6 Replies Latest reply on Oct 5, 2007 12:31 PM by Paul_D
    Displaying Slide Label or Frame Number
    SJD Level 1
      I was wondering if there is a way to display the slide label or frame number while a presentation is running. I am trying to find an easy way for reviewers to identify where they want changes made.
        • 1. Re: Displaying Slide Label or Frame Number
          Hi SJD
          Perhaps fellow Adobe Community Expert Paul Dewhurst's site can help here. Take a look at this link.
          Cheers... Rick
          • 2. Re: Displaying Slide Label or Frame Number
            SJD Level 1
            Because of our corporate network security I cannot insert someone elses SWF file in one of mine. Doesn't Captivate have a variable or code that can be inserted easily?
            • 3. Re: Displaying Slide Label or Frame Number
              Hi again SJD
              First off, I'm not understanding your statement with regards to using someone else's SWF. How will your network ever know? From what I understand of it, you download the .SWF and simply include it among your project files. From the network perspective, I would think it wouldn't be able to differentiate between the counter .SWF or one of the Captivate supplied animation .SWF files.
              Obviously it can be done, as you have seen on Paul's site. But there is absolutely nothing inside Captivate that will help you with this. The only "Total Captivate" possibility would be to maybe insert a transparent Text Caption on each slide. Instead of inserting text in the caption, you would type the slide number.
              You should also consider submitting a Wish Form asking for this functionality to be added to a future Captivate version. You may do this by clicking here and completing the form you should find there.
              Cheers... Rick
              • 4. Displaying Slide Label or Frame Number
                SJD Level 1
                Unless I have the FLA file I cannot see any Actionscript or other code the file contains...right? So if I put a SWF file into my presentation and it contains malicious code, this could be a problem.
                • 5. Re: Displaying Slide Label or Frame Number
                  Hi again
                  Fair enough I suppose. Sure, if you just grabbed a random .SWF off the web at large, I might understand the caution. However, I would think that with Paul being a recognized Adobe Community Expert, he would never jeopardize that status by inserting malicious code in what he offers.
                  Cheers... Rick
                  • 6. Re: Displaying Slide Label or Frame Number
                    Paul_D Level 1
                    Just to point out that there is NO malicious code in any of the files on my site nor has there ever been, over 8000 downloads and not one complaint, also if you look a bit closer you would see that the FLA for counter is available to download
