3 Replies Latest reply on Jul 22, 2013 12:40 PM by A.T. Romano
    Rotating a video Clip
    andrew-dd_1937
      How do I rotate a PE11 video clip 180 degrees?
        • 1. Re: Rotating a video Clip
          A.T. Romano Level 7
          andrew-dd_1937
          Have you tried the following...
          Expert view
          Timeline
          Highlight Clip
          Applied Effects Tab at right of interface
          Applied Effects Palette
          Motion Panel expanded
          and the go to Rotation in that Motion Panel expanded...use slider or type in degrees accordingly.
          Expert view
          Timeline
          Right click the clip
          select Rotate 90 degree left or Rotate 90 degree right as many time as necessary to get your 180 degrees.
          Please let us know if any of that worked for you.
          Thank you.
          ATR
          • 2. Re: Rotating a video Clip
            andrew-dd_1937 Level 1
            Thank you.  That worked fine in the Expert view but why doesn't the Projct Asset image also rotate?
            • 3. Re: Rotating a video Clip
              A.T. Romano Level 7
              andrew-dd_1937
              Glad that worked for you in the Expert view Timeline.
              The Project Assets has only copies of the source media, and those copies all link back to the source media at their hard drive save location.
              Once you drag a photo or video from Project Assets, the editing of the photo or video on the Timeline is not reflected in the Project Assets thumbnails. The only exception to that rule seems logical, that is, when you create a title in the program's Titler, edit that title in the Titler, and close the Titler, leaving the edited title file on the Timeline, what you see in Project Assets is a thumbnail for that title with all its up to date edits.
              If you are interested in going deeper into this train of thought, an interesting tour is the Replace Footage feature.
              http://help.adobe.com/en_US/premiereelements/using/WSDFC96396-A9C4-4a7a-A1B0-2549F5E479D4. html
              ATR
