0 Replies Latest reply on Jun 12, 2006 8:42 AM by NMC2004
    filereference proxy
    NMC2004
      Does anyone have problems with the fimereference when using behind a proxy.
      I made a fileupload using flash8 filereference that works as long as you use it from outside the domain. If you try to use the fileupload from wiothin the domein (the office uses a proxyserver for internet access) the upload does not work. The .php script executing the move_uploaded_file is not called at all!
      Has anyone had this problem ? And...is there a solution.
