6 Replies Latest reply on Jul 24, 2013 1:38 AM by davealot
    How to output full image path to logger/console
    davealot
      Hi All
      I'm just starting to get my hands dirty with the lr sdk and could do with a little guidance.
      For part of a plugin I need to retrieve the full path to each image, and although I can achieve what I want I'm struggling to print the path to the console/logger and can't understand why.
      Here's a snippit of code to illustrate things:
      for photo in exportSession:photosToExport() do
           filename = photo:getFormattedMetadata( "fileName" )
           outputToLog( filename )  -- Works as expected
           folderName = photo:getFormattedMetadata( "folderName" )
           outputToLog( folderName )  -- Works as expected
           local path = LrPathUtils.standardizePath(photo:getRawMetadata("path"))
           outputToLog( path ) -- Output is always blank
           -- and yet when passed to exiftool the path is correct and works as expected
           LrTasks.execute("exiftool  -Copyright=\"Imaginary person\" \""..path.."\"")
      end
      Basically I can get the path and use it as part of an exiftool command, but can't work out how to output the path to the log/console for debugging purposes. Am I missing something simple or is this an intentional limitation?
      Any help much appreciated.
        • 1. Re: How to output full image path to logger/console
          areohbee Level 6
          It would help if you posted outputToLog code too, but the problem could be due to backslashes if windoes environment - sometimes you need to double-'em up.
          • 2. Re: How to output full image path to logger/console
            davealot Level 1
            Here is the outputToLog code:
            local myLogger = LrLogger( 'libraryLogger' )
            function outputToLog( message )
              myLogger:trace( message )
            end
            Do I need to format the output using logger:tracef( format, ... ) instead?
            If it makes any difference I'm working in an OSX environment.
            • 3. Re: How to output full image path to logger/console
              areohbee Level 6
              I don't know what the problem is. What device are you outputting to?
              i.e. did you try logger:enable( "logfile" ) -- that works for me in OSX to log to a file.
              Here is the code I use:
              self.logger = LrLogger( logName )
              local function logToFile( msg )
                  local f = io.open ( self.logFilePath, "a" )
                  if f == nil then
                      Debug.pause( "can't open log file", self.logFilePath )
                      return
                  end
                  f:write ( LrDate.timeToUserFormat( LrDate.currentTime(), "%Y-%m-%d %H:%M:%S"), " ", msg, '\n' )
                  f:close ()
              end
              if self.verbose then
                  --self.logger:enable( 'logfile' ) -- enable everything to log file.
                  self.logger:enable( logToFile )
              else
                  local actions = {
                      -- debug output is suppressed when not logging verbosely
                      trace = logToFile,
                      info = logToFile,
                      warn = logToFile,
                      error = logToFile,
                      fatal = logToFile,
                  self.logger:enable( actions ) -- suppress trace & debug.
              end
              R
              • 4. Re: How to output full image path to logger/console
                johnrellis Most Valuable Participant
                Dave,
                I can't add anything more specific than Rob has already said.  But you might look at my Debugging Toolkit (free).  It takes a bit of time to learn and hook up at first (about 30 minutes), but it can really save you time going forward.
                • 5. Re: How to output full image path to logger/console
                  davealot Level 1
                  Rob,
                  You were right, the problem only exists when I use logger:enable( "print" ) in combination with osx console to view the output. If I use logger:enable( "logfile" ) then the path shows up as expected.
                  For others it might be worth noting that in a Windows 7 environment logger:enable( "print " ) works fine with windbg to view the ouput.
                  Thanks for your help and the logToFile function.
                  Dave
                  • 6. Re: How to output full image path to logger/console
                    davealot Level 1
                    John, thanks for the toolkit link, I've been meaning to give it a go.
