   com.adobe.ape.engine                    0x062d8b16 APXGetHostAPI + 2634598
                                8   libsystem_c.dylib                       0x99fe35b7 _pthread_start + 344
                                9   libsystem_c.dylib                       0x99fcdd4e thread_start + 34
                                Thread 8:
                                Thread 9:
                                0   libsystem_kernel.dylib                  0x96f697d2 mach_msg_trap + 10
                                1   libsystem_kernel.dylib                  0x96f68cb0 mach_msg + 68
                                2   com.apple.CoreFoundation                0x92861f79 __CFRunLoopServiceMachPort + 185
                                3   com.apple.CoreFoundation                0x9286795f __CFRunLoopRun + 1247
                                4   com.apple.CoreFoundation                0x9286701a CFRunLoopRunSpecific + 378
                                5   com.apple.CoreFoundation                0x92876ab1 CFRunLoopRun + 129
                                6   com.apple.DVCPROHDMuxer                 0x095cb98f AVS::DestroyAVCDeviceController(AVS::AVCDeviceController*) + 317
                                7   libsystem_c.dylib                       0x99fe35b7 _pthread_start + 344
                                8   libsystem_c.dylib                       0x99fcdd4e thread_start + 34
                                Thread 10:
                                1   libsystem_c.dylib                       0x99fe82e9 _pthread_cond_wait + 938
                                2   libsystem_c.dylib                       0x99fe8572 pthread_cond_timedwait_relative_np + 47
                                3   com.adobe.ape.engine                    0x062d8867 APXGetHostAPI + 2633911
                                4   com.adobe.ape.engine                    0x062f1a5e APXGetHostAPI + 2736814
                                Thread 11:
                                4   com.adobe.ape.engine                    0x06467028 APXGetHostAPI + 4266104
                                Thread 12:
                                0   libExManCoreLib.dylib                   0x001fc870 std::_Rb_tree<std::string, std::string, std::_Identity<std::string>, std::less<std::string>, std::allocator<std::string> >::~_Rb_tree() + 0
                                1   libExManCoreLib.dylib                   0x00810610 Poco::TempFileCollector::~TempFileCollector() + 126
                                2   libExManCoreLib.dylib                   0x0081017e __tcf_0 + 26
                                3   libsystem_c.dylib                       0x9a01debf __cxa_finalize + 184
                                4   libsystem_c.dylib                       0x9a020db9 exit + 23
                                5   libExManCoreLib.dylib                   0x0065cbe9 OPENSSL_config + 153
                                6   libExManCoreLib.dylib                   0x002f0553 ADOBE_EXMAN::SSLInitializer::SSLInitializer() + 35
                                7   libExManCoreLib.dylib                   0x002f0527 ADOBE_EXMAN::SSLInitializer::SSLInitializer() + 23
                                8   libExManCoreLib.dylib                   0x002310cb ADOBE_EXMAN::CExtensionManager::CExtensionManager() + 747
                                9   libExManCoreLib.dylib                   0x00230dd7 ADOBE_EXMAN::CExtensionManager::CExtensionManager() + 23
                                10  libExManCoreLib.dylib                   0x00231bc0 ADOBE_EXMAN::CExtensionManager::getInstance() + 64
                                11  libExManCoreLib.dylib                   0x001e5d32 ExManInit + 82
                                12  com.adobe.ExtensionManager              0x00055f55 CInitCoreLibCommand::execute() + 579
                                13  com.adobe.ExtensionManager              0x00052d6c CommandExecutor_Impl::run() + 144
                                14  com.adobe.ExtensionManager              0x00052c69 CommandExecutor_Impl::runHelper(void*) + 69
                                15  libsystem_c.dylib                       0x99fe35b7 _pthread_start + 344
                                16  libsystem_c.dylib                       0x99fcdd4e thread_start + 34
                                Thread 0 crashed with X86 Thread State (32-bit):
                                  eax: 0x06f849e8  ebx: 0x063dee71  ecx: 0xbfffda64  edx: 0x00004b00
                                  edi: 0x00000000  esi: 0x0709ac00  ebp: 0xbfffdaa8  esp: 0xbfffda4c
                                   ss: 0x00000023  efl: 0x00210286  eip: 0x00000000   cs: 0x0000001b
                                   ds: 0x00000023   es: 0x00000023   fs: 0x00000000   gs: 0x0000000f
                                  cr2: 0x00000000
                                Logical CPU: 0
                                Binary Images:
                                    0x1000 -    0xd7ff7 +com.adobe.ExtensionManager (7.0.1.17 - 7.0.1.17) <674354AE-B7BA-3CB4-BD1E-CD94A19483BC> /Applications/Adobe Extension Manager CC/Adobe Extension Manager CC.app/Contents/MacOS/Adobe Extension Manager CC
                                  0x125000 -   0x127fff +com.adobe.AdobeCrashReporter (7.0 - 7.0.1) <940AF5C8-23AA-3311-A69F-6FC43C80F05B> /Applications/Adobe Extension Manager CC/Adobe Extension Manager CC.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
                                  0x12d000 -   0x144fff +VulcanMessage4.dylib (4.0.0.101 - 4.0.0.101 © 2013 Adobe Systems, Inc. All rights reserved.) <110A0C05-61A2-ABE9-FCF8-99CD2DEE26C3> /Applications/Adobe Extension Manager CC/Adobe Extension Manager CC.app/Contents/Frameworks/VulcanMessage4.dylib
                                  0x166000 -   0x16dffb +com.adobe.ape.shim (3.4.0.29366 - 3.4.0.29366) <97387687-C9B4-76C5-FD95-8D4419271592> /Applications/Adobe Extension Manager CC/Adobe Extension Manager CC.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
                                  0x176000 -   0x1dbffb +com.adobe.adobe_caps (adobe_caps 7.0.0.21 - 7.0.0.21) <A3A3E3BA-98D5-34FD-A1CC-AF9999C3A1F6> /Applications/Adobe Extension Manager CC/Adobe Extension Manager CC.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
