3 Replies Latest reply on Jul 21, 2013 1:53 AM by Milky_au
    How i can create activator - serial number for my product?
    200x200 Level 1
      Hi
      I want my product find Motherboard serial and made a activate number for using software.
      It must put activate number to a file and save it.
      When an user load software it read number from file and permit him to use.
      1) How my script can find motherboard serial number?
      2) How my script can write and read on one file?
      3) Has director lingo any encryptor Function or method?
        • 1. Re: How i can create activator - serial number for my product?
          Milky_au Level 3
          You are after the 'Buddy API' xtra from www.mods.com.au
          Buddy API will do 1,2 & 3.
          • 2. Re: How i can create activator - serial number for my product?
            200x200 Level 1
            thanks
            But is there any method or function in lingo for readeing motherboard serial number?
            also is there any method for w/r files?
            • 3. Re: How i can create activator - serial number for my product?
              Milky_au Level 3
              look up info on 'fileio' xtra re: writting and reading files
              you can pull lots of computer info out of the win registry HKEY_CURRENT_USER etc. using the above method.
              best to use buddyAPI it's easier!
              --sets up a gPathName_to_where_I_want_this_file_to_read&write
              global gPathName_to_where_I_want_this_file_to_write
              set gPathName_to_where_I_want_this_file_to_write to the PathName
              -- Writes a Test File
              set myFile=new(xtra "fileio")
              createFile(myFile, gPathName_to_where_I_want_this_file_to_write & "TEST.txt")
              openFile(myFile, gPathName_to_where_I_want_this_file_to_write & "TEST.txt",2)
              put "test file" into theText
              writeString(myFile, theText)
              closeFile(myFile)
              set myFile = 0
              -- Reads a Test File
              set myFile = new(xtra "fileio")
              openFile(myFile, gPathName_to_where_I_want_this_file_to_read & "TEST.txt",1)
              set ReadFile to readFile(myFile)
              closeFile(myFile)
              set myFile = 0
              put ReadFile
