15 Replies Latest reply on Nov 7, 2016 6:22 AM by rob day
    Exporting PDF resolution changed from 300 to 212.18 dpi
    sexual_sushi
      Hello, I have been exporting from indesign for the last 1.5 years with a PDF preset (see summary below). All of a sudden it is now changing the resolution of the PDF to 212.18 dpi.
      The indesign document is basically made up up PSD images at 300 dpi. I am trying to export to a PDF at 300 dpi. Asyou can see the quality options are set to downsample to 300dpi for images above 300 dpi.
      This is on inDesign CC, however this exact preset process has worked previosuly on CC, CS6 & CS5.
      Can anyone tell me why this is happening?
      Compatibility: Acrobat 4 (PDF 1.3)
      Standards Compliance: None
      General
          Pages: All
          Spreads: Off
          Generate Thumbnails: On
          Optimize PDF: Off
          Create Acrobat Layers: N/A
          Export Layers: Visible and Printable Layers
          Include Bookmarks: Off
          Include Hyperlinks: Off
          Export Nonprinting Objects: Off
          Export Visible Guides and Baseline Grids: Off
          Create Tagged PDF: Off
          Interactive Elements: Do Not Include
      Compression
          Color Images
              Bicubic Downsample at: 300 ppi
              for images above: 300 ppi
              Compression: JPEG
              Tile Size: N/A
              Quality: Maximum
          Grayscale Images
              Compression: JPEG
              Tile Size: N/A
              Quality: Maximum
          Monochrome Images
              No Sampling Change
              for images above: 1800 ppi
              Compression: None
          Compress Text and Line Art: On
          Crop Image Data to Frames: On
      Marks and Bleeds
          Crop Marks: Off
          Bleed Marks: Off
          Registration Marks: Off
          Color Bars: Off
          Page Information: Off
          Page Mark Type: Default
          Weight: 0.50 pt
          Offset: 2 mm
          Use Document Bleed Settings: On
          Bleed Top: 5 mm
          Bleed Bottom: 5 mm
          Bleed Inside: 10 mm
          Bleed Outside: 5 mm
          Include Slug Area: Off
      Output
          Color Conversion: No Color Conversion
          Destination: Adobe RGB (1998)
          Profile Inclusion Policy: Include All Profiles
          Simulate Overprint: Off
          Output Intent Profile Name: N/A
          Output Condition: N/A
          Output Condition Identifier: N/A
          Registry Name: N/A
      Advanced
          Subset Fonts Below: 100%
          Omit PDF: Off
          Omit EPS: Off
          Omit Bitmap Images: Off
          Transparency Flattener Preset: Momento Indesign Flatten
          Ignore Spread Overrides: Off
      Security
          N/A
      Warnings