                                  0x1e4000 -   0xbb1fff +libExManCoreLib.dylib (0) <D77E9315-9610-3DD3-A97E-A14F59A06873> /Applications/Adobe Extension Manager CC/Adobe Extension Manager CC.app/Contents/Frameworks/libExManCoreLib.dylib
                                0x116f000 -  0x11befe3 +com.adobe.headlights.LogSessionFramework (2.1.2.1756) <783979BC-67DD-3702-BCCC-EA29C2828962> /Applications/Adobe Extension Manager CC/Adobe Extension Manager CC.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
                                0x11f2000 -  0x1223ff7 +com.adobe.pip (7.0.0.1768) <863344FC-040D-30CD-8D0C-22DE00F1C11B> /Applications/Adobe Extension Manager CC/Adobe Extension Manager CC.app/Contents/Frameworks/AdobePIP.framework/Versions/A/AdobePIP
                                0x122e000 -  0x1306fff +IMSLib.dylib (7.0.0.37 - 7.0.0.37) <9CC26669-4BB6-3082-B450-D98A49ED6911> /Applications/Adobe Extension Manager CC/Adobe Extension Manager CC.app/Contents/Frameworks/IMSLib.dylib
                                0x13d7000 -  0x13e4ff3  com.apple.Librarian (1.1 - 1) <68F8F983-5F16-3BA5-BDA7-1A5451CC02BB> /System/Library/PrivateFrameworks/Librarian.framework/Versions/A/Librarian
                                0x5fb2000 -  0x6006fef +com.adobe.ape (3.4.0.29366 - 3.4.0.29366) <FEA983C9-2221-4A47-D3E2-95DEA682B378> /Library/Application Support/Adobe/*/adbeapecore.framework/adbeapecore
                                0x6020000 -  0x6f68ff3 +com.adobe.ape.engine (3.4.0.29366 - 3.4.0.29366) <35BD8121-4596-CA6E-194B-FCE0D0635448> /Library/Application Support/Adobe/*/adbeapecore.framework/Libraries/adbeapeengine.bundle/Contents/MacOS/adbea peengine
                                0x7164000 -  0x720ffff  libcrypto.0.9.7.dylib (106) <041B3399-5033-3395-9A71-6693F3A33D94> /usr/lib/libcrypto.0.9.7.dylib
                                0x7565000 -  0x756afff  com.apple.audio.AppleHDAHALPlugIn (2.3.7 - 2.3.7fc4) <903097A8-3922-3BF8-8B82-8BD1D831F6E7> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
                                0x9540000 -  0x9595fe2  com.apple.DVCPROHDAudio (1.3.2 - 1.3.2) <A9248133-6EB0-2702-A9B8-71C67BE55FD4> /Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin/Contents/MacOS/DVCPROHDAudio
                                0x95b4000 -  0x9619fe0  com.apple.DVCPROHDMuxer (1.3.2 - 1.3.2) <C1AA540F-CEAD-77BA-1CD6-0D467B4F76FF> /Library/QuickTime/DVCPROHDMuxer.component/Contents/MacOS/DVCPROHDMuxer
                                0x9ec8000 -  0x9f86ff3  ColorSyncDeprecated.dylib (400) <35E3054C-5DF1-30D4-A368-C4FDB0992373> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/Resources/ColorSyncDeprecated.dylib
                                0xa00b000 -  0xa019fff  libSimplifiedChineseConverter.dylib (61) <60899F9C-A79F-3BC2-855E-DC5C78B98FEB> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
                                0xa01d000 -  0xa02fffd  libTraditionalChineseConverter.dylib (61) <519CAA3F-715E-3CAE-B158-57EC95D916B1> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
                                0xb4aa000 -  0xba29fe7 +Webkit.dylib (1) <5E61F610-AA01-BA06-32C0-0460F80E6EF5> /Library/Application Support/Adobe/*/adbeapecore.framework/Versions/A/Libraries/Webkit.dylib
                                0x8fe66000 - 0x8fe98e57  dyld (210.2.3) <4D38DEED-9837-3202-B8E9-41272D01EA2C> /usr/lib/dyld
                                0x90007000 - 0x90062ff7  com.apple.AppleVAFramework (5.0.19 - 5.0.19) <3C43A555-0A22-3D7C-A3FB-CFADDDA43E9B> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
                                0x90063000 - 0x9027afff  com.apple.CoreData (106.1 - 407.7) <EC4B8297-8E01-3778-A8A4-E8747F91109D> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
                                0x9027b000 - 0x9027bfff  libkeymgr.dylib (25) <D5E93F7F-9315-3AD6-92C7-941F7B54C490> /usr/lib/system/libkeymgr.dylib
                                0x9027c000 - 0x902beffb  com.apple.RemoteViewServices (2.0 - 80.6) <AE962502-4539-3893-A2EB-9D384652AEAC> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
                                0x902bf000 - 0x906a2fff  com.apple.HIToolbox (2.0 - 626.1) <ECC3F04F-C4B7-35BF-B10E-183B749DAB92> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                                0x906a3000 - 0x906c8ffb  com.apple.framework.familycontrols (4.1 - 410) <B1755756-BEA2-3205-ADAA-68FCC32E60BD> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
                                0x906c9000 - 0x906c9fff  com.apple.quartzframework (1.5 - 1.5) <9018BE5B-4070-320E-8091-6584CC17F798> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
                                0x90722000 - 0x90729fff  liblaunch.dylib (442.26.2) <310C99F8-0811-314D-9BB9-D0ED6DFA024B> /usr/lib/system/liblaunch.dylib
                                0x9072a000 - 0x90774ff7  com.apple.framework.CoreWLAN (3.3 - 330.15) <74C4B50F-7016-341F-8261-D379B8F0CC97> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
                                0x90775000 - 0x907ddfe7  libvDSP.dylib (380.6) <55780308-4DCA-3B10-9703-EAFC3E13A3FA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
                                0x90a79000 - 0x90a97ff3  com.apple.openscripting (1.3.6 - 148.3) <F3422C02-5ACB-343A-987B-A2D58EA2F5A8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
                                0x90a98000 - 0x90cc8fff  com.apple.QuartzComposer (5.1 - 284) <4E8682B7-EBAE-3C40-ABDB-8705EC7952BD> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
                                0x90d4c000 - 0x90d69fff  libCRFSuite.dylib (33) <C9D72D0C-871A-39A2-8AFB-682D11AE7D0D> /usr/lib/libCRFSuite.dylib
                                0x90d6a000 - 0x90da0ffb  com.apple.DebugSymbols (98 - 98) <9A9ADA0A-E487-3C8F-9998-286EE04C235A> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
                                0x90da1000 - 0x9142dff3  com.apple.CoreAUC (6.16.13 - 6.16.13) <3DCF4456-AF8D-3E87-B00C-C56055AF9B8E> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
                                0x9142e000 - 0x9146dff7  com.apple.bom (12.0 - 192) <0637E52C-D151-37B3-904F-8656B2FD44DD> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
                                0x9146e000 - 0x914b5ff7  com.apple.framework.CoreWiFi (1.3 - 130.13) <1961CC70-C00D-31DE-BAB5-A077538CD5CB> /System/Library/Frameworks/CoreWiFi.framework/Versions/A/CoreWiFi
