19 Replies Latest reply on Aug 14, 2014 11:01 AM by ChrisGoT
    Coldfusion 10 Update 11 SQL Server 2012 Query.columnList() Geometry Fields Error
    ChrisGo77345345
      When we do a query.columnList on a table that contains a geometry
      datatype column it errors with unsupported data type. This does not
      seem to be fixed in CF10 - Update 11. Have you heard of this, seen
      this or have a solution to this issue?
      Super easy to reproduce, just create a table with a geom or geography
      column, run a query Select TOP 1 * FROM TABLEWITHGEMO, whatever and
      then do the queryname_columnList which normal returns column names
      that you can loop through (as you most likely know).
