2 Replies Latest reply on Jul 23, 2013 8:20 AM by resdesign
    Communication between Symbols/Elements
    ThePixell95
      Hey Guys,
      I have a very basic question.
      I have a Textfield where you can put a number in.
      I also have another symbol where I want to "import" this number.
      The question is, how can I get the variable with the number from the one symbol to the other?
      I dont really found an answer in the documentation or something.
      Cheers
      - Daniel
        • 1. Re: Communication between Symbols/Elements
          resdesign Adobe Community Professional & MVP
          I suppose there are multiple ways to do this. Depends exactly what you are doing.
          // 2 variables that you compare when needed. They would not have to be the same all the time. Only when you decide it.
          var myNumber = 20;
          //Then you can use the variable in textField and change it.
          sym.$('textField').html(myNumber);
          // assign variable to the text Text in the symbol otherfield
          myOtherNumber = myNumber;
          sym.getSymbol('otherfield').$('Text').html(myOtherNumber);
          // you can use the same variable and when it changes in the first field it will also change in the other one since it is the same variable.
          var myNumber = 20;
          // it will have the same value as the first one.
          sym.getSymbol('otherfield').$('Text').html(myNumber);
          here is a comparison on a click event:
          // assign variables for each text field.
          var myNumber = 25;
          var myOtherNumber = 12;
          // click event compare the 2 variables and fills in the text field.
          sym.$('textField').click(function(){
          if (myOtherNumber == myNumber){
          else{
          sym.getSymbol('otherfield').$('Text').html('sorry');
          • 2. Re: Communication between Symbols/Elements
            If you have an input field then you can get the value then you could do it this way:
            var textField2= sym.$("textField2");
            textField2.html("Enter your number ");
            myNumber = $('<input />').attr({'type':'text', 'value':'', 'id':'textField2'});
            myNumber.css({'font-size': 14, 'background-color': '#0a81fb','box-shadow': '#0a81fb','width': 250});
            myNumber.appendTo(textField2);
            var otherField2 = sym.getSymbol('otherfield2').$('Text');
            sym.$('update').click(function(){
            var newValue = myNumber.attr("value");
            otherField2.html(newValue);
            Here is the file with both examples:
            https://app.box.com/s/9jq27re2w0todtbjhur7
