1. Re: Elements 9 Error Message Cannot Up Date Intel Display Driver Why?
Steve Grisetti Jul 19, 2013 7:52 AM (in response to waterworshipper)An obvious place to start would be the Intel driver download page.
2. Re: Elements 9 Error Message Cannot Up Date Intel Display Driver Why?
waterworshipper Jul 19, 2013 7:56 AM (in response to Steve Grisetti)I did that before I posted this I updated my display drivers same problem?
3. Re: Elements 9 Error Message Cannot Up Date Intel Display Driver Why?
A.T. Romano Jul 19, 2013 8:25 AM (in response to waterworshipper)waterworshipper
In reply to your message to me on this question in
http://forums.adobe.com/thread/1254296?tstart=0
Maybe some personal experiences with that message and Premiere Elements 9 might help. Taking everything else out of the equation, I found Premiere Elements 9 to be prone to this type of display messages and the consequences there from. My case is documented in the following thread here
http://forums.adobe.com/thread/732067
Since my video card driver was up to date "everywhere", my answer was the deletion of the BadDrivers.txt file as instructed by Daksha123 (believed to be from Adobe). The path to that file in your Windows 7 64 bit is:
Local Disc C
Program Data (make sure it is Program Data specifically)
Adobe
Premiere Elements
9.0
and in the 9.0 Folder is the BadDrivers.txt file that you delete.
In the thread cited, Daksha 123 goes into an explanation for how this BadDrivers.txt file is supposed to work.
Once the BadDrivers.txt was deleted, I found it to be a long lasting fix.
Let us know if that resolves the issue.
Thanks.
ATR
4. Re: Elements 9 Error Message Cannot Up Date Intel Display Driver Why?
waterworshipper Jul 19, 2013 8:35 AM (in response to A.T. Romano)Over my head I am lost where to even begin?
Thanks for Your Support,
Captain Bob Santangelo,
708-261-6759
Licensed United States Coast Guard Captain/Email Me At: krvguideservice@yahoo.com Owner Kankakee River Valley Guide Service
Professional Full-Time Guide & Senior Tackle Design Research & Development Engineer/Midwest Division of www.jerrysflies.com
Check out my web site at http://www.kankakeerivervalleyguideservice.com
Find My Video's on youtube Start by Typing "Kankakee River Valley"
5. Re: Elements 9 Error Message Cannot Up Date Intel Display Driver Why?
waterworshipper Jul 19, 2013 9:48 AM (in response to waterworshipper)I was very careful to follow your specific instructions I got to "Program Files" Adobe IS NOT listed there? I even checked all those file NO Adobe listed? I triple made sure (because I am so stupid) I was under "Program Files" Not Program Files 86?
708-261-6759
6. Re: Elements 9 Error Message Cannot Up Date Intel Display Driver Why?
A.T. Romano Jul 19, 2013 10:28 AM (in response to waterworshipper)waterworshipper
Communication is a two way street. So, let me see how I can improve on these instructions. You are doing fine.
There is a possibility that your computer is not set up to "Show Hidden Files, Folders, and Drives". So, let us check that out so that you can see all the files and folders in that path to the BadDrivers.txt file.
Start Button
In the Search field that is revealed, type in the words Folder Options, and then look to the top of that left hand column and click on Folder Options. See screenshot:
The Folder Options dialog should now appear. Click on its View Tab to reveal the View Tab options.
Make sure you have a dot next to "Show Hidden Files, Folders, and Drives".
Close out of there. And, then try the route to the BadDrivers.txt file again.
Looking forward to your results.
ATR
7. Re: Elements 9 Error Message Cannot Up Date Intel Display Driver Why?
waterworshipper Jul 19, 2013 10:48 AM (in response to A.T. Romano)This is scary there was a dot next to, show hidden files, folders, and drivers! When I go to start, computer, my choice is Win7 (C:) correct? Then I go to programs files, everything there seems to appear in alphabetical order by name and Adobe should be listed there correct? It's not sorry?
708-261-6759
8. Re: Elements 9 Error Message Cannot Up Date Intel Display Driver Why?
nealeh Jul 19, 2013 11:17 AM (in response to waterworshipper)Sounds as though you have a 32-bit version of Windows - check under 'Program Files (x86)' for the Adobe folders (everything else as described by ATR).