                                0x914b6000 - 0x9156afff  com.apple.coreui (2.0 - 181.1) <C15ABF35-B7F5-34ED-A461-386DAF65D96B> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
                                0x9156b000 - 0x916e3ff5  com.apple.QuartzCore (1.8 - 304.3) <F2EFC117-CDC6-3252-A4A8-880965764385> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
                                0x916e4000 - 0x916fafff  com.apple.CFOpenDirectory (10.8 - 151.10) <CDA91E5D-6F99-3001-BD31-82585FCF5CA2> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
                                0x916fb000 - 0x918b7ffd  libicucore.A.dylib (491.11.3) <FF55E176-7D66-3DBB-AF86-84744C47A02C> /usr/lib/libicucore.A.dylib
                                0x92139000 - 0x921aeff7  com.apple.ApplicationServices.ATS (332 - 341.1) <BEE998BC-E4A5-3BA0-A6B5-31A1DFA1522C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
                                0x921af000 - 0x9245dffb  com.apple.MediaToolbox (1.0 - 926.104) <DD264DFD-9AFB-38E2-A44C-B463DCB721A0> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
                                0x9245e000 - 0x92489ff9  com.apple.framework.Apple80211 (8.4 - 840.22.1) <DBC31BEB-B771-315F-852D-66ADC3BD75A1> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
                                0x9248b000 - 0x9249dfff  libbsm.0.dylib (32) <DADD385E-FE53-3458-94FB-E316A6345108> /usr/lib/libbsm.0.dylib
                                0x9249e000 - 0x9270bffb  com.apple.imageKit (2.2 - 673) <CDB2AC11-6D60-34A7-83F9-F6E7DA25F97B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
                                0x9270c000 - 0x92731ff7  com.apple.quartzfilters (1.8.0 - 1.7.0) <F6A88D89-AB4A-3217-9D65-C2C259B5F09B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
                                0x92732000 - 0x9273cfff  libsystem_notify.dylib (98.5) <7EEE9475-18F8-3099-B0ED-23A3E528ABE0> /usr/lib/system/libsystem_notify.dylib
                                0x9273d000 - 0x927b7ff7  com.apple.securityfoundation (6.0 - 55115.4) <4843FAEA-8161-34B3-A1F1-720154884E34> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
                                0x927b8000 - 0x927b9fff  libsystem_sandbox.dylib (220.3) <C532F6A6-7E85-38F3-8660-EC1066DF67BE> /usr/lib/system/libsystem_sandbox.dylib
                                0x927ba000 - 0x927c6ffe  libkxld.dylib (2050.24.15) <BEC097B0-9D9A-3484-99DB-0F537E71963E> /usr/lib/system/libkxld.dylib
                                0x927d5000 - 0x9282ffff  com.apple.Symbolication (1.3 - 93) <227F64A9-FC28-3680-BE92-FFAE86FD4866> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
                                0x92830000 - 0x92a18ffb  com.apple.CoreFoundation (6.8 - 744.19) <DDD3AA21-5B5F-3D8F-B137-AD95FCA89064> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                                0x92ab7000 - 0x92ae6ff7  com.apple.securityinterface (6.0 - 55024.4) <7C5E28DC-F8BE-3238-883F-E1646A2AF895> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
                                0x92ae7000 - 0x92af1ffe  com.apple.bsd.ServiceManagement (2.0 - 2.0) <9732BA61-D6F6-3644-82DA-FF0D6FEEFC69> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
                                0x92af2000 - 0x92af4fff  libdyld.dylib (210.2.3) <05D6FF2A-F09B-309D-95F7-7AF10259C707> /usr/lib/system/libdyld.dylib
                                0x92af5000 - 0x92af6fff  libquarantine.dylib (52.1) <094A1501-373E-3397-B632-8F7C5AC8EFD5> /usr/lib/system/libquarantine.dylib
                                0x92af7000 - 0x92b1cff7  com.apple.CoreVideo (1.8 - 99.4) <A26DE896-32E0-3D5E-BA89-02AD23FA96B3> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
                                0x92b7b000 - 0x92b7eff3  com.apple.AppleSystemInfo (2.0 - 2) <4639D755-8A68-31C9-95C4-7E7F70C233FA> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
                                0x92b7f000 - 0x92b86ffb  libunwind.dylib (35.1) <E1E8D8B3-3C78-3AB1-B398-C180DC6DCF05> /usr/lib/system/libunwind.dylib
                                0x92bee000 - 0x92c03fff  com.apple.ImageCapture (8.0 - 8.0) <B8BD421F-D5A9-3FB4-8E89-AD5CFC0D4030> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
                                0x92c04000 - 0x92c2dff7  libRIP.A.dylib (332) <521E60A6-A768-3CB8-B10D-D10EECD68A94> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
                                0x92c2e000 - 0x92c2efff  com.apple.Accelerate.vecLib (3.8 - vecLib 3.8) <908B8D40-3FB5-3047-B482-3DF95025ECFC> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
                                0x92c2f000 - 0x92c37fff  libcopyfile.dylib (89) <4963541B-0254-371B-B29A-B6806888949B> /usr/lib/system/libcopyfile.dylib
                                0x92c38000 - 0x92c3cfff  com.apple.IOSurface (86.0.4 - 86.0.4) <6431ACB6-561B-314F-9A2A-FAC1578FCC86> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
                                0x92c3d000 - 0x92c46ffd  com.apple.audio.SoundManager (4.0 - 4.0) <ABC5FE40-B222-36EB-9905-5C8C4BFD8C87> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/V ersions/A/CarbonSound
                                0x92c47000 - 0x92c73ff7  libsystem_info.dylib (406.17) <AA5611DB-A944-3072-B6BE-ACAB08689547> /usr/lib/system/libsystem_info.dylib
                                0x92c74000 - 0x93830ff3  com.apple.AppKit (6.8 - 1187.39) <ACA24416-D910-39B8-9387-52A6C6A561F8> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                                0x93831000 - 0x938acff3  com.apple.CorePDF (2.2 - 2.2) <5A52A1CF-4801-3E6C-BF6E-E5E75A8DBD8F> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
                                0x938ad000 - 0x93996ff7  libxml2.2.dylib (22.3) <015A4FA6-5BB9-3F95-AFB8-B9281E22685B> /usr/lib/libxml2.2.dylib
                                0x93997000 - 0x93a46ff7  com.apple.CoreText (260.0 - 275.16) <873ADCD9-D361-3753-A220-CDD289196AD8> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
                                0x93a47000 - 0x93aa1ffb  com.apple.AE (645.6 - 645.6) <44556FF7-A869-399A-AEBB-F4E9263D9152> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
