I'm running the following query and QoQ . Could you tell me how should I proceed for the "Download CSV" file option?
<!--- QoQ for FIRSTCONN --->
<cfquery datasource = "XX.XX.X.XX" name="master1">
SELECT STR_TO_DATE(date_format(Timedetail,'%m-%d-%Y'),'%m-%d-%Y') as FIRSTCONN
, COUNT(Timedetail) as FIRSTOccurances
, EVENTS
FROM MyDatabase
WHERE EVENTS = "FIRST"
GROUP BY FIRSTCONN ;
</cfquery>
<!--- Detail Query --->
<cfquery dbtype="query" name="detail1">
SELECT *
FROM master1
WHERE FIRSTCONN >= <cfqueryparam value="#form.startdate#" cfsqltype="cf_sql_varchar">
AND FIRSTCONN < <cfqueryparam value="#dateAdd('d', 1,form.enddate)#" cfsqltype="cf_sql_varchar">;
</cfquery>
<!--- QoQ for SECONDCONN --->
<cfquery datasource = "XX.XX.X.XX" name="master2">
SELECT STR_TO_DATE(date_format(Timedetail,'%m-%d-%Y'),'%m-%d-%Y') as SECONDCONN
, COUNT(Timedetail) as SECONDOccurances
, EVENTS
FROM MyDatabase
WHERE EVENTS = "SECOND"
GROUP BY SECONDCONN ;
</cfquery>
<cfquery dbtype="query" name="detail2">
SELECT *
FROM master2
WHERE SECONDCONN >= <cfqueryparam value="#form.startdate#" cfsqltype="cf_sql_varchar">
AND SECONDCONN < <cfqueryparam value="#dateAdd('d', 1,form.enddate)#" cfsqltype="cf_sql_varchar">;
</cfquery>
<cfchart format="flash" chartwidth="1000" chartheight="500" scalefrom="0" scaleto="50000" xAxisTitle="Dates" yaxistitle="Number of Connections">
<cfchartseries query="detail1" type="line" itemColumn="FIRSTCONN" valueColumn="FIRSTOccurances" >
<cfchartseries query="detail2" type="line" itemColumn="SECONDCONN" valueColumn="SECONDOccurances" >
</cfchartseries>
</cfchart>
The cfform code I'm using is as follows:
<cfform format="flash" preloader ="false">
<cfformgroup type="horizontal">
<cfinput type="dateField" name="startdate" label="Start Date" width="100" value="#form.startdate#">
<cfinput type="dateField" name="enddate" label="End Date" width="100" value="#form.enddate#">
<cfinput name="submitApply" type="submit" value = "Apply">
<cfinput name="cancel" type="submit" value="Download CSV">
</cfformgroup>
Desired Output:
I have attached the image for the output below. Please find it attached.
Basically, if a date range is 21June to 21 July. The output must be as shown in the image. (I have omitted THIRDCONN etc for the sake of simplicity in my code).
Please let me know how should I go about this problem and let me know if I can answer more questions.
Have something to add?
