1 Reply Latest reply on Oct 10, 2007 4:37 AM by Derrick_DC
    Passing cfselect value to cfgrid
    MickBW
      Good Afternoon,
      I am trying to pass the values from a cfselect box to filter the results in a CFGrid and then refresh the grid. Both of the objects are bound to a cfc method.
      When I run the code I see the select box with the correct values and the unfiltered grid. I believe all I need to know is how to pass the value of the cfselect object to the cfc that is bound to the grid.
      The CFM:
      <cfform name="DisplayGrid">
      <cfselect name="DebtIssue"
      bind="cfc:Mint_DataQueries.IssuesForSelect()"
      bindonload="true" multiple="true" size="5" onclick="ColdFusion.Grid.refresh('asynchgrid', true)" />
      <cfgrid name="asynchgrid"
      format="html"
      pageSize="10"
      bind="cfc:Mint_DataQueries.dmf_all({cfgridpage},{cfgridpagesize},{cfgridsortcolumn},{cfgr idsortdirection})"
      stripeRows="true"
      stripeRowColor="##e0e0e0" selectmode="row" >
      <cfgridcolumn name="debtname" header="Debt">
      <cfgridcolumn name="debtissue" header="Issue">
      <cfgridcolumn name="FSRC" header="FSRC">
      <cfgridcolumn name="appropriation" header="Appropriation">
      </cfgrid>
      </cfform>
      The CFC that the Grid and Select Box is bound to:
      <cffunction name="dmf_all" output="false"
      access="remote" returntype="any"
      hint="Pulls in all DebtMasterFile records">
      <cfargument name="cfgridpage" required="true" />
      <cfargument name="cfgridpagesize" required="true" />
      <cfargument name="cfgridsortcolumn" required="true" />
      <cfargument name="cfgridsortdirection" required="true" />
      <cfargument name="issuefilter" required="false" type="numeric" default="0"/>
      <cfargument name="codefilter" required="false" type="numeric" default="0"/>
      <cfargument name="fsrcfilter" required="false" type="numeric" default="0"/>
      <cfargument name="appropriationfilter" required="false" type="numeric" default="0"/>
      <cfargument name="fundfilter" required="false" type="numeric" default="0"/>
      <cfset var mfrecords = ' />
      <cfquery name="mfrecords" datasource="#Application.datasource#" result="QueryRezultz">
      Select DMF.DebtID,
      DMF.DebtNumber,
      DMF.DebtName,
      DMF.FSRCID,
      FSRC.Fsrc,DebtDate, PrincipalDate, InterestDate,
      DTT.DebtCode, DTT.DebtType,PrincipalAmount, InterestAmount,
      DMF.AppropriationID,
      Approp.Appropriation, Clerk, LastRev, ClerkRev,
      DMF.codeID, DMF.FSRCID, DI.DebtIssue, DMF.IssueID,DMF.FundID,DMF.Active
      from DebtMasterFile DMF
      left outer join FSRC
      on FSRC.FSRCID = DMF.FSRCID
      left outer join DebtTypetitles DTT
      on DTT.TitleID = DMF.CodeID
      left outer join Appropriations Approp
      on Approp.AppropriationID =
      DMF.AppropriationID
      left outer join DebtIssues DI
      on DI.IssueID =DMF.IssueID
      where 0 = 0
      <cfif issuefilter neq 0>
      AND DMF.IssueID =
      <cfqueryparam cfsqltype="cf_sql_smallint" value="#arguments.issuefilter#">
      </cfif>
      AND DMF.CodeID =
      <cfqueryparam cfsqltype="cf_sql_tinyint" value="#arguments.codefilter#">
      </cfif>
      <cfif fsrcfilter neq 0>
      AND DMF.FsrcID =
      <cfqueryparam cfsqltype="cf_sql_smallint" value="#arguments.fsrcfilter#">
      </cfif>
      <cfif appropriationfilter neq 0>
      AND DMF.AppropriationID =
      <cfqueryparam cfsqltype="cf_sql_smallint" value="#arguments.appropriationfilter#">
      </cfif>
      <cfif fundfilter neq 0>
      AND DMF.FundID =
      <cfqueryparam cfsqltype="cf_sql_tinyint" value="#arguments.fundfilter#">
      </cfif>
      </cfquery>
      <cfreturn QueryConvertForGrid(mfrecords, #arguments.cfgridpage#,#arguments.cfgridpagesize#)>
      </cffunction>
      <cffunction name="IssuesForSelect" access="remote">
      <cfset var SelectData = "" />
      <cfquery name="SelectData" datasource="#Application.datasource#"
      result="SelectRezultz1">
      Select IssueID, DebtIssue from DebtIssues
      order by IssueID desc
      </cfquery>
      <cfset Issuez = arraynew(2)>
      <cfset Issuez[1][1] = "0">
      <cfset Issuez[1][2] = "--issue--">
      <cfloop query="SelectData">
      <cfset Issuez[SelectData.CurrentRow][1] =
      SelectData.IssueID>
      <cfset Issuez[SelectData.CurrentRow][2] = ltrim(SelectData.DebtIssue)>
      </cfloop>
      <cfreturn Issuez>
      </cffunction>
      Any Help would be appreciated.
      Michael
        • 1. Re: Passing cfselect value to cfgrid
          Derrick_DC
          Michael, you could use a javascript function to get at the value from the select box:
          Javascript Function:
          <script>
          getDebtIssue = function()
          var s = ColdFusion.getElementValue(DebtIssue);
          return s;
          </script>
          CFGrid:
          format="html"
          pageSize="10"
          bind="cfc:Mint_DataQueries.dmf_all(getDebtIssue(),{cfgridpage},{cfgridpagesize},{cfgridsor tcolumn},{cfgridsortdirection})">
          CFC Change:
          <cfargument name="deptissue" required="false"/>
          </cffunction>
          Let me know if I did not make any sense or if you need more information.