                                0x93aa2000 - 0x93aa6fff  com.apple.CommonPanels (1.2.5 - 94) <6B3E7E53-7708-3DA2-8C50-59C2B4735DE1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
                                0x93aa7000 - 0x93aa7fff  com.apple.vecLib (3.8 - vecLib 3.8) <83160DD1-5614-3E34-80EB-97041016EF1F> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
                                0x93aa8000 - 0x93aacffc  libGIF.dylib (850) <45CD8B8F-7324-3187-B01C-8E16C04F33FA> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
                                0x93aad000 - 0x93b0ffff  libc++.1.dylib (65.1) <C0CFF9FF-5D52-3EAE-B921-6AE1DA00A135> /usr/lib/libc++.1.dylib
                                0x93b10000 - 0x93b1afff  com.apple.DisplayServicesFW (2.7.2 - 357) <76D33A58-C39E-398A-9597-389A9B1FE76D> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
                                0x93b1b000 - 0x93ba0ff7  com.apple.SearchKit (1.4.0 - 1.4.0) <454E950F-291C-3E95-8F35-05CA0AD6B327> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
                                0x93ba1000 - 0x93c82fff  libcrypto.0.9.8.dylib (47.1) <E4820342-4F42-3DEB-90DB-DE5A66C5585E> /usr/lib/libcrypto.0.9.8.dylib
                                0x93c83000 - 0x9403bffa  libLAPACK.dylib (1073.4) <9A6E5EAD-F2F2-3D5C-B655-2B536DB477F2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
                                0x94048000 - 0x94056ff7  libz.1.dylib (43) <245F1B61-2276-3BBB-9891-99934116D833> /usr/lib/libz.1.dylib
                                0x94057000 - 0x94377ff3  com.apple.Foundation (6.8 - 945.18) <BDC56A93-45C5-3459-B307-65A1CCE702C5> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                                0x9441a000 - 0x94471ff7  com.apple.ScalableUserInterface (1.0 - 1) <2B5E454B-BC49-3E85-B54D-1950397C448C> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterfa ce.framework/Versions/A/ScalableUserInterface
                                0x94472000 - 0x944eeff3  com.apple.Metadata (10.7.0 - 707.11) <F9BB5BBE-69D0-3309-8280-2303EB1DC455> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
                                0x944ef000 - 0x9476bff7  com.apple.QuickTime (7.7.1 - 2599.31) <3839E1F3-7948-3E68-9AE1-A0CEE8C59212> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
                                0x9477d000 - 0x9479dffd  com.apple.ChunkingLibrary (2.0 - 133.3) <FA45EAE8-BB10-3AEE-9FDC-C0C3A533FF48> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
                                0x9479e000 - 0x9488fffc  libiconv.2.dylib (34) <B096A9B7-83A6-31B3-8D2F-87D91910BF4C> /usr/lib/libiconv.2.dylib
                                0x94890000 - 0x9489efff  com.apple.opengl (1.8.9 - 1.8.9) <1872D2CD-00A8-30D1-8ECC-B663F4E4C530> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
                                0x9489f000 - 0x948a2ffc  libCoreVMClient.dylib (32.3) <35B63A60-DF0A-3FB3-ABB8-164B246A43CC> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
                                0x948a3000 - 0x948f3ff7  com.apple.CoreMediaIO (308.0 - 4155.4) <E2FF59A9-3728-3D17-A1AD-84DC1BDA2146> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
                                0x948f4000 - 0x94909fff  com.apple.speech.synthesis.framework (4.1.12 - 4.1.12) <DE68CEB5-4959-3652-83B8-D2B00D3B932D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
                                0x9490a000 - 0x9491cff7  libdispatch.dylib (228.23) <86EF7D45-2D97-3465-A449-95038AE5DABA> /usr/lib/system/libdispatch.dylib
                                0x9491d000 - 0x94965ff5  com.apple.opencl (2.2.19 - 2.2.19) <968DD067-49D0-3B71-A96B-B3579698D992> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
                                0x94966000 - 0x949caff3  libstdc++.6.dylib (56) <F8FA490A-8F3C-3645-ABF5-78926CE9C62C> /usr/lib/libstdc++.6.dylib
                                0x949cb000 - 0x949ccffd  libunc.dylib (25) <58599CBF-E262-3CEA-AFE1-35560E0177DC> /usr/lib/system/libunc.dylib
                                0x949cf000 - 0x94ac3ff3  com.apple.QuickLookUIFramework (4.0 - 555.5) <5A62C87F-5F74-380B-8B86-8CE3D8788603> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
                                0x94ac4000 - 0x94ac4fff  com.apple.Accelerate (1.8 - Accelerate 1.8) <4EC0548E-3A3F-310D-A366-47B51D5B6398> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
                                0x94ac5000 - 0x94f07fff  com.apple.CoreGraphics (1.600.0 - 332) <67E70F21-A0F1-356F-90B7-4B90C468EE2C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
                                0x94f08000 - 0x94f61fff  com.apple.QuickLookFramework (4.0 - 555.5) <4E381B7B-7EB5-37FD-9BA7-517DB48D07A7> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
                                0x94f9a000 - 0x94f9cffd  libCVMSPluginSupport.dylib (8.9.2) <D6D0BB75-42DA-3772-AB5E-CBD59B343393> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
                                0x94f9d000 - 0x9509bff7  libFontParser.dylib (84.6) <7D3EB3CC-527E-3A74-816A-59CAFD2260A4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
                                0x9509c000 - 0x950a5fff  com.apple.DiskArbitration (2.5.2 - 2.5.2) <89822A83-B450-3363-8E9C-9B80CB4450B1> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
                                0x950a6000 - 0x95146ff7  com.apple.QD (3.42.1 - 285.1) <BAAC13D2-1312-33C0-A255-FAB1D314C324> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
                                0x95147000 - 0x9523fff9  libsqlite3.dylib (138.1) <AD7C5914-35F0-37A3-9238-A29D2E26C755> /usr/lib/libsqlite3.dylib
                                0x95240000 - 0x95240fff  libsystem_blocks.dylib (59) <3A743C5D-CFA5-37D8-80A8-B6795A9DB04F> /usr/lib/system/libsystem_blocks.dylib
                                0x959dd000 - 0x959defff  libdnsinfo.dylib (453.19) <3B523729-84A8-3D0B-B58C-3FC185060E67> /usr/lib/system/libdnsinfo.dylib
                                0x959df000 - 0x95dfcfff  FaceCoreLight (2.4.1) <B12C8721-EFB3-30A2-9A1B-ABCDF5670764> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/FaceCoreLight
                                0x95e29000 - 0x95e30ffe  com.apple.agl (3.2.1 - AGL-3.2.1) <F13F8669-5FC5-386C-9100-523D2BBF23CE> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
