• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Recording sound in PPT using Presenter
New Here ,
Oct 04, 2007 Oct 04, 2007
A faculty member at my University is creating his modules in PPT using Adobe Presenter. He has put builds into his PPT slides, but when he records the audio there are two problems he experiences...
1. the slide doesn't show any text at all except the header
2. or all of the text is on the screen
In either case the builds are not there.
Has anybody experienced this or has found a solution? Any ideas would be very helpful.
Thank You
TOPICS
Presenter
Views
484
Translate
Translate
Report
Report
Community guidelines
community guidelines
Guest
Oct 05, 2007 Oct 05, 2007
amm,
Just curious....after your collegue has added audio to the presentation, did he/she go back and adjust the timings of the anims? Most often what will happen is that all the animated elements will get pushed to the end of the audio; if you go into the Audio Editor, what you might find is that there will be a few blue colored markers all bunched up together at the very end of the audio for a given slide. The solution to that problem is to either go into Synchronized Timings to adjust when the animations are supposed to appear, or you could drag each of the blue markers in the Audio Editor to have the animations appear where/when you want them to.
Regarding item #2, I'm not really sure why all of your text would be just sitting there, but I'd check the Audio Editor for that as well: take a look at where the animation markers are sitting within the Audio Editor's timeline. I'd suspect, however, that if no markers are present, that perhaps the animations for the text builds either weren't set properly or were killed off somehow.
Hope that helps,
Rob
Votes
Translate
Translate
Report
Report
New Here ,
Thank you Rob.... This information is really useful. I'll look into it and see. I'm guessing it is better to record all the audio, then but the builds in?
We'll check into it. I appreciate the reply.
Anne
Votes
Translate
Translate
Report
Report
Guest
LATEST
Hi Anne,
No problem.
As far as importing/recording the audio and doing the builds afterwards, it really depends on how you choose to do it. Bottom line: it really doesn't matter.
What I typically do (when working with content authors) is set up the builds anyway; oftentimes I don't have audio to work with until those files are provided later on in the project, and by establishing the builds, the SMEs or content authors can have a sense of how the anims will work. So we set 'em all up, and run the deck in show mode so they get a sense of how it'll work.
Then once the audio is available (most of our clients insist on professional narrators), its imported and then we synch the timings.
So again, you can approach this anyway that is most convenient/comfortable to you and your team.
Rob
Votes
Translate
Translate
Report
Report
Resources
Help resources
