1 Reply Latest reply on Jul 24, 2013 9:57 AM by sjpt
    e_lic_already_fulfilled_by_another_user
    egyptians
      ENGLISH:
      I bought a digital book with .acsm extension.
      I opened it on another computer (not my computer) without giving it a ID account.
      The problem is that I created a adobe account only AFTER downloaded the e-book on the other computer.
      Now i NEED to open it on MY computer with the account I created. But I cannot do this due of: e_lic_already_fulfilled_by_another_user.
      - How can I solve the problem?
      - Is it possibile to give my ID to the .acsm file (that hasn't an ID account)?
      I mean: If I login (with the my ID account) on the "other" computer, can I transfer the .acsm on my library?
      ITALIANO:
      Ho comprato un e-book con estensione .acsm.
      Ho aperto il file su un altro pc, che non  è il mio, senza collegarlo ad un account (quindi senza dargli ID).
      Adesso ho creato un account adobe sul mio pc (quindi dopo aver scaricato il libro sull'altro pc).
      Non posso, però, aprire adesso il file .acsm sul mio pc perché mi da questo errore:
      - Come posso fare?
      - È possibile collegare  l' e-book (senza ID) al mio nuovo account?
      Cioè: Se entro con il mio account di adobe "sull'altro" computer, posso trasferire il file nella mia libreria?
      THANKS ANYONE.
        • 1. Re: e_lic_already_fulfilled_by_another_user
          sjpt Level 4
          The book is locked to the account in use when you first opened the .acsm.
          If that is an 'anonymous' account you get by using ADE without ID, it cannot be used anywhere else;
          and can't even be used on the original computer if you register that with a proper account.
          This is a vicious trap that Adobe lays for unsuspecting customers.
          When you register 'without ID', ADE creates an anonymous/implicit ID with limited powers (eg can't be used to share with other devices).
          Whenever you first load a DRM book, that copy of the book is associated with whatever ID the computer is registered to at the time.
          Any book you load while this anonymous ID is active gets associated with that ID, and can't be read on any other device.
          When you properly register your computer with a real ID, that old anonymous ID is lost.
          Now you don't have any devices that can read the book.
          The only way I know round this is to use a DRM stripper such as epubee BEFORE you deauthorize the device.
          I do NOT advocate using such code to get around the valid limitations placed on a DRM book.
          However, where the problem arises only because of the ineptness of Adobe's ADEPT DRM infrastructure and its implementation,
          such a measure is totally justifiable.
          google translate ....
          Il libro è bloccato per l'account in uso quando hai aperto il. ACSM.
          Se questo è un account di 'anonymous' si ottiene utilizzando ADE senza ID, esso non può essere utilizzato in qualsiasi altro luogo;
          e non può nemmeno essere utilizzato sul computer originale se si registra che con un conto corretto.
          Questa è una trappola vizioso che Adobe prevede per i clienti ignari.
          Quando ti registri 'senza ID', ADE crea un ID anonimo / implicito con poteri limitati (ad esempio non può essere utilizzato per condividere con altri dispositivi).
          Ogni volta che si carica un libro DRM, che copia del libro è associato con qualsiasi ID del computer è registrato al momento.
          Qualsiasi libro si carica durante questo ID anonimo è attivo viene associato a tale ID, e non può essere letto su qualsiasi altro dispositivo.
          Quando si registra correttamente il computer con un vero e proprio ID, che il vecchio ID anonimo è perduto.
          Ora non avete alcun dispositivo in grado di leggere il libro.
          L'unico modo che conosco tutto questo è quello di utilizzare una spogliarellista DRM come epubee PRIMA rimuovi l'autorizzazione del dispositivo.
          Io non sostengo utilizzando tale codice per aggirare i limiti validi posto su un libro DRM.
          Tuttavia, se il problema si pone solo per l'inettitudine di ADEPT infrastruttura DRM di Adobe e la sua attuazione,
          tale misura è del tutto giustificabile.