                                0x95e31000 - 0x95e35fff  com.apple.OpenDirectory (10.8 - 151.10) <B9244697-CB05-3BD3-80A7-D188B3747B03> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
                                0x95e87000 - 0x96147ff3  com.apple.security (7.0 - 55179.13) <000FD8E9-D070-326A-B386-51314360FD5C> /System/Library/Frameworks/Security.framework/Versions/A/Security
                                0x9614d000 - 0x963a6ff5  com.apple.JavaScriptCore (8536 - 8536.30) <24A2ACA7-6E51-30C6-B9AE-17A77E511735> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
                                0x963a7000 - 0x96408fff  com.apple.audio.CoreAudio (4.1.1 - 4.1.1) <A3B911DB-77DF-3037-A47A-634B08E5727D> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
                                0x96409000 - 0x9640cff9  libCGXType.A.dylib (332) <07B59FCC-6229-37C2-9870-70A18E2C5598> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
                                0x9640d000 - 0x9640dffd  libOpenScriptingUtil.dylib (148.3) <87895E27-88E2-3249-8D0E-B17E76FB00C1> /usr/lib/libOpenScriptingUtil.dylib
                                0x9640e000 - 0x9640fffd  com.apple.TrustEvaluationAgent (2.0 - 23) <E42347C0-2D3C-36A4-9200-757FFA61B388> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
                                0x96410000 - 0x966b3ff3  com.apple.CoreImage (8.4.0 - 1.0.1) <C25B9EEC-4824-3088-BC08-2EA516C0728C> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework /Versions/A/CoreImage
                                0x966b4000 - 0x96811ffb  com.apple.QTKit (7.7.1 - 2599.31) <B9AE5675-22B0-3AA9-903F-2195DA0B04F5> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
                                0x968ca000 - 0x96924ff3  com.apple.ImageCaptureCore (5.0.4 - 5.0.4) <6313E06F-37FD-3606-BF2F-87D8598A9983> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
                                0x96958000 - 0x9697afff  libc++abi.dylib (26) <3AAA8D55-F5F6-362B-BA3C-CCAF0D3C8E27> /usr/lib/libc++abi.dylib
                                0x96982000 - 0x969e6ff7  com.apple.datadetectorscore (4.1 - 269.3) <C11C2014-298E-3E2B-9F5D-02CCD3CA4AB3> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
                                0x969e7000 - 0x96af4ff3  com.apple.ImageIO.framework (3.2.1 - 850) <C964E877-660E-3482-ACF9-EC25DFEAF307> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
                                0x96af5000 - 0x96b00fff  libcommonCrypto.dylib (60027) <8EE30FA5-AA8D-3FA6-AB0F-05DA8B0425D9> /usr/lib/system/libcommonCrypto.dylib
                                0x96b01000 - 0x96b0afff  com.apple.CommerceCore (1.0 - 26.1) <8C28115C-6EC1-316D-9237-F4FBCBB778C5> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
                                0x96b0b000 - 0x96b59ff3  com.apple.SystemConfiguration (1.12.2 - 1.12.2) <6E858B9F-337A-314E-88B7-24A274ACE568> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
                                0x96b5a000 - 0x96b5cffb  libRadiance.dylib (850) <83434287-A09E-3A3F-A1AC-085B563BA46D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
                                0x96b5d000 - 0x96bc3fff  com.apple.print.framework.PrintCore (8.3 - 387.2) <0F7665F5-33F0-3661-9BE2-7DD2890E304B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
                                0x96bc4000 - 0x96c13ff6  libTIFF.dylib (850) <78E121A6-92A2-3120-883C-7AA3C2966F9C> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
                                0x96c14000 - 0x96d30ffb  com.apple.desktopservices (1.7.4 - 1.7.4) <782D711D-7930-324A-9015-686C2F86DBA3> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
                                0x96d31000 - 0x96d88ff3  com.apple.HIServices (1.20 - 417) <30AA0F48-A397-339E-BC62-24620B2B35BC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
                                0x96d89000 - 0x96dadfff  libJPEG.dylib (850) <36FEAB05-86C5-33B9-9DE9-5FAD8AEBA15F> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
                                0x96ddf000 - 0x96eb3ff3  com.apple.backup.framework (1.4.3 - 1.4.3) <6EA22ED3-BA18-3A37-AE05-5D6FDA3F372F> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
                                0x96ef3000 - 0x96f10ff7  libresolv.9.dylib (51) <B9742A2A-DF15-3F6E-8FCE-778A58214B3A> /usr/lib/libresolv.9.dylib
                                0x96f57000 - 0x96f71ffc  libsystem_kernel.dylib (2050.24.15) <9E58DCC0-D5FF-37E1-AA7F-F2206719E138> /usr/lib/system/libsystem_kernel.dylib
                                0x96f72000 - 0x96f75ff7  com.apple.TCC (1.0 - 1) <437D76CD-6437-3B55-BE2C-A53508858256> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
                                0x96f76000 - 0x96f89ff9  com.apple.MultitouchSupport.framework (235.29 - 235.29) <451701B6-03CE-3F26-9FF0-92D8DA1467EE> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
                                0x96f96000 - 0x970efffb  com.apple.audio.toolbox.AudioToolbox (1.9 - 1.9) <8BF022FC-C38A-34AA-8469-D98294094659> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
                                0x973dd000 - 0x9746fffb  libvMisc.dylib (380.6) <6DA3A03F-20BE-300D-A664-B50A7B4E4B1A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
                                0x97470000 - 0x9752eff3  com.apple.ColorSync (4.8.0 - 4.8.0) <EFEDCB37-4F20-3CEC-A185-5D2976E11BAC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
                                0x9752f000 - 0x9752fffd  com.apple.audio.units.AudioUnit (1.9 - 1.9) <F7638E43-F885-372E-9DAE-24D0C21AA66E> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
                                0x97556000 - 0x975eefff  com.apple.CoreServices.OSServices (557.6 - 557.6) <E1600639-3EEC-3DF8-BD40-747BB2117988> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
                                0x975ef000 - 0x97657ff7  com.apple.framework.IOKit (2.0.1 - 755.24.1) <70DE925B-51E8-3C65-8928-FB49FD823D94> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                                0x9769b000 - 0x97738ff7  com.apple.PDFKit (2.8.4 - 2.8.4) <639CF802-BE94-39C5-AC97-B5B42FF910C2> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
                                0x97739000 - 0x97743fff  com.apple.speech.recognition.framework (4.1.5 - 4.1.5) <B855E8B4-2EE3-3BFF-8547-98A0F084F9AF> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
