4 Replies Latest reply on Jul 21, 2013 6:18 PM by JonnyDL
    detect load completion from an array of images
    JonnyDL Level 1
      I have an array with 6 items. I have a for loop that dynamically builds a movie clip and loads the images. I'm trying to get an action/function to start only when the last image is finished loading I have the onLoadComplete working, but I cant seem to figure out how to get it to work on the last image and then activate an action/function?
      Wil I need to find another way of looping them using the onloadcomplete as a singnal to load the on image and then the other?
      Can anybody help?
        • 1. Re: detect load completion from an array of images
          you can use a variable to count the number of loaded images if you don't want to load them sequentially:
          var imagesLoaded:Number=0;
          whateverLO.onLoadComplete=function(mc:MovieClip){
          imagesLoaded++;
          if(imagesLoaded==yourarray.length){
          callyourfunction();
          • 2. Re: detect load completion from an array of images
            JonnyDL Level 1
            Thank you Kglad! I was able to get the script working. If I could bother you with a minor problem with the script? its with the depths. I had better controll over depths in AS3, but I need to write in AS2. Any way with the script, before I added the tweens I was able to stack the images one ontop of the other, and then set the depth of the banner_mc above the images, but when I go to tween them they are infront of the banner. How can I get that banner on top (of everything else)?
            import mx.transitions.Tween;
            import mx.transitions.easing.*;
            var MCL:Number
            var listener:Object = new Object()
            napolpics = new Array()
            napolpics = [
                                           "estimates_1_sm.jpg",
                                           "directions_1_sm.jpg",
                                           "partners_3_sm.jpg",
                                           "home_4_lg.jpg",
                                           "estimates_2_sm.jpg",
                                           "about_4_lg.jpg"
            MC_Tween = new Array
            MC_Tween = []
            for (var i=0; i < napolpics.length; i++)
                      var container:MovieClip = this.createEmptyMovieClip("big_"+i, this.getNextHighestDepth());
                      MC_Tween.push(container);
                      var mcLoader:MovieClipLoader = new MovieClipLoader();
                      mcLoader.addListener(this);
                      mcLoader.loadClip(napolpics[i], container);
                      container._y=75;
                      container._x=10;
                      container.height=161;
                      container.width=194;
                      this.onLoadComplete = function(mc:MovieClip)
                                          imagesLoaded++;
                                          if(imagesLoaded==napolpics.length)
                                                    var tweenit=setTimeout(callyourfunction, 3000);
                                                    MCL= MC_Tween.length-1
            function TweenImages()
                      trace (MCL)
                      var fadeit = new Tween(MC_Tween[MCL], "_X", Strong.easeInOut, MC_Tween[MCL]._x, 300, 4, true);
                      fadeit.onMotionFinished=function()
                                MCL--
                                if(MCL>-1){var tweenit=setTimeout(TweenImages, 3000);}
                                else{clearTimeout(tweenit)}
            • 3. Re: detect load completion from an array of images
              assign your banner's depth to be napolpics.length
              • 4. Re: detect load completion from an array of images
                JonnyDL Level 1
                thanks...that confuses me on why they chose to use swapdepth to set a depth