Cheers,
Neale
Insanity is hereditary, you get it from your children. -
9. Re: Elements 9 Error Message Cannot Up Date Intel Display Driver Why?
A.T. Romano Jul 19, 2013 1:12 PM (in response to nealeh)nealeh
waterworshipper writes at the beginning of the very first post in this thread
Running Windows 7 64 Bits
The mistake is mind, not waterworshipper.
I checked the whole thread I saw that I had mistakenly circled "Program Files" instead of "Program Data" although I wrote "Program Data" in the written instruction elsewhere in the thread..
To correct that this moment.
ATR
10. Re: Elements 9 Error Message Cannot Up Date Intel Display Driver Why?
A.T. Romano Jul 19, 2013 1:03 PM (in response to waterworshipper)waterworshipper
Many many apologizes. In the screenshot in post 5 I circled Program Files instead of Program Data although I wrote Program Data in the written instruction elsewhere. Please watch this post for the correction.
Very sorry. You did great. I messed up.
Correction
(Since I cannot get back into Post 5 to edit it, I going through the process of getting Post 5 deleted. What follows here is the replacement.)
waterworshipper
You can do it. Let us go step by step
Start Button
Click Computer
Double Click Local Disk C
You should see a list similar to the following:
Double click "Program Data" circled above.
When you do, you will get another list showing some folders etc. Find the folder named Adobe and click on it.
(At that point, make sure to scroll all the way to the top area to make sure that you are not missing Adobe.)
When you do, you will get another line up of folders. Find specifically the folder named Premiere Elements and double click that.
When you do, you will get another line up of folders. Find specifically the folder named 9.0 and double click that.
When you do, you should see the following:
As the screenshot immediately above shows, right click the BadDrivers.txt file and select Delete.
At that point, you close out of there.
Reopen Premiere Elements 9.0/9.0.1 and see if the video card error and other problems are gone.
Please give this another look. If you run into difficulties following my instructions, then please indicate where and I will rewrite them.
Thanks.
ATR
If you have Windows 7 64 bit computer, the location for the BadDrivers.txt file should be in the corrected information just posted.
Again sorry for the detour.
11. Re: Elements 9 Error Message Cannot Up Date Intel Display Driver Why?
waterworshipper Jul 19, 2013 1:42 PM (in response to A.T. Romano)Don't apologize most people blow me
Off I appreciate your help. I will go back
To my desk top and try now.
Thank You,
708-261-6759
Licensed United States Coast Guard Captain/Senior Tackle Design R & D Engineer MidWest Division of www.jerrysflies.com/
Professional Full Time Register State Guide/Owner Kankakee River Valley Guide Service Email Bob at
Watch my Videos on YouTube
Kankakeerivervalleyguideservice.com
Sent from my iPhone4
12. Re: Elements 9 Error Message Cannot Up Date Intel Display Driver Why?
waterworshipper Jul 19, 2013 2:16 PM (in response to A.T. Romano)YESSSSSSSSSSSSSSSSSSSSSS Thank you for sharing! I'd give anything to once again be able to comprehend all the knowledge and retain then it. Great job thank you for your patience. One day it will all be returned to you at a time when you need it the most. Now I will try to quietly fade in to the back ground not to bother anyone any more please no more issues Adobe. Thank you Steve and Mr. Hunt (I know you wanted to hang yourself at times) everyone there supporting me and others ATR your the best. Trust me the last thing I want to do is to ask you for help I realize you are all very busy. Thanks Again.
13. Re: Elements 9 Error Message Cannot Up Date Intel Display Driver Why?
A.T. Romano Jul 19, 2013 2:31 PM (in response to waterworshipper)waterworshipper
We are grateful for the opportunity to help.
There is no small or insignificant question if the person asking does not know the answer and it is holding him/her back from getting that special project done.
Never, never hesitate to ask for help. When you ask for help, we all learn - the person asking, the person(s) answering, and those who are reading the thread behind the scenes.
Continued success and as always best wishes.
ATR
14. Re: Elements 9 Error Message Cannot Up Date Intel Display Driver Why?
waterworshipper Jul 19, 2013 3:23 PM (in response to A.T. Romano)I love surrounding myself with positive people if it wasn't for people like yourself I would of give up (literally) years ago.