                                0x97784000 - 0x977b7fff  libssl.0.9.8.dylib (47.1) <1725A506-BD80-39D5-8EE8-78D2FBBE194C> /usr/lib/libssl.0.9.8.dylib
                                0x977b8000 - 0x977e5ffe  libsystem_m.dylib (3022.6) <9975D9C3-3B71-38E3-AA21-C5C5F9D9C431> /usr/lib/system/libsystem_m.dylib
                                0x978e8000 - 0x9791bffb  com.apple.GSS (3.0 - 2.0) <9566A96D-C296-3ABD-A12A-E274C81C0B25> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
                                0x9791c000 - 0x97933fff  com.apple.GenerationalStorage (1.1 - 132.3) <DD0AA3DB-376D-37F3-AC5B-17AC9B9E0A63> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
                                0x97934000 - 0x97935fff  libDiagnosticMessagesClient.dylib (8) <39B3D25A-148A-3936-B800-0D393A00E64F> /usr/lib/libDiagnosticMessagesClient.dylib
                                0x97936000 - 0x97937fff  libremovefile.dylib (23.2) <9813B2DB-2374-3AA2-99B6-AA2E9897B249> /usr/lib/system/libremovefile.dylib
                                0x97938000 - 0x97938fff  com.apple.ApplicationServices (45 - 45) <677C4ACC-9D12-366F-8A87-B898AC806DD9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
                                0x97939000 - 0x97950ff4  com.apple.CoreMediaAuthoring (2.1 - 914) <DE0D100E-96AA-3E85-AFB0-43832E9B4C54> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthor ing
                                0x97951000 - 0x97a5cff7  libJP2.dylib (850) <3FFCEFA6-317A-34AF-8D99-AEBB017543C5> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
                                0x97a5d000 - 0x97a69ff7  com.apple.NetAuth (4.0 - 4.0) <4983C4B8-9D95-3C4D-897E-07743326487E> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
                                0x97a6a000 - 0x97bf3ff7  com.apple.vImage (6.0 - 6.0) <1D1F67FE-4F75-3689-BEF6-4A46C8039E70> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
                                0x97e66000 - 0x97eabff7  com.apple.NavigationServices (3.7 - 200) <F6531764-6E43-3AF3-ACDD-8A5551EF016A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.fram ework/Versions/A/NavigationServices
                                0x97eac000 - 0x97ebbfff  libGL.dylib (8.9.2) <1082B9A5-9AA3-35D4-968B-3A3FE15B1ED7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
                                0x97ebc000 - 0x97f03ff3  com.apple.CoreMedia (1.0 - 926.104) <D0E3BE86-12ED-31BE-816F-E72D757A9F2F> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
                                0x97f04000 - 0x97f08ff7  libmacho.dylib (829) <5280A013-4F74-3F74-BE0C-7F612C49F1DC> /usr/lib/system/libmacho.dylib
                                0x97f09000 - 0x97f25fff  libPng.dylib (850) <26AD967A-D55E-3C5A-A643-D9953136DE58> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
                                0x97f26000 - 0x97fd0fff  com.apple.LaunchServices (539.9 - 539.9) <C0E0CFFF-3714-3467-87DA-4A6F0AF1953B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
                                0x97fd1000 - 0x97fd1fff  libSystem.B.dylib (169.3) <0A82D354-A1B4-3F3E-8C7E-5047C38D4668> /usr/lib/libSystem.B.dylib
                                0x97fd2000 - 0x9810dff7  libBLAS.dylib (1073.4) <FF74A147-05E1-37C4-BC10-7DEB57FE5326> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
                                0x9811d000 - 0x9818cffb  com.apple.Heimdal (3.0 - 2.0) <964D9952-B0F2-34F6-8265-1823C0D5EAB8> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
                                0x9818d000 - 0x9819dff2  com.apple.LangAnalysis (1.7.0 - 1.7.0) <875363E7-6D02-3229-A9DD-E5A5568A7D61> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
                                0x9819e000 - 0x981e0fff  libauto.dylib (185.4) <3098A75E-438E-3F18-BAAC-CD8F1CC7C2F7> /usr/lib/libauto.dylib
                                0x981e1000 - 0x981e1fff  com.apple.Carbon (154 - 155) <17F1B675-E054-3D2C-900B-C9CE69F1FC31> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
                                0x982b9000 - 0x982c7ff3  libsystem_network.dylib (77.10) <7FBF5A15-97BA-3721-943E-E77F0C40DBE1> /usr/lib/system/libsystem_network.dylib
                                0x99001000 - 0x99025fff  com.apple.PerformanceAnalysis (1.16 - 16) <18DE0F9F-1264-394D-AC56-6B2A1771DFBE> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
                                0x99026000 - 0x99032ff8  libbz2.1.0.dylib (29) <7031A4C0-784A-3EAA-93DF-EA1F26CC9264> /usr/lib/libbz2.1.0.dylib
                                0x99033000 - 0x99041fff  libxar.1.dylib (105) <343E4A3B-1D04-34A3-94C2-8C7C9A8F736B> /usr/lib/libxar.1.dylib
                                0x99083000 - 0x9908fffa  com.apple.CrashReporterSupport (10.8.3 - 418) <03BC564E-35FE-384E-87D6-6E0C55DF16E3> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporter Support
                                0x99409000 - 0x99409fff  com.apple.CoreServices (57 - 57) <956C6C6D-A5DD-314F-9C57-4A61D41F30CE> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
                                0x9940a000 - 0x99465fff  com.apple.htmlrendering (77 - 1.1.4) <5C0C669F-AE07-3983-B38F-EB829B5CE609> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework /Versions/A/HTMLRendering
                                0x99466000 - 0x9947ffff  com.apple.Kerberos (2.0 - 1) <9BDE8F4D-DBC3-34D1-852C-898D3655A611> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
                                0x99480000 - 0x994bbfef  libGLImage.dylib (8.9.2) <9D41F71E-E927-3767-A856-55480E20E9D9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
                                0x994bc000 - 0x994c9ff7  com.apple.AppleFSCompression (49 - 1.0) <166AA1F8-E50A-3533-A3B5-8737C5118CC3> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompress ion
                                0x994ca000 - 0x995d7057  libobjc.A.dylib (532.2) <FA455371-7395-3D58-A89B-D1520612D1BC> /usr/lib/libobjc.A.dylib
                                0x995d8000 - 0x9966fff7  com.apple.ink.framework (10.8.2 - 150) <A9C3B735-7D5F-3D7D-AA70-2CC852D09CDE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
                                0x99670000 - 0x99671fff  liblangid.dylib (116) <E13CC8C5-5034-320A-A210-41A2BDE4F846> /usr/lib/liblangid.dylib
