1 Reply Latest reply on Jul 21, 2013 4:36 AM by Ned Murphy
    Help me with my code! Vertical Shooter Game.
    Novian2419
      Okay so I am making a Vertical Shooter Game and I want to have 2 Weapons a Smaller Blue Bullet and a larger Green Bullet. When I shoot with the green bullet the enemies dont die but with the blue bullet the enemies do. Here is a chunk of the code for the blue and green bullet hitting enemies.
      enemyTime ++;//incrementing time for enemy
      if(enemyTime == enemyLimit){//if enough time has elapsed
      _root.attachMovie('mcEnemy', 'en'+enemyTotal,_root.getNextHighestDepth());//then add the enemy
      //setting it's coordinates
      _root['en'+enemyTotal]._x = int(Math.random()*Stage.width);//randomly within the boundaries
      _root['en'+enemyTotal]._y = -50; //sets this offstage at first
      _root['en'+enemyTotal].onEnterFrame = function(){//then give it some functions
      this._y += 5;
      _root.attachMovie('mcEnemy2', 'en'+enemyTotal,_root.getNextHighestDepth());//then add the enemy
      this._y += 5;
      //run a loop checking if it's touching any bullets
      for(var cBullet:String in _root.bulletHolder){
      //if it's touching the bullet
      //we have to use coordinates because hit testing doesn't seem to work
      if(this._y >= _root.bulletHolder[cBullet]._y-30 && this._y <= _root.bulletHolder[cBullet]._y){
      if(this._x <= _root.bulletHolder[cBullet]._x+5 && this._x >= _root.bulletHolder[cBullet]._x -35){
      //then destroy this guy
      this.removeMovieClip();
      //and destroy the bullet
      _root.bulletHolder[cBullet].removeMovieClip();
      //up the score
      _root.score += 5;
      //hit testing with the user
      if(this.hitTest(_root.mcMain)){
      //set the game to be over and go to lose screen
      gameOver = true;
      gotoAndStop('lose');
      //and remove main
      mcMain.removeMovieClip();
      //checking if the game is over or it's off the stage
      if(gameOver || this._y > 450){
      //destroy this guy if the game is over
      enemyTime = 0;//reset the time
      enemyTotal ++; //add 1 more to the amount of enemies total
      //updating the score text field
      txtScore.text = 'Score:  '+score;
      //up the score
      _root.score += 5;
      gameOver = true;
      //and remove main
      //running a 2nd loop checking if it's touching any bullets
      for(var cBullet2:String in _root.bulletHolder2){
      if(this._y >= _root.bulletHolder2[cBullet2]._y-30 && this._y <= _root.bulletHolder2[cBullet2]._y){
      if(this._x <= _root.bulletHolder2[cBullet2]._x+5 && this._x >= _root.bulletHolder2[cBullet2]._x -35){
      _root.bulletHolder2[cBullet2].removeMovieClip();
      //up the score
      _root.score += 5;
      gameOver = true;
      //and remove main
      //up the score
      _root.score += 5;
      gameOver = true;
      //and remove main
      Please help I would really appreciate it
