3 Replies Latest reply on Jul 22, 2013 1:42 AM by Andreas Jansson
    Files not saved out path
    Simon Dav Level 1
      Hi Forum,
      I am converting IDML to INDD in specific paths of IN and OUT folders, my JS is opening multiple files only, but not saved to out folder
      please can one correct my error
      my JS:
      checkDocLen()
      var myDoc;
      var mySourceFolder = Folder("/Volumes/User/Desktop/IN");
      var myOutFolder = Folder("/Volumes/User/Desktop/OUT");
      var Idml_files = get_File(mySourceFolder,[],'.idml');
      if(Idml_files.length>0)
          for(var w=0;w<Idml_files.length;w++)
              try{
                  app.scriptPreferences.userInteractionLevel = UserInteractionLevels.neverInteract;
                  myDoc = app.open(File(Idml_files[w]));
                  var myDocNam = stripExt((Idml_files[w].name).replace(/%20/g," "))+"indd";
                  myDoc.save(File(myOutFolder+"/"+myDocNam));
                  app.activeDocument.close();
              }catch(E){}
      function get_File(dir,myfile_arr,extension)
          var f = Folder( dir ).getFiles();
          for( var ifil = 0; ifil < f.length; ifil++ )
              var mystr=f[ifil]+"";
              var aa=mystr.match(/\/[.]AppleDouble/)
              var bb=mystr.match(/[_]VUC69~7/)
              var cc=mystr.match(/DS[_]Store/)
              if( f[ifil] instanceof Folder )     //change
                  if((aa==null) && (cc==null))
                      get_File( f[ifil],myfile_arr,extension)
              else
                  if(extension!=".*")
                      if( f[ifil].name.substr( -extension.length ) == extension )
                          myfile_arr.push(f[ifil])
                  else
                      if((bb==null) && (cc==null) && (f[ifil] instanceof Folder == false))
                          myfile_arr.push(f[ifil]);
          }//for
          return myfile_arr;
      function stripExt (f)
              return f.substring(0,f.length-4);
      function checkDocLen()
          while(app.documents.length!=0)
              try{
              }catch(e){}
      Thanks in advance
      Simon
        • 1. Re: Files not saved out path
          Mac_rk Level 2
          change
          to
          var mySourceFolder = Folder("~/Desktop/IN");
          var myOutFolder = Folder("~/Desktop/OUT");
          • 2. Re: Files not saved out path
            Simon Dav Level 1
            Hi Mac_rk,
            It works in Desktop only, but not working in server, I found it, as your way. Maybe my fault I asked only for Desktop.
            the code is:
            Folder("/SERVER/LiveJobs/IDML/IN")
            Mac_rk wrote:
            change
            to
            Great! Mac_rk
            Many Thanks
            Simon
            • 3. Re: Files not saved out path
              Andreas Jansson Level 2
              Oops... the question was already answered. Sorry. Some other things got in between before I sent my answer.
              // Andreas
              I changed the paths to desktop to a generic format (since I use windows):
              var mySourceFolder = Folder.desktop + '/IN';
              var myOutFolder = Folder.desktop + '/OUT';
              Then I created an IN-folder on my desktop, put three idml files in it and ran the script. The three files were opened and saved as indd files in the OUT folder. No errors.
              I suggest that you add an alert to the error handler, showing any errors.
              Or simply step through the script in the ExtendScript Toolkit, and when you are on the line with the save call, just write out the contents of
              File(myOutFolder+"/"+myDocNam).fsName
              in the javascript console window of the Extendscript Toolkit.
              There is probably some error.
              Also, there is no need to set app.scriptPreferences.userInteractionLevel = UserInteractionLevels.neverInteract more than once.
              It may very well be this that hides something for you, you could try running the script with userInteraction set to its default, just to make sure.
              Best regards,
              Andreas
              Message was edited by: Andreas Jansson