                                0x99783000 - 0x997acfff  libxslt.1.dylib (11.3) <0DE17DAA-66FF-3195-AADB-347BEB5E2EFA> /usr/lib/libxslt.1.dylib
                                0x997ad000 - 0x997adfff  com.apple.Cocoa (6.7 - 19) <354094F0-F36B-36F9-BF5F-FD60590FBEB9> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
                                0x997ae000 - 0x997f0ff7  libcups.2.dylib (327.6) <D994A44F-CCDD-3D40-B732-79CB88F45908> /usr/lib/libcups.2.dylib
                                0x997f1000 - 0x9983dfff  libcorecrypto.dylib (106.2) <20EBADBA-D6D6-36F0-AE80-168E9AF13DB6> /usr/lib/system/libcorecrypto.dylib
                                0x9983e000 - 0x99847ff9  com.apple.CommonAuth (3.0 - 2.0) <34C4768C-EF8D-3DBA-AFB7-09148C8672DB> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
                                0x99848000 - 0x9984ffff  libsystem_dnssd.dylib (379.38.1) <4F164CA8-4A4F-3B27-B88A-0926E2FEB7D4> /usr/lib/system/libsystem_dnssd.dylib
                                0x99850000 - 0x9985afff  libCSync.A.dylib (332) <86C5C84F-11EC-39C0-9FAC-A93FDEEC3117> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
                                0x99877000 - 0x998a8fff  com.apple.DictionaryServices (1.2 - 184.4) <A31BB2CE-6965-3610-8B11-EA26EC6D7EEA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
                                0x998a9000 - 0x998adffe  libcache.dylib (57) <834FDCA7-FE3B-33CC-A12A-E11E202477EC> /usr/lib/system/libcache.dylib
                                0x998ae000 - 0x998b4fff  libGFXShared.dylib (8.9.2) <F3B0E66D-5C47-3A5A-A2CD-F0C58E8322C3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
                                0x998b5000 - 0x99cb1feb  com.apple.VideoToolbox (1.0 - 926.104) <4275B89E-F826-3F65-ACE1-89052A9CAC6B> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
                                0x99cb2000 - 0x99cb9ff3  com.apple.NetFS (5.0 - 4.0) <1F7041F2-4E97-368C-8F5D-24153D81BBDB> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
                                0x99cba000 - 0x99dd2ff7  com.apple.coreavchd (5.6.0 - 5600.4.16) <F024C78B-4FAA-38F1-A182-AD0A0A596CBE> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
                                0x99dd3000 - 0x99f06ff3  com.apple.MediaControlSender (1.7 - 170.20) <7B1AC317-AFDB-394F-8026-9561930E696B> /System/Library/PrivateFrameworks/MediaControlSender.framework/Versions/A/MediaControlSen der
                                0x99f48000 - 0x99f4bffc  libpam.2.dylib (20) <FCF74195-A99E-3B07-8E49-688D4A6F1E18> /usr/lib/libpam.2.dylib
                                0x99f4c000 - 0x99f52fff  com.apple.print.framework.Print (8.0 - 258) <12AEAD24-6924-3923-9E4A-C5D21231E639> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
                                0x99f53000 - 0x99f55fff  com.apple.securityhi (4.0 - 55002) <F95F4BF5-2290-3CC4-A37A-4852F0AE6FAE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
                                0x99f56000 - 0x99f9aff7  libGLU.dylib (8.9.2) <F33F6C73-7F89-3B5B-A50F-2AB57BBA314D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
                                0x99f9f000 - 0x99fccffb  com.apple.CoreServicesInternal (154.3 - 154.3) <A452602B-67CB-39C4-95EB-E59433C65774> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
                                0x99fcd000 - 0x9a08afeb  libsystem_c.dylib (825.26) <6E35A83F-1A5B-3AF9-8C6D-D7B57B25FB63> /usr/lib/system/libsystem_c.dylib
                                0x9a08b000 - 0x9a0aaff3  com.apple.Ubiquity (1.2 - 243.15) <E10A2937-D671-3D14-AF8D-BA25E601F458> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
                                0x9a0ab000 - 0x9a0c8fff  libxpc.dylib (140.43) <C628073D-51A0-3541-A665-1121520508C6> /usr/lib/system/libxpc.dylib
                                0x9a0c9000 - 0x9a117ffb  libFontRegistry.dylib (100) <3B8350C2-4D8F-38C4-A22E-2F855D7E83D1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
                                0x9a118000 - 0x9a41dff7  com.apple.CoreServices.CarbonCore (1037.6 - 1037.6) <4DB4B0C9-1377-3062-BE0E-CD3326ACDAF0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
                                0x9a454000 - 0x9a5a2ff3  com.apple.CFNetwork (596.4.3 - 596.4.3) <547BD138-E902-35F0-B6EC-41DD06794B22> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
                                0x9a5dd000 - 0x9a5e0ff7  libcompiler_rt.dylib (30) <CE5DBDB4-0124-3E2B-9105-989DF98DD108> /usr/lib/system/libcompiler_rt.dylib
                                0x9a5e1000 - 0x9a5e4fff  com.apple.help (1.3.2 - 42) <AD7EB1F0-A068-3A2C-9D59-38E59CEC0D96> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
                                0x9a5e5000 - 0x9a680fff  com.apple.CoreSymbolication (3.0 - 117) <F705A8CD-A04A-3A84-970A-7B04BC05DA97> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
                                0xb0000000 - 0xb0013fff +com.adobe.ahclientframework (1.8.0.31 - 1.8.0.31) <356D51D4-F625-3570-9D90-8E934EF03FFC> /Applications/Adobe Extension Manager CC/Adobe Extension Manager CC.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
                                0xba900000 - 0xba91cffd  libJapaneseConverter.dylib (61) <A3F2F55D-E491-3532-A8F6-8D3F2455704F> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
                                0xbab00000 - 0xbab21ffc  libKoreanConverter.dylib (61) <39F6BEE7-AE54-3423-B920-2A3573BC9A1A> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
                                External Modification Summary:
                                  Calls made by other processes targeting this process:
                                    task_for_pid: 2
                                    thread_create: 0
                                    thread_set_state: 0
                                  Calls made by this process:
                                    task_for_pid: 0
                                    thread_create: 0
                                    thread_set_state: 0
                                  Calls made by all processes on this machine:
                                    task_for_pid: 398
                                    thread_create: 4
                                    thread_set_state: 0
                                VM Region Summary:
                                ReadOnly portion of Libraries: Total=190.2M resident=91.0M(48%) swapped_out_or_unallocated=99.2M(52%)
                                Writable regions: Total=122.5M written=23.3M(19%) resident=42.7M(35%) swapped_out=0K(0%) unallocated=79.8M(65%)
                                REGION TYPE                      VIRTUAL
                                ATS (font support)                 32.1M
                                ATS (font support) (reserved)         4K        reserved VM address space (unallocated)
                                CG backing stores                  3364K
                                CG shared images                   1184K
                                CoreServices                       2788K
                                MALLOC                             33.4M
                                MALLOC guard page                    48K
                                Memory tag=240                     24.0M
                                Memory tag=242                       12K
                                Memory tag=243                        4K
                                Memory tag=249                      192K
                                Memory tag=35                      4572K
                                Stack                              70.1M
                                VM_ALLOCATE                        17.3M
                                __DATA                             9600K
                                __DATA/__OBJC                       192K
                                __IMAGE                             528K
                                __IMPORT                              8K
                                __LINKEDIT                         38.2M
                                __OBJC                             2432K
                                __OBJC/__DATA                       100K
                                __PAGEZERO                            4K
                                __TEXT                            152.0M
                                __UNICODE                           544K
                                mapped file                        87.7M
                                shared memory                       308K
                                TOTAL                             480.0M
                                TOTAL, minus reserved VM space    480.0M
                                Model: MacBookPro5,2, BootROM MBP52.008E.B05, 2 processors, Intel Core 2 Duo, 2.8 GHz, 8 GB, SMC 1.42f4
                                Graphics: NVIDIA GeForce 9400M, NVIDIA GeForce 9400M, PCI, 256 MB
                                Graphics: NVIDIA GeForce 9600M GT, NVIDIA GeForce 9600M GT, PCIe, 512 MB
                                Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1067 MHz, 0x80CE, 0x4D34373142353237334248312D4346382020
                                Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1067 MHz, 0x80CE, 0x4D34373142353237334248312D4346382020
                                AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8D), Broadcom BCM43xx 1.0 (5.106.98.100.17)
                                Bluetooth: Version 4.1.4f2 12041, 2 service, 18 devices, 1 incoming serial ports
                                Network Service: Ethernet, Ethernet, en0
                                Network Service: Wi-Fi, AirPort, en1
                                PCI Card: sppci_expresscard_name, sppci_ieee1394openhci, ExpressCard@7,0,0
                                Serial ATA Device: Crucial_CT960M500SSD1, 960.2 GB
                                Serial ATA Device: HL-DT-ST DVDRW  GS21N
                                USB Device: Built-in iSight, apple_vendor_id, 0x8507, 0x24400000 / 3
                                USB Device: hub_device, apple_vendor_id, 0x9126, 0x24100000 / 2
                                USB Device: BUFFALO INC. USB-SATA Bridge, 0x0411  (Melco, Inc.), 0x00db, 0x24120000 / 9
                                USB Device: My Passport 0748, 0x1058  (Western Digital Technologies, Inc.), 0x0748, 0x24130000 / 8
                                USB Device: Datacolor Spyder4, 0x085c, 0x0400, 0x24110000 / 7
                                USB Device: Display Audio, apple_vendor_id, 0x1105, 0x24140000 / 6
                                USB Device: Apple LED Cinema Display, apple_vendor_id, 0x9226, 0x24160000 / 5
                                USB Device: Display iSight, apple_vendor_id, 0x8508, 0x24150000 / 4
                                USB Device: USB2.0 Hub, 0x05e3  (Genesys Logic, Inc.), 0x0608, 0x26400000 / 3
                                USB Device: Apollo M250, 0x1bcf  (Sunplus Innovation Technology Inc.), 0x0c31, 0x26440000 / 7
                                USB Device: USB2.0 Hub, 0x05e3  (Genesys Logic, Inc.), 0x0608, 0x26410000 / 6
                                USB Device: EPSON Scanner, 0x04b8  (Seiko Epson Corp.), 0x012a, 0x26413000 / 11
                                USB Device: Samsung S2 Portable, 0x04e8  (Samsung Electronics Co., Ltd.), 0x1f06, 0x26411000 / 10
                                USB Device: USB2.0 Hub, 0x05e3  (Genesys Logic, Inc.), 0x0608, 0x26200000 / 2
                                USB Device: USB2.0 Hub, 0x05e3  (Genesys Logic, Inc.), 0x0608, 0x26240000 / 5
                                USB Device: Logitech Camera, 0x046d  (Logitech Inc.), 0x0821, 0x26242000 / 9
                                USB Device: SDDR-189, 0x0781  (SanDisk Corporation), 0xb7bd, 0x26243000 / 8
                                USB Device: FreeAgent GoFlex, 0x0bc2  (Seagate LLC), 0x5021, 0x26230000 / 4
                                USB Device: Apple Internal Keyboard / Trackpad, apple_vendor_id, 0x0237, 0x04600000 / 3
                                USB Device: IR Receiver, apple_vendor_id, 0x8242, 0x04500000 / 2
                                USB Device: BRCM2046 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0x06100000 / 2
                                USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8217, 0x06110000 / 4
                                FireWire Device: My Book, WD, 800mbit_speed
